16 inch Method NV305
Discussion in 'Wheels & Tires' started by Moonsurfer47, Mar 15, 2023.
  1. Mar 15, 2023 at 9:36 PM
    Moonsurfer47
    Moonsurfer47 [OP] Member
    Jeremy
    Central Coast California
    2022 TRD DCSB 4X4 MGM
    Hi guys still new to the forums. I tried searching but haven’t found a clear answer. Im getting ready to purchase a set of Method NV 305s in 16 inch. I have a 2022 trd off road 4x4 on stock suspension. Im going to run stock tires (265 70r 16) and wanted to know if I will have any rubbing issues with my front mud flaps with the 0 offset?
    Thank you for your time
  2. Mar 16, 2023 at 1:47 AM
    flan2504
    flan2504 Active Member
    CO
    2017 TRD OR
    I have a 2017 OR and I started my wheel/tire journey by running 265/75/16 Duratracs on Method 305s. No rubbing or contact issues with the mud flaps back when I had stock suspension. I’ve since made some changes, but you should be good with stock tires.
    I’ll try to dig up some pictures for reference.
    Moonsurfer47[OP] likes this.
  3. Mar 16, 2023 at 7:22 AM
    Moonsurfer47
    Jeremy
    Thank you for the good info. Id love to see some pictures if you got em
  4. Mar 16, 2023 at 2:52 PM
    boricua41
    boricua41 Active Member
    I had 265/70/16 on the same rims. Just put 265/75/16 and no rubbing so far. Put a set of Falken wildpeaks a couple days ago. Put a ceramic coating on them if you can. I used one from Adams, This one Graphene Ceramic Spray Coating™ Advanced. And had it for a for about six months and they still shiny black.
  5. Mar 16, 2023 at 5:53 PM
    Moonsurfer47
    Jeremy
    Sounds good. Im glad you had no issues with rubbing on the mudflaps. I really want to keep them on to help reduce road rash from the tires. I will have to check into the ceramic coat. It will make cleaning them a breeze.
  6. Mar 22, 2023 at 2:06 PM
    SconnieTaco60
    SconnieTaco60 Well-Known Member
    2021 Tacoma TRD Off Road
    Stock
    I'm running 265/75r16s on my 21 TRD OR. Thinking of getting a set of Method 305 NV Double Blacks in 16x8" size. I also have a leveling kit on my Taco. Any concerns re: fitment I should have? I dont wanna go any bigger tire size, have to make any addt'l mods or have other suspension issues/failures. Your thoughts & suggestions are appreciated.
  7. Mar 22, 2023 at 4:25 PM
    boricua41
    I haven't had any issues with my Method's. Fitments is great. No concerns at all. I want to raise it 2in in fron and 1 in the back. And I will be happy.
  8. Mar 28, 2023 at 9:34 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Method is a solid choice used by many forum members. They have a great selection of styles and finishes.
    Menardo, TacoPacific and boricua41 like this.
  9. Jul 27, 2023 at 5:30 PM
    TacoPacific
    TacoPacific Just a Joe in a Taco
    Vancouver BC
    2021 Tacoma TRD OR DCSB
    Smartcap Evo Sport, Gar-FAB tailgate panel, TRD Performance Suspension/Lift
    What is the largest tire we can fit on this guy? Width and height? Not looking for a skinny specifically.
  10. Jul 27, 2023 at 6:09 PM
    boricua41
    Im running 265/75/16 and no rub, unless you take a path hole hard. I was running 265/70/16 before no rub at all.
    TacoPacific likes this.
  11. Jul 28, 2023 at 7:48 AM
    Discount Tire
    Arizona, USA
    265/75R-16 is the ticket; you can anticipate rubbing with anything larger. 255/85R-16 will likely result in rubbing as well.
  12. Aug 3, 2023 at 10:15 AM
    TacoPacific
    Vancouver BC
    And what can you tell me if i have a 2.5” lift? Still 265/75?
  13. Aug 3, 2023 at 12:09 PM
    Discount Tire
    Arizona, USA
    Even with the lift, 265/75R-16 due to the lower offset on the wheels.
    Think of your wheel wells as bowl shaped. It you push the wheels out, you are locating the wheel in a shallower part of your wheel well. This restricts how tall of a tire you can run.
    TacoPacific[QUOTED] likes this.
