150k mile serivce
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Envo, Nov 7, 2016.
  1. Nov 7, 2016 at 9:00 AM
    Envo
    Envo [OP] Member
    Jack
    2006 Desert Sand TRD Offroad
    Just popped into my local toyota dealer to get an estimate on the 150k mile service on my tacoma.
    Im currently at 146k, thinking im just gunna do the service myself. prices are pretty insane at the dealer!
    spark plugs - $247
    transmission service - $295
    diff service - $262
    t-case service - $130.95
    fuel system service - $170
    brake fluid service - $137
    LOF service - $60
    tyre rotate $30
    all seems pretty high to me. with regards to diff tcase transmission service, are they just gunna change the oil or strip em down and inspect em? guess the fuel system service is just a bottle of cleaner dumped in the tank for $170 :p
  2. Nov 7, 2016 at 10:16 AM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    Those rates are about what I would expect to pay in my area (near San Francisco). Where are you located? Diff and transfer case will likely be drain and fills. Tranny for that price likely a flush which might not be good given your miles. If you have tools, time, and space you can do half of the items on the list yourself even if you have limited mechanical knowledge. I think it cost me about $120 for fluids and washers to do drain and fills on the diffs, transmission, and power steering (ps was siphon and fill). Tools for these would run less than $100. That took about three hours or so plus the time to get supplies, and I was going at snail pace.
  3. Nov 7, 2016 at 10:19 AM
    Envo
    Envo [OP] Member
    Jack
    im pretty mechanicaly sound. have worked on alot of old trucks, had to fix my 1977 f250 pretty much every weekend something else would break on it:p and i built an old Series 2 landrover. just not worked on too many modern cars. but changing fluids is pretty simple. spark plugs i can def do. $1222 dealership service. i could get a sweet bumper for that:p
  4. Nov 7, 2016 at 10:20 AM
    Envo
    Envo [OP] Member
    Jack
    oh and im in Colorado on the western slope
  5. Nov 7, 2016 at 10:21 AM
    BaconPower
    BaconPower Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    LOF service?
  6. Nov 7, 2016 at 10:22 AM
    Envo
    Envo [OP] Member
    Jack
    lube oil and filter service
    so ur general engine oil/filter air filter etc
  7. Nov 7, 2016 at 11:23 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks for showing me all the $$$ I save - even more then I thought. I do everything myself but this make me even happier that I do.
    1R0NMAN811, BaconPower and Envo[OP] like this.
  8. Nov 7, 2016 at 3:11 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Wooh buddy! You could buy a tool chest and fill it with the amount of money you will save doing it yourself.
    Pabloeeto likes this.
  9. Nov 7, 2016 at 4:20 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Damn those prices... I should become certified and open my own garage.
  10. Nov 7, 2016 at 4:22 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    The fuel system service consist of a pour in treatment and a can of carb cleaner as they spray your throttle body. Everything over priced with the exception of transmission service depending it it is a complete flush.
  11. Nov 7, 2016 at 7:56 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    For that much money, they better use lube
