'16 Prerunner Rear Differential Lock help needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hydehunter, Oct 29, 2017.
  1. Oct 29, 2017 at 9:41 AM
    Hydehunter
    Hydehunter [OP] Member
    Jim
    '16 PreRunner TRD Offroad
    none-stock
    Hi, I'm a new member that needs some help. My PreRunner TRD Sport has the V6 + auto trans. My window sticker says the truck has a automatic limited slip differential + a locking rear differential. My truck does have the rear differential lock button in the overhead console. My problem is that nothing happens when I press that switch, no dash indicator lamp comes on. The only button in the overhead console that does anything is the Auto LSD switch. When I press it everything seems to work as the owner manual explains. So my question is: why am I not seeing a rear differential lock indicator in the dash when I press the button?? ( I've tried pressing it in both park + neu)
    Thanks for any information you can provide!
  2. Oct 29, 2017 at 9:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    From what I understand you have to be in 4LO for it to activate. You can try doing that on pavement, but make sure you stay in a straight line, and slow speeds.
  3. Oct 29, 2017 at 9:45 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Just to clarify, you have a trd sport with a rear diff lock? Did u add this aftermarket?
  4. Oct 29, 2017 at 9:51 AM
    Hydehunter
    Jim
    none-stock
    Yes My vehicle is a 2wd Prerunner, its stock I've added nothing. I just cant figure out what the console differential lock button does since I get no indicator light that its engaged or working.
  5. Oct 29, 2017 at 9:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Jim did you see my post above? Also if you double check the manual that'll tell you how to use it.
  6. Oct 29, 2017 at 9:55 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Could you send a picture or the diff lock button? A TRD Sport should not have a rear diff lock.
    Jukeboxx13 likes this.
  7. Oct 29, 2017 at 10:13 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Your post says, TRD Sport.
    Your avatar says, TRD Offroad.
    Which is it?
  8. Oct 29, 2017 at 10:29 AM
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    But is doesn't have 4lo?
    Or am I stupid?
    EatSleepTacos[QUOTED] likes this.
  9. Oct 29, 2017 at 10:34 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh duh. Totally missed the 2wd part. Don't judge me, I just woke up :rofl:
    Jukeboxx13[QUOTED] likes this.
  10. Oct 29, 2017 at 10:45 AM
    Hydehunter
    Jim
    none-stock
    My window sticker says this 2WD PreRunner has a locking rear differential, not sure how to upload photos to this site. My overhead console only has 2 switches, one is VSC SWITCH ( image of a vehicle with 2 curly tracks) and the other is a Rear Differential lock switch (image of 4 tires with a X over the rear axle) Hope this explains how my truck is equipped. [​IMG]
  11. Oct 29, 2017 at 10:47 AM
    Hydehunter
    Jim
    none-stock
    My manual says to just press the switch to activate it, the info is somewhat misleading.
  12. Oct 29, 2017 at 10:49 AM
    Hydehunter
    Jim
    none-stock
    One more thing to clarify, my truck is a TRD OffRoad 2WD
  13. Oct 29, 2017 at 10:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Hmmm, interesting. Have you tried it with the truck in the lowest gear?
  14. Oct 29, 2017 at 10:54 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Try holding it down for 3 to 5 seconds or turn off Trac control first then hold rear diff lock for 3 to 5 seconds.
    Thunder Fist and splitbolt like this.
  15. Oct 29, 2017 at 10:55 AM
    Murkules
    Murkules Well-Known Member
    Dane
    Hawaii
    2016 Tacoma TRD Offroad DCSB Super White
    Can you get a picture of your rear differential? It’ll look similar to this, although this picture is off a 1st gen from google.
  16. Oct 29, 2017 at 10:58 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Why? He said he has a diff lock button and that he's got an OR.
  17. Oct 29, 2017 at 11:00 AM
    Murkules
    Dane
    Hawaii
    Doesn’t hurt to look.
  18. Oct 29, 2017 at 11:05 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    if he doesnt have that set of gear actuator on his diff, he is not locked.
    curious on photos op
    Murkules likes this.
  19. Oct 29, 2017 at 12:32 PM
    splitbolt
    NW Arkansas
    Where are you looking for the indicator?
  20. Oct 29, 2017 at 12:43 PM
    Jukeboxx13
    California
    The rear locker is the symbol on the right? If that's what you have and it won't engage then try holding it down till the light comes on in the dash. The light will look exactly like the switch if my memory serves me.
    If that don t work id take it in for warranty.
    PvilleJohn likes this.
