'16-'18 Front Differential Cyclical Groaning/Grinding Noise TSB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaDriver631, Feb 6, 2018.
  1. Feb 6, 2018 at 9:24 PM
    #41
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Damn, this is a very simple TSB.
    Is a sound present? Yes? Replace front differential.
  2. Feb 6, 2018 at 9:51 PM
    #42
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    How many miles are people starting to see this problem?? I have about 4,000 on my 17’. Just curious. I had the same issue with my 08 Tundra as far as the cyclical vibration. I replaced needle bearing on that with the ecgs bushing and totally eliminated the problem.
    lpfe42 likes this.
  3. Feb 6, 2018 at 10:08 PM
    #43
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    Is there a VIN range for this? Just scheduled a front locker install...
  4. Feb 6, 2018 at 11:20 PM
    #44
    sig916
    sig916 Well-Known Member
    I have 15k on mine with 2.5 + lift haven't exp this problem.
  5. Feb 7, 2018 at 6:21 AM
    #45
    Brenden J
    Brenden J Well-Known Member
    Brenden
    2016 Tacoma TRD sport
    I am going to the Toyota dealership tomorrow after work to get the needle bearing done as well as bring up the front diff replacement. I will keep everyone posted about what happens.
    lpfe42 and sig916 like this.
  6. Feb 7, 2018 at 6:25 AM
    #46
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    Toyota of Olympia did mine. Knew exactly what the issues were and had the part in stock.
    tonered likes this.
  7. Feb 7, 2018 at 8:03 AM
    #47
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    jezus a whole diff for all of a 60 dollar part.
    I wouldnt want toyota touching my whole front driveline. FYI the TSB (different than this) for the new needle bearing part is still a shitty needle bearing.
    Just do it right the first time, if you have the front diff noise, ECGS needle bearing and call it good. Bout and hour of time with the right tools. Had mine in for 60k vibe free miles.
    tonered likes this.
  8. Feb 7, 2018 at 8:11 AM
    #48
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Why would Toyota start changing the whole front diff for just that needle bearing? They haven’t done that in the past they just change the needle bearing. There’s something a lot more going on here than just a needle bearing change
  9. Feb 7, 2018 at 8:19 AM
    #49
    Malibu7tss
    Malibu7tss Can' t think of anything to type here right now.
    Central pa.
    2016 trd sport dcsb 4x4 bbp 6spd manual
    Old man emu with 888's and headstrong off road progressive aal, trd pro wheel, Cooper Stt Pros 285/70r17
    I just looked up the part # it is $2089.00.....so I'm going to say it is definitely the whole diff assembly.
  10. Feb 7, 2018 at 9:01 AM
    #50
    Brenden J
    Brenden
    I was told the new needle bearing is a different part number than the old one so is it the same part? Or do you think the new diff and new needle bearing are designed in a way that you wont need the ECGS bushing fix?
  11. Feb 7, 2018 at 9:55 AM
    #51
    nd4spdbh
    SoCal
    Id be willing to bet its because so many techs were messing up the needle bearing / seal replacement of the original TSB from back in the 2nd gen days (because if you dont pay attention you can make it so things leak real easy) so they just said eff it we are shipping them a fully assembled diff. i HIGHLY HIGHLY doubt they did anything internal to change things other than the updated TSB needle bearing of the past.
    Its the same exact principal as to why they replace a full rear driveshaft for u joint failures, because they dont trust their techs to do it proper / dont supply dealerships with driveshaft balancing machines if a tech put it back together 180* off.
    the new needle bearing is a different part number with slightly tighter tolerances / different specs. That stated, the ECGS bushing is still superior, its longer which is the biggest thing to support that front CV cup properly.
    Seriously guys, save yourself the hassle of dealing with the dealership and just do it right the first time if you have the issue.
    Harley08 and tonered like this.
  12. Feb 7, 2018 at 10:33 AM
    #52
    Furball
    Furball Well-Known Member
    Minnesota
    2017 TRD Off Road
    following
  13. Feb 7, 2018 at 1:44 PM
    #53
    Hiluxski
    Ventura California
    I would not encourage anybody to do it themselves until we know for sure what’s happening with this new replacement third member. Everybody has an opinion but nobody has been proven correct yet so we’re all still guessing at this point. Having said that I did the bushing on mine and I’m going to be pissed if it’s a nice new updated third member that I will not be able to get now
  14. Feb 7, 2018 at 2:23 PM
    #54
    sig916
    Agreed. Dont do it and let toyota replace ur front diff. It'll make them source something out and get this fix once and for all.:fingerscrossed:
    lpfe42 likes this.
  15. Feb 7, 2018 at 2:28 PM
    #55
    Iamraiderpower
    Iamraiderpower Well-Known Member
    I wonder if this will ever become applicable to the 5th Gen T4R
  16. Feb 7, 2018 at 2:36 PM
    #56
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    No problems, just curious.
  17. Feb 7, 2018 at 7:35 PM
    #57
    nd4spdbh
    SoCal
    to each their own. I hate letting toyota tech scum touch my truck especially in this case when you KNOW for 100% certainty that an ECGS bushing will fix the issue.
    Lets see. Coordinate someone to follow you to toyota dealership, drop your truck off, leave it with unknown people all day, get a ride back to dealership (assuming they finished a full diff replacement in a day)... to possibly have the issue fixed? I am 100% positive that they are not using a longer needle bearing or a bushing for the driver side CV. So why even bother with a fix that may or may not solve the issue.
    60 bucks, an hour or two in your garage and a 6 pack of beer for a 100% fix seems like a lot better fix than a maybe.
  18. Feb 8, 2018 at 2:09 PM
    #58
    Baerskin
    Baerskin Rocking in the Free World
    Manitoba
    TRD Sport Premium 4x4
    Stock
    You know you’ll need at least a 12 of beer ;)
  19. Feb 8, 2018 at 3:09 PM
    #59
    nd4spdbh
    SoCal
    I mean, if we want the job to get done quick. 1. beer before while gathering tools. 1 beer during. then the rest after. haha. I actually made a puller tool that worked baller. Didnt even have to replace the seal, and its been 60ish k miles without issue.
    tonered likes this.
  20. Feb 9, 2018 at 5:16 AM
    #60
    Malibu7tss
    Central pa.
    So I'm going to give it a shot. Test drove with manager and verified vibration. Scheduled for replacement Wednesday.
    lpfe42 and tonered like this.
