16'' or 17'' !?!?!?!?
Discussion in 'Wheels & Tires' started by Quang, Jun 15, 2015.
  1. Jun 17, 2015 at 7:23 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    285s or 255s?
    Both are 33" tires.
    Looking good. I recommend extended brake lines in the rear at least if not all around. Longer bump stops all around too.
  2. Jun 17, 2015 at 7:24 AM
    geekhouse23
    Also if you flex, trimming will be required.
    Definitely have to remove the mudflats and trim at the back of the front fenders near the bottom by the mudflat mounts. Not much if it's on road but if you're flexing, it will be more.
  3. Jun 17, 2015 at 7:40 AM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    Looks like a dang good setup to me! I think you will be very happy. If you wheel hard you will have to trim quite a bit with 285s, I had to trim a bit and I don't "wheel" it. Like geek said, kiss your mudflaps goodbye.
  4. Jun 17, 2015 at 8:10 AM
    Quang
    Quang [OP] Austin is weird!
    quang
    PFLUGERVILLE/ Hutto
    2015 tacom trd off road
    OME 3” lifts OME Dakar leafs Allpro upper control arm Front and rear steel bumpers from relentless fab Some amazon light bar Allpro skid plate
    if I went 255 would I still need to trim? and bye bye mud flaps =D lol
