'16 fogs ON with high beams.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by caribe makaira, Sep 20, 2016.
  1. Sep 21, 2016 at 4:11 AM
    RHelton10
    RHelton10 Well-Known Member
    Atlanta, GA
    '16 DCLB MGM TRD Sport 4x4
    Predator bars, Revolver X2 tonneau cover, SwingCase tool box, Husky mats, HID conversion Fuel vapor 17” wheels, 2” front /1” rear lift with Bilstein 5100’s, 285/70R17 Nitto grappler 2’s
    Dude check the attitude. He's trying to help out members like me that want the extra light for off-roading or for driving in rural areas. When approaching oncoming traffic the high beams are turned off leaving the normal setup of low beams and fog lights. So how is this being a dick?
    gsubioguy, IronPeak and arnette64 like this.
  2. Sep 21, 2016 at 5:51 AM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I turn on fogs whenever I need the fogs. It's not a dick move anymore than using daytime running lights during the day or headlights at night.
    This guy needs to cool his tits.
    Persnickety likes this.
  3. Sep 21, 2016 at 5:59 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Why not install a light bar for night-time off-roading? Much better light.
  4. Sep 21, 2016 at 6:01 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Cool idea.
  5. Sep 21, 2016 at 10:44 AM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Cost vs zero cost, factory look vs aftermarket. No new switches vs new switches. Less time vs time.
    swordfish and arnette64 like this.
  6. Sep 21, 2016 at 3:36 PM
    Truggin
    Don
    More light versus less light...
    Tastes great versus less filling...
  7. Sep 21, 2016 at 6:32 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Not sure I understand the new trend of turning on fog lights only and not headlights but there are a lot of things I do not understand. I see several vehicles every day doing this.
  8. Sep 21, 2016 at 6:46 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Dearest, @caribe makaira , the kindest of gentleman...
    Would you have any insight into a/the Locker-Anytime modification for the 2016-2017 Off Road 4x4 model?
    We, as a community, would be ever grateful for any help or assistance in this matter.
    Lost In The Woods likes this.
  9. Sep 21, 2016 at 8:08 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    It would be....complicated, internal 4WD ECU interlocks aside.
    The 4WD ECU converts the switched ground from the locker switch, to a pulsed waveform power circuit used by the diff lock coil.
    This makes simply bypassing the 4WD ECU a no-go.
    You could probably source a pulse generator circuit with the correct voltage and wave form to get around it.
  10. Sep 21, 2016 at 8:16 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    So can he help us? Has he already looked at it?
  11. Sep 21, 2016 at 9:29 PM
    splitbolt
    NW Arkansas
    I don't know... I'll let him speak for himself.
    I was just trying to provide some insight. ;)
    Pulse duty solenoids generate large forces for a short time, but heat quickly.
    This is one reason for not running your locker for extended periods.
    It's probably why ARB uses air to actuate theirs.
    Sourcing the correct power supply with a 12V input and 5V/500ms output is the biggest hurdle I've encountered.
  12. Sep 21, 2016 at 9:34 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    I knew of the control module that was stopping us but I didn't know what was actually happening.
    I have a friend in 2 wheel drive 2016 off road who uses his locker for long periods of time. His is fine
  13. Sep 21, 2016 at 9:44 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    o_O Sooooooooooo I need a flux capacitor?
    2016_dbag likes this.
  14. Sep 21, 2016 at 9:46 PM
    splitbolt
    NW Arkansas
    I should have said "comparatively speaking", when describing and comparing a pulsed duty solenoid.
    Out of curiosity, how fast and how long does your friend drive with the diff locked.
  15. Sep 21, 2016 at 10:03 PM
    #35
    Z50king
    Eric
    Southern California
    Stock and loving it
    @odinsbro15
  16. Sep 21, 2016 at 10:39 PM
    #36
    splitbolt
    NW Arkansas
    Without knowing exactly what interlocks are present in the 4WD ECU, yes.
    Even then...
    Things like the ADD switch position and transfer case switch position are easy to fool the input side of the 4WD ECU into seeing. But, internal interlocks on the output for those things is a possibility.
    The real deal killer is possibly the skid control ECU data fed by CAN.
  17. Sep 22, 2016 at 3:49 AM
    #37
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    I thought GM schematics were bad, those suck. No wonder toyota techs can't fix anything.
    But it looks like you could just tie the coil grounds together on the fog light and high beam relays. Would bypass the fog light switch, but they would come on with high beams. And work normal in low beam.
  18. Sep 22, 2016 at 4:10 AM
    #38
    Outlier
    Outlier I get around...
    Dallas GA
    2016 Tacoma AC TRD OR 4x4 V6 Slushbox
    No BRO-ness to speak of... Well, except Kbro2's
  19. Sep 22, 2016 at 7:17 AM
    #39
    odinsbro15
    odinsbro15 Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    ive had the diff locked for a while (2 hrs or so) before disengaging to let it cool. durring that time ill go upward of 35mph
  20. Sep 22, 2016 at 11:05 AM
    #40
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I'm with you man...(if your fogs are OEM)... I've got Hyper Yellow and run them on the daytime with my DTRL's ...... I like the looks and everyone knows that's it Big Bad Me coming from a long way away...hehe..!!
    bobrown14 likes this.
