'16-'18 Front Differential Cyclical Groaning/Grinding Noise TSB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaDriver631, Feb 6, 2018.
  1. Feb 6, 2018 at 10:53 AM
    Brenden J
    Brenden J Well-Known Member
    Brenden
    2016 Tacoma TRD sport
    Are there any bulletins for the needle bearing?
  2. Feb 6, 2018 at 12:58 PM
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    Former 3G Tacoma owner
    It is a complete front differential replacement. Read the first post with the TSB.
  3. Feb 6, 2018 at 1:41 PM
    sig916
    sig916 Well-Known Member
    Well, how do I make my front diff to have a that grinding noise???
  4. Feb 6, 2018 at 1:45 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Why would you want to make your truck have a problem???
    dYL0n likes this.
  5. Feb 6, 2018 at 1:48 PM
    Scotty Dosent Know
    Scotty Dosent Know Well-Known Member
    2017 Tacoma DCSB
    My Toyota dealer put the ecgs bushing in mine, pretty reasonable as well.
  6. Feb 6, 2018 at 1:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You can't skimp on the details there! :thumbsup:
    It sounds like out of pocket? Where are you / your dealer?
  7. Feb 6, 2018 at 1:53 PM
    Scotty Dosent Know
    2017 Tacoma DCSB
    I had them do it when they installed my OME lift as a preventative measure. I believe they had one in stock as the dealer carries a lot of aftermarket stuff for our trucks. Michaels Toyota in Bellevue, great dealer to work with.
  8. Feb 6, 2018 at 1:57 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    so replace the whole diff for a needle bearing?
    lmao
  9. Feb 6, 2018 at 1:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Excellent. And, local!
    I will keep that in mind. I got mine at Rodland. I was only in the service department once for a quick wash. They seemed to only have Toyota stuff on display.
    TheToyotaGarage likes this.
  10. Feb 6, 2018 at 2:04 PM
    Scotty Dosent Know
    2017 Tacoma DCSB
    Yeah they have all kinds of aftermarket stuff, Toytec lifts, SCS wheels etc. If you have IG follow "thetoyotagarage"
    tonered[QUOTED] likes this.
  11. Feb 6, 2018 at 2:10 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very cool. I might stop in since I work not far away.
    No. I've given up on social media. It is a beautiful thing to see a blank FB feed. o_O
  12. Feb 6, 2018 at 4:21 PM
    sig916
    Because "It is a complete front differential replacement. Read the first post with the TSB."
    Meaning i probably wouldn't have to worry about future problem (after warranty ).
  13. Feb 6, 2018 at 4:24 PM
    sig916
    Nvm bro, I read it wrong. I was reading too fast and thought dude meant completely different diff. LoL
  14. Feb 6, 2018 at 4:29 PM
    Lt. Dangle
    Ohio
    Yeah, I can read. Still not sure I agree with your thought process. No, wait... I'm sure.
    You have a 60k mile drivetrain warranty, also this is no guarantee that that new diff fixes the issue (which you don't even have). What's the new part Toyota is putting in?
    tonered and sig916[QUOTED] like this.
  15. Feb 6, 2018 at 4:31 PM
    #35
    Lt. Dangle
    Ohio
    I'm completely lost now lol.
  16. Feb 6, 2018 at 5:39 PM
    #36
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    This is a good sign, Toyota may have fixed the problem correctly by machining the side gear and making it right in the housing and taking that slop of the axle which is the problem to begin with. The axle slides into the side gear and it has so much play in there that it wears out the needle bearing very quick that’s why the bushing replacement works so great because it keeps the axle stable doesn’t allow it to move around. My2017 got this issue immediately after I did a 1 inch lift in the front. I bought the bushing and took it all apart and I could totally see what the problem is and hopefully Toyota fixed it
    YotaDriver631[OP] likes this.
  17. Feb 6, 2018 at 5:51 PM
    #37
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is a lot of assumption going on.
    Thankfully, mine is in the very early stages. Hopefully, folks will report what is going on with this.
  18. Feb 6, 2018 at 5:53 PM
    #38
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
  19. Feb 6, 2018 at 8:16 PM
    #39
    Hiluxski
    Ventura California
    Yes, but let me explain I feel that must be something pretty big if you’re changing that whole front differential if it was just a bushing or new needle bearing or redesign needle bearing or something they wouldn’t be changing out the whole third number it has to be something internal and if they did fix the side gear/housing that would explain why they have to change the whole differential. Just a thought
  20. Feb 6, 2018 at 9:22 PM
    #40
    Baerskin
    Baerskin Rocking in the Free World
    Manitoba
    TRD Sport Premium 4x4
    Stock
    Following
