15's on a second gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LUISFER, Jan 9, 2012.
  1. Jan 9, 2012 at 8:51 AM
    LUISFER
    LUISFER [OP] Member
    TX
    2010 TACOMA 4X4
    Hello,
    I bought a set of 15" pro comp steel wheels for my second gen. It has a 32" X 11.5 all terrain. I made them fit by adding a 1.25 spacer and grinding down on the calipers a bit. I love how it looks but I ended up busting the right caliper. Now I see that the only way to get them to fit without ruining the calipers is to put in a 2 inch spacer. Does anyone have any advice if it will work or how bad I might mess up my truck If i do that. The plan is to put in new ungrinded calipers and then the spacer.
  2. Jan 9, 2012 at 8:57 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Seems like it'd be a lot easier to go with 16" or 17" wheels... Personally, I'm not a fan of spacers and definitely wouldn't want one that big on the truck.
  3. Jan 9, 2012 at 11:22 AM
    nimrod712
    nimrod712 Well-Known Member
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    A 2" spacer on top of what looks like less than 3" of backspacing? Bad idea..
    Your best option is to get new wheels and tires...
  4. Jan 9, 2012 at 1:31 PM
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    That looks sweet! Yea ive heard 15's are basically impossible to fit.. But you might be onto something i wouldnt want to widen it more though, what lift set up do you have?
  5. Jan 9, 2012 at 2:07 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    :eek: 2" wheel spacers,not for me.puts alot of added stress on the front end
  6. Jan 9, 2012 at 2:14 PM
    DPR921
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    Any detail on those roof lights aswell?
  7. Jan 9, 2012 at 2:17 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Curious why you are so dead set on 15s.
    I have 0 fitment issues with my 16s and is an easy size to find tires.
  8. Jan 9, 2012 at 2:24 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    :eek:
    Your wheel bearings will hate you. Also, you will increase your scrub radius dramatically.
    Did you use the stock wheel studs with your 1.25" spacer?
  9. Jan 9, 2012 at 2:26 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yeah those wheels stick out way too far as it is. I'm surprised you can turn at all without rubbing. Looks pretty silly actually IMO,
  10. Jan 9, 2012 at 3:25 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Looks like one of those 90s model Chevy Mexican trucks that have the wheels completely outside of the fenderweel
  11. Jan 9, 2012 at 3:51 PM
    inesshell
    inesshell blah blah blah
    john
    Superwhite 10' AC
    looks liek ass to me. Show us a front shot....
    and it reminds me of this
  12. Jan 9, 2012 at 4:13 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    pics of calliper?
  13. Jan 10, 2012 at 6:34 AM
    LUISFER
    LUISFER [OP] Member
    TX
    2010 TACOMA 4X4
    I have a 3 inch space in the front and an add a leaf which gives me around 2 inch in the back. I am about to put a 3 inch block and some pro comp shocks on top of that though.
  14. Jan 10, 2012 at 6:37 AM
    LUISFER
    LUISFER [OP] Member
    TX
    2010 TACOMA 4X4
    I dont really care that much on the size. They are just the ones I bought thinking they would fit. I like how they look so I will try that last option and see if it will work for me if not they will be on craigslist soon.
  15. Jan 10, 2012 at 6:38 AM
    KPT
    09 Prerunner
    You can't stack lifts like that on an independent front suspension. You will have no down travel left and your ball joints will bind. Do not do that.
  16. Jan 10, 2012 at 6:39 AM
    Pugga
    Massachusetts
    So you have a 3" spacer lift up front, a 2" AAL for the back, 15" rims that you want to run 2" wheel spacers with and are not thinking about a 3" block for the rear???
    I gotta ask, did you just search though TW for the set up with the most issues and lowest performance? Just seems like you're asking for trouble with that set-up...
  17. Jan 10, 2012 at 6:43 AM
    LUISFER
    LUISFER [OP] Member
    TX
    2010 TACOMA 4X4
    Here it is. I was thinking some fender flares might help.
  18. Jan 10, 2012 at 6:43 AM
    KPT
    09 Prerunner
    Actualy re-reading i can't tell if he's talking about stacking front and rear lifts or only the rear.
  19. Jan 10, 2012 at 6:50 AM
    Pugga
    Massachusetts
    I assumed rear but that would be horrible if he was planning on adding another block to the front. The 3" block on the rear will just produce horrible axle wrap, the front would tear up the whole front end without a drop bracket.
  20. Jan 10, 2012 at 6:50 AM
    LUISFER
    LUISFER [OP] Member
    TX
    2010 TACOMA 4X4
    Roof light are by Recon.
    www.gorecon.com
