15x7 with 3.75 in backspacing
Discussion in '5 Lug' started by Scrider424, Oct 13, 2013.
  1. Oct 13, 2013 at 2:14 PM
    Scrider424
    Scrider424 [OP] Well-Known Member
    Anthony
    San Luis Obispo, CA
    2018 DCSB 2.7l
    I'm about to pull the trigger on some new wheels, but I wanted to get a couple of opinions if anybody thinks they will fit without rubbing on the caliber.
    I'm looking at part number SUM-84-5765 from summit. They are 15x7 and have 3.75 inch back spacing. Will these rub? Any help is appreciated.
  2. Oct 13, 2013 at 3:02 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I'd go to a 16" to be safe.
    The 6-lug comes with 16" and has issues with most 16" aftermarket.
    I've seen some 5 lug that are tight with even 16" alloys.... had a set on the Marketplace a couple of months ago where the owner had a wheel welded up where the caliper had worn it.
  3. Oct 14, 2013 at 7:46 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I think those are the exact specs on mine, but I'm 1st gen
  4. Oct 14, 2013 at 9:27 AM
    Scrider424
    Anthony
    San Luis Obispo, CA
    2018 DCSB 2.7l
    Yeah I had to stay with 15 since my tires are already 15. Plus I like the look of more tire than rim.
    So it should fit than since our trucks have the same lug pattern it's just a matter of it rubbing in the brake caliper?
  5. Oct 14, 2013 at 7:39 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Caliper rubbing.
    If you're buying local, no problem, you can mount them up and see if they rub, but if you're buying online from Summit, you may be SOL.
  6. Oct 17, 2013 at 5:57 PM
    Scrider424
    Anthony
    San Luis Obispo, CA
    2018 DCSB 2.7l
    Mowtaco. I know your a first gen but was there a decent amount of space between your wheels and the brake caliper?
  7. Oct 23, 2013 at 7:48 PM
    MowTaco
    Kansas
    I think so, I guess I can check for you. Our problems arise from tire hitting spindle typically
  8. Oct 23, 2013 at 10:04 PM
    Scrider424
    Anthony
    San Luis Obispo, CA
    2018 DCSB 2.7l
    Awesome thanks Mowtaco. No worries about checking I was just concerned at first because I only have about the size of a credit card between my wheels and caliper bracket.
