16" spare with 17" wheels
Discussion in 'Wheels & Tires' started by lastcall190, Jun 12, 2025.
  1. Jun 12, 2025 at 6:03 AM
    lastcall190
    lastcall190 [OP] Well-Known Member
    NJ
    2023 Silver DCSB TRDOR
    Truck in question: 2023 TRD OR with 265/70/16 tires on stock wheels presently
    I found some tires I want to get for my 17" T4R wheels but don't have a FIFTH version of the wheel.
    Does anyone have 265/70/17 tires while having a 265/75/16 spare? They are damn close in overall diameter, and I'm just thinking in terms of in a pinch if I need the spare I don't want the sizes TOO different so as to muck anything up.
    Appreciate the feedback, thanks.
    -J
  2. Jun 12, 2025 at 6:09 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's fine.
    Tire calculator shows what you seem to know already re dia closeness
    I run a 235 75 15 on ground and 215 75 15 spare
    I'm more concerned about the spare rotting before needing it :anonymous:
    lastcall190[OP] likes this.
  3. Jun 12, 2025 at 6:17 AM
    lastcall190
    NJ
    Thank you for the feedback
  4. Jun 12, 2025 at 6:26 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    just make sure the 16” clears the brakes in front.
  5. Jun 12, 2025 at 6:42 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Those tires are essentially identical, that would be a perfect match for a spare. Just like how stock Sport from 2020 and on gives you a 265/70R16 even though the stock tire size is 265/65R17. They are equivalent.
    Beyond that, you don’t even need them to be that close. You could easily run an inch or two difference in diameter and the diff will make up for it.
  6. Jun 12, 2025 at 6:53 AM
    lastcall190
    NJ
    Thanks all!
