150k maintenance suggestions
Discussion in '1st Gen. Tacomas (1995-2004)' started by '01runner, Feb 7, 2021.
  1. Feb 7, 2021 at 11:32 AM
    '01runner
    '01runner [OP] Member
    Lucas
    2001 Tacoma PreRunner
    Hey all,
    New to the forum, and pretty new to being a fellow Tacoma owner.
    I got my 2001 PreRunner about 1.5-2 years ago from a family friend. They were the second owner, and they got it from one of their family friends. It had about 108k original miles on it at that time.
    It has been a complete joy to own, as the only trouble it's ever given me was when I needed to replace the spark plugs.
    Now, I am steadily approaching 150k and my radiator just cracked along the top.
    I was about to call up my local parts house to see what they had in stock, when I figured I might as well do the belts at the same time. Being somewhere in between a certified mechanic and a total dingus, I figure this job might take me a couple of days.
    I'm thinking I'll put a new thermostat in too.
    So, my question to you all is this: What else might you replace/check while you have the radiator pulled out?
    Thanks ahead of time, I appreciate any help you can offer!
    Lucas
    Taco critter likes this.
  2. Feb 7, 2021 at 11:58 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    The radiator is a quick job, the accessory belts aren't bad even with the radiator still in but you could to make them easier. Timing belt is a whole mess you probably don't want to get into unless its time.
    '01runner[OP] likes this.
  3. Feb 7, 2021 at 1:01 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    replace drive belts, proper coolant change, a new thermostat and waterpump wouldn't be a bad idea while you're at it. The AISIN brand waterpumps are known around here for being of very good quality and basically OEM. Other than that, perhaps a brake fluid drain and fill, a small amount of transmission drain and fill (there's some good threads on here about this), as well as power steering fluid. Basically every fluid
  4. Feb 7, 2021 at 3:57 PM
    '01runner
    Lucas
    Cool. Good deal. Are my original Pulleys fine to keep using? Anything I should check as far as those go?
  5. Feb 7, 2021 at 4:26 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    pulleys are good. Just replace them when they start making noise
  6. Feb 7, 2021 at 4:30 PM
    '01runner
    Lucas
    I should mention, on cold, and especially cold AND WET mornings, there is always some squealing until everything warms up. When I say cold, I'm talking California cold, so lowest being 40-50 degrees fahrenheit... It sounds like its coming from the belts but the belts don't show signs of cracking or tearing. Would this be the pulley noise you are talking about?
    Thanks for the help!
  7. Feb 7, 2021 at 4:35 PM
    '01runner
    Lucas
    I found a youtube video on this. I think I've got it from here... Thanks again for your help!
    crazytacoman likes this.
  8. Feb 7, 2021 at 4:37 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    It's pretty normal due to humidity as well. Happens to me especially when i see mildew on everything in the mornings. Though, if it keeps for longer than a few seconds, I recommend tightening your belts a little bit. For me it was the belt that's connected to the power steering pulley. I had to tighten it a little bit a few times until it was tight enough.
  9. Feb 7, 2021 at 4:42 PM
    '01runner
    Lucas
    Awesome. Thanks for pointing out exactly which pulley it was for you. It definitely lasts longer than a few seconds. It usually lasts for a few minutes on a cold start. Since I have only had it for less than a 2 years I don't know if the belts have ever been replaced. I am thinking they may just be stretched out. Before I tear into the new belts though, I will try and see if its a pulley as well that is making the noise. Then I can replace that at the same time as refreshing the belts.
    crazytacoman[QUOTED] likes this.
  10. Feb 7, 2021 at 4:46 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Good luck! and take a look at the youtube videos that help you determine if the belt is tight enough
    '01runner[QUOTED][OP] likes this.
  11. Feb 8, 2021 at 4:20 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
  12. Feb 9, 2021 at 10:55 AM
    L78
    L78 Well-Known Member
    Tony
    Nor Cal
    1995 Tacoma DLX, 2.7/Manual, 4x4, 1 family ownership
    Mostly stock, added custom wood bed rails and a Sony/Infinity stereo system
    How about the upper and lower radiator hoses?
  13. Feb 9, 2021 at 11:48 AM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    1997tacomav6 likes this.
  14. Feb 9, 2021 at 1:23 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    I have no idea, I did this myself, super simple job. remove the cooling fan, and about 4 or 5 bolts, the top part of the timing cover. disconnect the to radiator hose, which might cause you to loose s small amount of coolant, but really it's an easy job, so easy even a "crippled old man" can do it.
  15. Feb 9, 2021 at 1:24 PM
    vettehigh
    Jon
    Upstate, NY
    No rad hose removal either?
  16. Feb 9, 2021 at 1:25 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    yes, check my edited comment
    vettehigh[QUOTED] likes this.
  17. Feb 9, 2021 at 1:27 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Also, don't be dumb like I was, put a piece of cardboard or something in front of your radiator, so you don't mess up the cooling fins when you remove the fan. I banged my fan into my radiator. No leaks but I don't like the fact that the air isn't flowing through it like it should.
  18. Feb 9, 2021 at 1:39 PM
    1997tacomav6
    Denver
    Less than an hour
  19. Feb 9, 2021 at 7:01 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Welcome to the forum!
    These trucks don't need much especially at only 150,000 as it's just getting broke-in. Belts and hoses would be good since replacing the radiator.
    I wouldn't even bother with the water pump as my '96 has 414,000 miles on the original water pump, original radiator too for that matter.
  20. Feb 10, 2021 at 5:05 AM
    vettehigh
    Jon
    Upstate, NY
    Holy :headbang:
