16" AR Fuels on Sport?
Discussion in 'Wheels & Tires' started by Panther, Aug 16, 2011.
  1. Aug 16, 2011 at 9:20 AM
    Panther
    Panther [OP] Well-Known Member
    Kaiden
    BH, ME & BOS, MA
    2021 TRD Sport DCLB
    OEM lift. Ditch lights
    I know some of you hate me for asking. I used the search, but just wanted to double check. I think I've seen some guys using 16" American Racing Fuel wheels on the Sport Tacos, and I was wondering if they actually fit? I understand the calipers on the sport are a little big, and I'm not sure if the pictures I saw were trucks that just had the hood scoop or were actually the Sport.
    I found some on Craigslist for a good deal, and would like to buy them, but don't want to end up grinding my caliper (or wheel). Anyone run this rim on their Sport?
    Thanks in advance, and sorry too.
  2. Aug 16, 2011 at 9:36 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Didn't think it was that simple... I thought certain 16" rims will hit the caliper :confused: I think one of the countersteers maybe?
  3. Aug 16, 2011 at 9:46 AM
    Pugga
    Massachusetts
    I believe it's the inside diameter that causes it. KPT will have to weigh in but I believe some of the 16" rims are tighter inside than the TRD OR or stock steel rims. There's one in particular that is a 16" rim that does not fit the 2nd gen without modification.
  4. Aug 16, 2011 at 9:48 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    You could try to test fit them before you buy them. BTW mine are 6 years old now and are holding up great. My only issue with them is the center caps which were rusty garbage. I ditched them after about 6 months and honestly they look tons better without them.
  5. Aug 16, 2011 at 12:51 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Correct.
    Correct again. There are actually several brands of wheeels that don't fit in the 16" version, most notably the pro comp rock crawlers, and anything made by Cragar.
