15x8 no mods???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stm82, Feb 24, 2017.
  1. Feb 24, 2017 at 11:30 AM
    Stm82
    Stm82 [OP] BRAAAPPP!!!
    Mb. Canada
    95.5 2.7 5 speed 4x4 reg cab
    33x12.5x15 Nitto Trail Grapplers on M/T 15×8 3.25" Bs 3" Toytech front Mystery add a leaf back with random shocks Bush whacker cutout flares (extra firewall smash) Side dump exhaust Washer fluid relocate 91 (or so) bucket seats and console Twin stick transfer case Toyota elocker
    Hey to all I'm new! I have been looking on here for hours and haven't gotten a clear answer. I'm looking for a 15x8 steel wheels that will clear calipers fit studs with no mods or spacers. if you have pics and part#'s would be best. i have 33 12.5 15 tires going on them so 3.75 BS min with some rub but thats not what im worried about. just looking for wheels that bolt up and done.
    thanks.
    ChadsPride likes this.
  2. Feb 24, 2017 at 11:31 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    subd for answers​
  3. Feb 24, 2017 at 12:25 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Yes they will fit fine, the tires will most likely rub though...
    MtRSQ and ChadsPride like this.
  4. Feb 24, 2017 at 12:26 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    How come? Just to add to the knowledge bank?
    ChadsPride[QUOTED] likes this.
  5. Feb 24, 2017 at 12:26 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Mine have 3.5" back spacing if you're wondering.
  6. Feb 24, 2017 at 12:29 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
  7. Feb 24, 2017 at 12:32 PM
    ChadsPride
    Yes sir!!!
    the moar ya knoe!
    :wink:
  8. Feb 24, 2017 at 1:26 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    with a 15x8 and 3.75'' BS the tire will rub the frame at full steering lock. you'll clear the UCA fine. And yes you will need to trimm and hammer the hell out of the fender well and pinch weld area.
    as for wheels that just bolt on..that is harder to anwser. Most wheels out there rub the calipers a bit. Wheelers used to make 15'' steelies that cleared everything. But not anymore. Most D window wheels the D punch outs rub the calipers. Can either run spacers or grind the caliper down. I ground down my calipers.
    MtRSQ, DustStorm4x4 and ChadsPride like this.
  9. Feb 24, 2017 at 1:33 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Why would a 3.75 BS rub the frame when stock rims are 4.6 BS? I was planning on running SCS 16" with a 3.5 BS
  10. Feb 24, 2017 at 1:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    backspacing is different for every wheel width. stock is 7.5'' wide. And if you stuffed a 33x12.5 tire on that you will rub on the UCA and the Frame.
    A 15x8 is wider so you gain 1/4'' right there. plus a 3.75 vs a 4.5'' is a huge difference.
    If you're running an SCS 16 3.5'' BS you'll be fine with a 285 or even 295.
  11. Feb 24, 2017 at 2:12 PM
    Stm82
    Mb. Canada
    thanks for the advice might go with 3.5 or 3.25 BS hopefully clear the frame rub. I called pro comp and the require shims or caliper grinding. has anyone tried to cut a larger center out of a Chevy rally so they fit? they are the right bolt pattern but wrong bore diameter.
  12. Feb 24, 2017 at 4:02 PM
    smmarine
    Melbourne FL
    Ah that's right, I forgot he was running 12.5. My plans are 285s or 255s
  13. Feb 24, 2017 at 4:51 PM
    JAMES399
    JAMES399 EL CAPO
    JAMES
    Alejandria Antioquia Colombia S.A.
    White 2003 Hilux DCSB 4x4 HI-RIDER +. 2.4L I-4, 5 spd.
    275/70R16 tires, gasolina or CNG fuel, Konig shox, Energy Suspension poly bushings,
    American Racing used to make 8" steel rims with 3.75 backspacing for Toyotas. I had a set on my 87 4x4 pickup. Bought them at Discount tire in Anaheim. But this was "back then" of course.
  14. Feb 24, 2017 at 8:14 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I have run both the 8 and 10 inch wide wheel. The 8 had a 3.75bs with no rub on frame. My 10s (4 inch bs) just started rubbing on one side after i installed my uca's....either way, you wont be disappointed. ...bust out the bfh
  15. Feb 24, 2017 at 8:36 PM
    Stm82
    Mb. Canada
    I think I wasn't super clear but I'm not worried about tire rub it's almost impossible to avoid with that size of tires. the rim fitment around the caliper as I don't want to take a grinder to my calipers and do not like the idea of spacers / shims. I believe it is the dish of the "spokes" on most steel rims that will grind on the calipers.
  16. Feb 24, 2017 at 8:43 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    I really wanted steelies too. Couldn't find any that fit without spacers or grinding the caliper. I settled for alloy but bought the warranty that 4wp offers (they get too damaged to mount a tire on and I get a replacement)
  17. Feb 24, 2017 at 8:59 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    FJ steelies work.
    https://www.tacomaworld.com/threads/show-off-your-steel-wheels.467479/
    There are a couple different kinds in this thread. ^
  18. Feb 24, 2017 at 9:32 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    1\4 spacers up front and u are good
    ChadsPride and DustStorm4x4 like this.
  19. Feb 25, 2017 at 6:24 AM
    Stm82
    Mb. Canada
    I'm fairly decent on a tire machine but I don't think my 15's are going to slide on to some 17's haha cool that they work though.
    I have 1/4 shims and studs on order. not a big fan but I'm going to try and fit the Chevy rally rims I have lying around. still would buy a wheel that would bolt on direct though.
  20. Feb 25, 2017 at 9:01 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Oops my bad, I didn't realize you already had the tires. I was just thinking you could put the 17" steelies on and adjust the tire size accordingly.
