16 sr5 crankshaft sensor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jws6295, Mar 26, 2021.
  1. Mar 26, 2021 at 7:20 PM
    jws6295
    jws6295 [OP] Well-Known Member
    Central PA
    2016 SR5 double cab long bed
    Sure this has been discussed many many times. But I have a 7/16 sr5 3.5 engine. Not included in the recall. How many of you have replaced your crank sensor as a preventive measure? I do drive a good bit and mine hasn’t gave me any fits yet.. just under 40k miles on the odometer. I can replace the sensor myself. Just curious who has done this? Is there really a difference in the sensors? It seems to me the issue is the coating on the gear that the sensor reads and not the sensor itself? I’m assuming if mine isn’t in the recall I should be okay? It’s just weird how some vins are included some aren’t and they all fall in the same production dates?
  2. Mar 26, 2021 at 7:43 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    The only issue if you do this is you may get the same exact one. Is there an updated part number for the CPS they're putting in the recalled trucks?
    Skydvrr and jws6295[QUOTED][OP] like this.
  3. Mar 26, 2021 at 8:11 PM
    jws6295
    Central PA
    Not 100% sure. I do see they have an updated number.. 90919-05089. I just don’t understand what’s different about it. I guess that’s the number to look for. I’m wondering if they’re maybe made out of some different materials internally? To help with that coating flaking Off? Wonder if theirs any toyota techs on here that could chime in?
    Grossomotto[QUOTED] likes this.
  4. Mar 26, 2021 at 8:24 PM
    Grossomotto
    2017 4WDV6LB6MT
    Here's an old thread on it, quite a bit of info. The new part number is 90919-05098 and more info to tell if you have the old or newer version
    Old sensor has these numbers printed on it "0971 02U28"
    New sensor has these numbers printed on it "0972 06U20"
    https://www.tacomaworld.com/threads/diy-check-replace-your-cps-sensor.497659/
  5. Mar 26, 2021 at 8:31 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    @Jeff Lange any insight on part numbers / iterations?
    Imo, if she didn't shit the bed yet, she's probably good. Or buy a new one and keep it in the truck w you
    jws6295[OP] and shakerhood like this.
  6. Mar 26, 2021 at 8:39 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    90919-05089 is the original sensor, it is no longer listed for the Tacoma. The parts catalog has been updated to 90919-05098, which is the current sensor being used.
    A dealer wouldn't even look up the original sensor, which is still available, but not used for the Tacoma.
    Jeff
    MOC221_, Skydvrr, Grossomotto and 2 others like this.
  7. Mar 27, 2021 at 4:05 AM
    jws6295
    Central PA
    Thanks everyone for the responses! Might just play the route of having one just as a spare. Just weird why not all the trucks are included in the recall. That’s what I’m most curious about.
    MOC221_ likes this.
  8. Mar 27, 2021 at 4:29 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    My first 3rd gen was an early 2016, built in Sep of 2015 (IIRC). I thought for sure I would be on the list for the CKP recall, but nope. I asked the dealer to find out the exact date of manufacture, and as it turned out, my truck/engine was built... too early. Yeah.. and then I went and bought/installed the updated sensor anyway. I still have that old one around somewhere lol
    Grossomotto likes this.
  9. Mar 27, 2021 at 5:55 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    jws6295[OP], MOC221_ and Grossomotto like this.
  10. Mar 27, 2021 at 7:56 AM
    jws6295
    Central PA
  11. Mar 27, 2021 at 8:02 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    The best and easy way I’ve found to remove the connector is to take a pair of pliers, and cover the jaws with tape, or rag over the rubber boot so as not to rip or damage rubber and just gently but firmly press down on the boot with the pliers to release clip lock while pulling back.
    Once the clip is pushed down it will release and come off easy. And whatever you do, just don’t force it back. Easy peaches
