16" steel rims vs the alloys
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fletcher007, Oct 1, 2009.
  1. Oct 1, 2009 at 9:58 PM
    Fletcher007
    Fletcher007 [OP] Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed.
    quick question. What is the weight difference between the 16" base 4x4 rims and the 16" alloys. also will the tpms sensors off the steel rims fit on the alloy rims. Finally, if the don't fit can i just roll without them?.....is the tpms light easy to disengage. Thanks
  2. Oct 1, 2009 at 10:06 PM
    willmhobbs
    willmhobbs 50Tacoma
    Will
    Corpus Christi, Texas
    2008 Toyota Tacoma Prerunner 4X2
    3in Lift 17 inch Pro Comp Xtreme Rims. Tires BF Goodrinch All Terrain 265/70 Undercoating Lift kit done by dealer services international
    id go with the 16''...
  3. Oct 2, 2009 at 5:42 AM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    what year is your truck?
    with my 09, the steel wheels are heaver than the alloy wheels.
    the sensors in my steel wheels would not fit on my allow wheels.
    I put the sensors in a wheel barrow tire and aired it up to 32psi and that fixed my sensor problem on the dash. Have not had it light up since the wheel barrow fix.
    do a search on here for TPMS and you will find out how to disable it to some degree. there are several fixes.
    You might have a sensor in your spare tire ...depending on the model of your truck...so always let us know what year and type of truck you are talking about and we will try to help.
    welcome to the forum.
  4. Oct 2, 2009 at 8:07 AM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    I found a set of TRD off road wheels with tires, sensors, and lugs for $720 on Craigslist. They had about 500 miles on them. Next I paid $45 at Toyota to re-scan the new sensors. I then sold my stock steel wheels and tires with the old sensors still in them on Craigslist for $350. So for $415 I got the stock TRD wheels that I wanted.
  5. Oct 2, 2009 at 9:25 PM
    Fletcher007
    Fletch
    Phoenix,AZ
    mine is an 09 base 4x4.....how do i disable the tpms light or should i just put the wheel barrel tire in the bed and cal it a day?
  6. Oct 2, 2009 at 9:38 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^Either that or black tape over the dash light. You can get a small enough wheel/tire to fit behind the rear seat, though.
