16" Procomp 7089s and 265/75/16s
Discussion in 'Wheels & Tires' started by Future55, Dec 12, 2010.
  1. Dec 12, 2010 at 1:50 PM
    Future55
    Future55 [OP] Well-Known Member
    Oahu
    2010 4x4 DC TRD Sport
    Weathertech Mats, AFE Stage 2 SI Pro Dry S CAI, TRD Exhaust, Access LE w/ Pop'n lock, 17" XD Revolvers, 285/70/17 Duratracs
    I know there have been a few discussions on this wheel, but i just want to make sure the 16"s are good to go, and will clear the brake calipers.
    Just to clarify i need:
    16x8 6 on 5.5 bolt pattern. 4.5 BS
    Hub-centric: No
    And..265/75/16 Wrangler Duratracs will fit this wheel and run smoothly on a 2010 DCSB TRD Sport with stock suspension?
    One more thing, what lug-nuts do i need? And can they be found in black? Ive searched and always found different opinions and answers.
    Thanks for any help fellas. :)
  2. Dec 12, 2010 at 3:48 PM
    CanadianGuy
    CanadianGuy Well-Known Member
    Vancouver, BC
    08 Access Cab 4x4 TRD
    Pretty much the exact set up I am planning to buy this Christmas. They will clear the brakes but not 100% sure if it will run on stock suspension - I think so...I'm sure someone else knows for sure.
    Lug-nuts - I think you need to get the Gorilla E/T lug nuts to fit those wheels...don't think they are available in black from what I've heard. Hope this helps!
    EDIT: check this sticky out regarding the Gorilla lug nuts - http://www.tacomaworld.com/forum/wheels-tires/119883-wheel-studs-too-short-what-do.html
  3. Dec 12, 2010 at 4:40 PM
    SadManGrin
    SadManGrin Active Member
    I'm going with this setup as well, and I have the same questions.
    If someone with Procomp 7089's could chime in about what type of lug nuts worked best for their ride with no vibes or mounting problems.
    http://www.gorilla-auto.com/gorilla.tech.tips
    What kind of lug seats do the 7089's have?
    If there isn't enough thread sticking out of the wheel to grab onto, why would extended lug nuts help? Wouldn't you just have an extra long lug nut that's not biting in? Wouldn't switching out the studs themselves, be the correct way to mount wheels in this case (hunt4steve)? I just want to buy the extended threads and call it a day, but only if there aren't any problems down the line.
  4. Dec 12, 2010 at 4:57 PM
    SadManGrin
  5. Dec 12, 2010 at 5:57 PM
    CanadianGuy
    Vancouver, BC
    I think that we need the acorn style lugs.
    Changing out the wheel studs would definitely work, but I think buying E/T lugs will grab a few more threads and be safe to drive on. Wait for more responses though.....
  6. Dec 12, 2010 at 6:15 PM
    Future55
    Oahu
    Haha, this discussion about lugs is exactly what i mentioned in my OP. :D
    Someone with the 7089s with the best/correct lugs chime in!!!
  7. Dec 13, 2010 at 1:37 PM
    Future55
    Oahu
    bummmp, anybody wanna confirmation?
  8. Dec 13, 2010 at 4:17 PM
    Future55
    Oahu
    Also, are the duratracs in "C" good or should i go with "E"?
  9. Dec 13, 2010 at 4:24 PM
    BSPDX
    BSPDX Well-Known Member
    First off you do want hubcentric wheels... What is your towing going to be?? light towing load C's will be fine, if you're going to tow heavy and frequently I would roll load E's.
    Good Luck!
  10. Dec 13, 2010 at 4:28 PM
    Future55
    Oahu
    Im not gonna be towing anything really, at least right now and in the near future. I just want to make sure i do/get things right from the get go. I know i read a lot of guys with the tracs went with Cs but i just want to be sure. Thanks!
  11. Dec 13, 2010 at 4:35 PM
    rcfreak201
    rcfreak201 Well-Known Member
    i have those rims but i forgot wut type of lugs i got! i just know they are a pain in the ass because most wheel wrenches are too wide and wud scratch the rim so it took me a while to find a narrower wrench. sorry im not sure about the lugs tho
  12. Dec 16, 2010 at 4:14 PM
    Future55
    Oahu
  13. Dec 16, 2010 at 6:47 PM
    holeinone604
    holeinone604 Well-Known Member
    Vancouver, BC
    16' TRD Sport Black Crew Cab
    Just a heads up I received this response from a guy on here that is running these wheels on his 2nd Gen Taco... I too would like to do this set up but beware you may be in it deep for hidden $$$
    Originally Posted by holeinone604
    Hey just curious how are the 7089 16" wheels?
    I just got some Duratracs (265/75/16) mounted to my stock wheels. I'm looking at the 7089 and want to make sure there are no clearance issues with the calipers.
    Any tips on where to get the wheels, mount and balance done?
    I have an 09' access cab SR5 4x4 4L, V6 if it makes a difference.
    Thanks for your help.
    Hey man,
    I would NOT get these rims for that setup. I know guys have run this setup with no issues but you are taking a very big chance of something not working. There is very minimal clearance with the caliper and for some reason these rim/tire combo are hard to balance and took alot of weight which made mine not be able to clear the caliper. I tried 2 different sets of duratracs and they both had the same effect. I loved the look of this setup alot but i spent over $250 in balancing trying to make it work. hope this helps
  14. Dec 16, 2010 at 6:53 PM
    CanadianGuy
    Vancouver, BC
    Shit...I was just about to order this set up. How would adding a lot of weights to the tire make the wheel not clear the caliper?
    Anyone know of a similar looking wheel that has no problems?
  15. Dec 16, 2010 at 7:25 PM
    Future55
    Oahu
    Fuuuuu...How do you think 17s with the 265/75/16s would look?
