15x10 on stock suspension 99 taco
Discussion in 'Wheels & Tires' started by deerslayer, Nov 25, 2011.
  1. Nov 25, 2011 at 9:20 AM
    deerslayer
    deerslayer [OP] Active Member
    addison
    cleveland, tn
    '17 inferno trd OR
    Could i fit 15x10? If so what size tire you suggest with no or minimal rub? Thanks.
  2. Nov 26, 2011 at 7:48 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I suggest you need at least a 12.5" wide tire to even consider running 10" wide rims. And there's no way you could do that on stock suspension. Look for 7-8" wide rims.
  3. Nov 26, 2011 at 8:19 AM
    ratso
    ratso Well-Known Member
    northern ca2
    sr5
    Camburg coilovers,ARB, warn 9000,avic d3,KN cold air,poweraid, optima yellow top,line x
    The widest wheel I would get is 8.5 with the right offset the wheels will stick out giving you a wider stance. This may help Offroad but will throw mud and snow down the side of your Tacoma giving it a nice winter coat.
