15x8 backspacing?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2KTacoPr3runn3r, Nov 10, 2010.
  1. Nov 10, 2010 at 1:49 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r [OP] Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    I am looking to put ProComp Series 98 black rock crawlers on my 2000 tacoma. Im running 31x10.5r15 all terrains on stock 15x7's right now with no fender flares. I want my tires to stick out of the wheelwells more and am not sure what backspacing to go with. I was recommended 3.75" but figured I would try and get more opinions. Also there will be a daystar 2.5" strut spacer leveling kit soon to come.
  2. Nov 10, 2010 at 2:01 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    i don't know what the requirements are for a 2000 with a 3.75 and a 8" rim it should stick out a bit. What's the offset on the new wheels.
  3. Nov 10, 2010 at 2:02 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    couldnt tell you. it only gives me backspacing on the website
  4. Nov 10, 2010 at 2:09 PM
    JLee
    Jerry
    Benicia, CA
    Okay i found this on the Summit website
    with a -19mm offset they should stick out. I'm sure the stock wheels are 0 offset.
    Wheel Diameter 15 in.
    Wheel Width (in) 8.000 in.
    Wheel Material Steel
    Primary Wheel Color Black
    Wheel Finish Gloss
    Manufacturers Wheel Series Pro Comp Xtreme Rock Crawler 98 Series
    Backspacing (in) 3.750 in.
    Offset -19.00mm
    Wheel Construction 2-piece
    Beadlock Included No
    Beadlock Functional No
    Lug Nut Seat Style Conical seat - 60 degree
    Hub Centric No
    Center Bore Diameter (mm) 108.00mm
    Center Cap Included No
    Load Rating (lbs) 1,600 lbs.
    Valve Stems Included No
    Quantity Sold individually.​
  5. Nov 10, 2010 at 2:11 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    okay thanks for the help
  6. Nov 10, 2010 at 8:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Stock 1st gen wheels (15x7 on a 2000) have +15 mm offset. A wheel that has -19 mm offset would stick 34 mm (~1.33") further out than the stock wheel.
    IMO If you now have no fender flares an 8" wide wheel with 4.5" of backspacing (0 mm offset) would look very good and not stick out toooooo much.
  7. Nov 10, 2010 at 8:55 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    thanks. im just tryin to get about an inch more out of the wheelwell
  8. Nov 10, 2010 at 11:06 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    im goin to be running a stock front set up for a couple months. would 3.5 bs stick out too much. cus im goin to put a 2.5" leveling kit on it
  9. Nov 11, 2010 at 3:55 AM
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    Im running those same rims on my 99 tacoma and they do stick out about an inch or two. I have no problems with my truck and these rims even though I have heard of some guys having to grind down their calipers to run these rims.
  10. Nov 11, 2010 at 8:54 AM
    Digiratus
    Roaming the PNW
    The RedHead
    IIRC the caliper fitment issues are limited to the '01 thru '04 trucks.
    In 2001 Toyota started using larger, 16" wheels. I think it was because they also started using larger calipers on those models.
  11. Nov 11, 2010 at 12:01 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    what size backspace are you running?
  12. Nov 11, 2010 at 2:27 PM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    2004 PreRunner Xtra Cab
    STOCK
    1. Call summit and tell them you want a 15" wheel on an 01-04 toyota tacoma. They are going to tell you that a 15" wheel straight up wont fit. ( which is BS )
    2. Order Wheelers wheels. They are a TW sponsor and just totally kick ass. when mine showed up, low and behold they were in pro comp rock crawler boxes. ( as that would appear to be the manu of the wheels. ) Skip the center caps and just hit the hubs with a little bit of black high temp spray paint or something.
    i went with the black type B's 4" BS on my 03 xtracab pre runner. my 31x10.5R15 Yokohama geolanders rub slightly on the pinch weld and on certain inclines up driveways. Im running stock suspension/height.
  13. Nov 11, 2010 at 2:56 PM
    99yodataco
    Chad
    Soon...
    15x8 with 3.75" backspacing
  14. Nov 11, 2010 at 6:55 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    your truck is clean
  15. Nov 11, 2010 at 7:01 PM
    99yodataco
    Chad
    Soon...
