16 inch pro wheels. Can’t decide 2017 or 2020 or 2022
Discussion in '3rd Gen. Tacomas (2016-2023)' started by radclerk1, Sep 26, 2021.
  1. May 5, 2022 at 3:36 PM
    #81
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Pure advertising BS.
  2. May 5, 2022 at 3:39 PM
    #82
    avn
    avn Well-Known Member
    A
    CA
    2022 TRD OR
    Maybe, who knows unless they’ve tested it themselves. I edited my prior post if you want to look.
  3. May 5, 2022 at 3:40 PM
    #83
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Most, if not all, 35" tires are recommended to be on 8"+ wide wheels by the tire OEMs
  4. May 5, 2022 at 3:43 PM
    #84
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    So .1% of Tacoma owners would benefit from the 8” wide wheel. Marketing BS
  5. May 5, 2022 at 3:43 PM
    #85
    avn
    A
    CA
    2022 TRD OR
    That’s what I found after a quick look online. It doesn’t sound like pure advertising bs to me if you’re looking to run 35s or larger.
    doublethebass[QUOTED] likes this.
  6. May 5, 2022 at 3:47 PM
    #86
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    The ignore button comes in pretty hand on here sometimes :thumbsup:
    jmferg likes this.
  7. May 5, 2022 at 3:54 PM
    #87
    avn
    A
    CA
    2022 TRD OR
    No need. I don’t know a lot but when people ask questions (even with a bit of attitude) about things I post it gives me a reason to go and try to find out myself. At the end of the day I know a bit more than I did when I woke up so I consider it a win.
  8. May 5, 2022 at 5:30 PM
    #88
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    Thanks. It will soon be in the hands of Costco, LOL.
  9. May 5, 2022 at 5:34 PM
    #89
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    I strongly suggest getting tires elsewhere. Costco tire center is run so horribly. Americas Tore will price match and their service is 100X better.
    Panchito V likes this.
  10. May 5, 2022 at 6:00 PM
    #90
    Tenricco
    Tenricco Well-Known Member
    Tommy
    2021 Tacoma SR DCSB
    Weather-tech mudflaps, 20% tint
    SEMAs
    MiTacoTRD likes this.
  11. May 5, 2022 at 7:08 PM
    #91
    JWestie
    I might just pick up the tires from Costco and have them mounted and balanced with my local mechanic. Not sure I trust them with TPMS swap.
    Thegenerik1[QUOTED] likes this.
  12. May 5, 2022 at 8:30 PM
    #92
    Liv4Spd
    Liv4Spd Member
    22>20>17 imho
    Amorak and CaptainTikihut like this.
  13. May 9, 2022 at 3:01 PM
    #93
    JWestie
    Thanks. Ordered the '20 Pro wheels and shooting for Friday install if everything is in order.
  14. May 9, 2022 at 3:05 PM
    #94
    MAC07
    MAC07 Active Member
    Ind Hbr Bch, FL
    2021 DCSB OR
    Stock for now
    Pics when finished please
  15. May 11, 2022 at 11:42 PM
    #95
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    Any rubbing on this setup? Tire size, 265/70/17 ? TIA
  16. May 12, 2022 at 7:42 AM
    #96
    JWestie
    OK, I got my '20 Pro wheels and caps for install. What's the trick for the caps? Massaging them in?
    Edit: Wheels on and caps installed. Trick is to depress the cap so four of the clips are seated/nearly seated. I seated the bottom of the cap first. Then, carefully work clip #5 with index finger from the side until it just begins to slide under the lip of the wheel; but dont fully seat it. While holding clip 5 (partially seated) in place, use your other index finger to carefully depress clip #6 from the side with constant pressure. This one will be tougher, but with constant, gentle pressure it will seat, taking clip 5 with it. Once it seats it will suck the cap in and pinch your finger.
    mdywv likes this.
  17. May 13, 2022 at 8:29 PM
    #97
    curated
    curated Well-Known Member
    NY
    2022 TRD OR, 2001 TRD OR
    Definitely 2020
  18. May 13, 2022 at 10:45 PM
    #98
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the first thing i changed was those UGLY wheels - I went from 2022 OR wheels to 2019 PRO wheels with same sensors - with no problems - now chicks follow me all the time
    doublethebass and MiTacoTRD like this.
  19. May 14, 2022 at 7:21 AM
    #99
    JWestie
    OK, here you go. One thing I can say for sure: the new wheels are better matched to my Craig's List cap.
  20. May 15, 2022 at 4:52 AM
    #100
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Imagine how many chicks would follow you if you picked the good looking Pro wheels.
