15's on my 04?
Discussion in '1st Gen. Tacomas (1995-2004)' started by LearningToFly, Jun 14, 2017.
  1. Jun 14, 2017 at 5:42 PM
    LearningToFly
    LearningToFly [OP] Well-Known Member
    Northeast Alabama
    2004 Double Cab
    Hey guys. Can I run 15's on my 2004 Tacoma? I have a nice set of factory chrome wheels from a first gen pickup (83). Just wondering if any of y'all have tried it.
  2. Jun 14, 2017 at 5:45 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The early Tacoma s had 15" wheels. The TRD version were 16". All I can say is check to see if the break calipers clear.
  3. Jun 14, 2017 at 5:59 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Not sure about 83 rim, but 15 do fit up to 04. Depending on back spacing tho. One too many people so no, but they fit with proper spacing.
    I'm running 15x10 w/ 3.5 back spacing. No rub, clear caliper.
  4. Jun 14, 2017 at 6:32 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If you already have them, just jack it up and put them on and see for yourself.
    They'll more than likely be *close*, one way or the other.
  5. Jun 14, 2017 at 7:46 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I am running an old set of Enkei 15's that I had on my '92, now use them for my winter tires. I keep my 16's for summer street tires. No problem with fitment.
  6. Jun 14, 2017 at 8:05 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I ran 15" rims from a '00 on my '01 (which came with 16"). The 16s were steelies whereas the 15s were the older toyota aluminum wheels with way better tires. The swap worked fine on both vehicles.
  7. Jun 14, 2017 at 10:35 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Some 15's clear, some don't. I have Pro Comp 7069's in a 15" and they clear the caliper but I know a lot of the steel 15" wheels don't fit. Try it and see if you have the wheels already!
  8. Jun 14, 2017 at 10:49 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, I've done it. 15" OEM wheels from a 2000 on my 2003 which came with 16s.
  9. Jun 15, 2017 at 8:36 AM
    LearningToFly
    Northeast Alabama
    2004 Double Cab
    Thanks for the info. I bolted the bare wheel on there and it clears the caliper just fine. Thinking of finding a set of mud tires to go on them for winter.
