16" rims for '99 Tacoma - help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rdsacto, Jun 16, 2016.
  1. Jun 16, 2016 at 10:12 PM
    Rdsacto
    Rdsacto [OP] Member
    Need some new, bigger rims for my '99 Tacoma, base 2WD. It has 5 lug 14" factory rims. Thought I'd stick with Toyota rims and found some nice 2005 16" Toyota rims online, also 5 lug. But, the 16s are not off of a Tacoma. Do I need to worry about the bolt pattern or will any 5 lug Toyota rim fit my '99 Tacoma? Thanks,
  2. Jun 17, 2016 at 12:16 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    bolt pattern will work for most imports (5x114.3mm or 5x4.5in)
    what you have to worry about is the hub size. the 1st Gen has a larger hub size than most '03+ cars and is larger than the 2nd Gen hub.
