16 Taco Off Road Mod Time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rfilmalter, Apr 3, 2017.
  1. Apr 3, 2017 at 11:00 AM
    rfilmalter
    rfilmalter [OP] Member
    2016 white Tacoma TRD OFF Road
    None
    Hi All
    I am pretty new to the forum in terms of posting. I have been reading for a while on all the issues with some of the tacos as well as the upgrades some have done to the truck.
    I am lucky so far with the truck (She was assembled in US). She has about 13k miles on it and the only issue I am experiencing is the "ABS" brake feel when you stop.
    I hope I don't get flamed, because there are tons and tons of info on the forums. I have about 5k to spend on wheels, tires, suspension.
    I am wondering if there is anyone out there that did everything at once and what did you go for with that budget in mind.
    I appreciate any feedback.
    JTM1 likes this.
  2. Apr 3, 2017 at 11:03 AM
    GIANTSteps
    GIANTSteps Well-Known Member
    Brandon
    Reno
    2017 Tacoma TRD Off Road Access Cab
    Added SnugTop cap and KO2's
    Your wheels and suspension are fine. Upgrade your tires, put together a nice recovery kit, and spend the leftover $4k on your first 10 payments. If you must have wheels, get what YOU like.
    QuicksandTaco likes this.
  3. Apr 3, 2017 at 11:13 AM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    Get your truck fixed first!! No dealership is going to look at your brakes the moment you lift it.
    Don't do tires and suspension same day. Cause I'm going to guess you're not the guy to be installing it yourself, it's safer to do lift on Sunday, tires on Saturday to be a 100% on the work that's been done to your truck.
    No point asking for lift advice without listing what terrain you want to drive and how fast or slow you want to go over it.
    Btw you're better off investing your money to give you a return on investment. I hear dominos pizza is doing Great these days! -the only real advise you'll get that's helpful. Everyone else will take your money and sell you icon stage stupid.
    Start small - get stuck - learn - improve.
    Or OME - Sliders - tires - front skid aftermarket. Solves 99% of real requirement.
  4. Apr 3, 2017 at 11:14 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Are you wanting cosmetic mod suggestions?
    I like those Magnum steps. $300
    Maybe a front bumper? What's that run? $1200-1500?
    Slight lift might be nice. That'll be about $600 if you upgrade suspension.
  5. Apr 3, 2017 at 11:56 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    You gave us your budget but you did not provide a list of operational requirements/desires/needs/wants and uses.
    How do you plan to use the truck? Do you plan to haul equipment or tow? How much weight and how often? Do you want to add a topper, a RTT, heavy bumpers, armor and a winch? All of this can impact greatly the type of set up you'll want to run.
    What size tires would you want to run? How much lift do you plan to add? Best to keep at 2" or less BTW.
    JTM1 likes this.
  6. Apr 3, 2017 at 12:03 PM
    JTM1
    JTM1 Well-Known Member
    Justin
    West Houston
    99 PreRunner, 08 TRD OR DC, 16 TRD OR DC, 18 F150 FX4 5.0L
    99-Fabtech Lift, Fox coil overs, OME Dakar leaf pack, LCE Header and Pro Flow Exhaust, TRD Supercharger, 275/70-17 BFG AT KO 08-Bilstein 5100s, OME 885 Coils, Wheeler's 2"AAL, All-Pro Skid Plates, Shrockworks Sliders, 265/75-16 BFG AT KO2 16-Daystar Strut Spacer, SSO Slimline Hybrid Winch Bumper, All-Pro Skid Plates, Shrockworks Sliders
    Do you just want a pretty truck or are you looking to Overland or Off-Road?
  7. Apr 3, 2017 at 4:28 PM
    AddicTioN
    AddicTioN Forklift technician
    wyatt
    north carolina mountains
    2020 dclb off road
    Ome with dakars - 1600
    Scs sr8s - 700
    St maxxes 285/75/16 - 1100 mounted balanced aligned
    Black et lugs - $50
    Total = 3450
    1550 left over
    All prices were rounded up. Left over can be spent on armor ( skids and sliders ) or appearance enhancements like a grill or what not. Depending on your uses of course.
    Pistol Pete likes this.
  8. Apr 3, 2017 at 4:51 PM
    smitty99
    Scottsdale
    I wouldn't get Dakars unless planning on carrying a lot of weight around.
    AddicTioN[QUOTED] likes this.
  9. Apr 3, 2017 at 5:37 PM
    AddicTioN
    wyatt
    2020 dclb off road
    Should have noted that for OP. For my uses they fit perfectly and would hate to still have stock springs considering how easy i had the rear of the truck sagging before the install. Would hate to have seen them with my rtt and loaded down with camping gear for the weeked.
  10. Apr 4, 2017 at 8:57 AM
    rfilmalter
    None
    Pardon my ignorance, is there a fix (TSB) for that light pulsating brake feel when you come to a stop? From my understanding everyone that has the truck suffers from this.
    Appreciate the advise
  11. Apr 4, 2017 at 9:05 AM
    T6A1C9O
    T6A1C9O Well-Known Member
    San Diego, CA
    2017 SW DCSB TRDOR 4x4 w/Tech
    Some pulsing/vibration is normal with the way the electronic brake boost system on the TRDOR operates.
  12. Apr 4, 2017 at 9:06 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    It's normal. The brake booster found in TRD OR and Pro models is the source of it.
    If I had $5k to burn on my Taco I'd get Kings, TC UCAs, SCS Ray10s and 285s. Unsure which flavor of tire I'd go with atm.
  13. Apr 4, 2017 at 9:08 AM
    rfilmalter
    None
    Hi All
    Thanks for all the replies.
    I apologize for not being specific on what I want to accomplish with the truck. I live in Vero Beach FL (Not much off-roading around here at all). I do on a regular basis drive on dirt farm roads, most of which have poor washboard surfaces.
    I guess what I wish to do is to make the truck just a little more capable to handle all kinds of off-road situations and a little more "aggressive". Tire upgrade, I agree, is 100% must.
    JTM1 likes this.
  14. Apr 4, 2017 at 9:09 AM
    rfilmalter
    None
    Thanks for the information
  15. Apr 4, 2017 at 9:18 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I dont have this feel. I didnt notice anything about the brake sin particular.
    If I had $5k to burn I would go with an AllPro Long Travel kit with extended travel Fox or Kings front and rear with Expedition Leaf pack. I would get Sealth Custom wheels and Maxxis Trepadors
  16. Apr 4, 2017 at 11:43 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    bilstein 5100 with OME 888 springs from Headstrong Offroad
    wheels of your choice
    some 265s or 285s
    winch
    bumper
    call it a day
  17. Apr 4, 2017 at 11:49 AM
    smitty99
    Scottsdale
    and an ECGS bushing and possibly UCAs with 285s, and possibly trimming as well (CMC)
    Mr. Projekt[QUOTED] likes this.
  18. Apr 4, 2017 at 11:50 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    fact.
  19. Apr 4, 2017 at 11:55 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    There's quite a few of us on the Treasure Coast. Check out the Florida Page. We are also on FB as Florida Tacomas.
  20. Apr 4, 2017 at 11:59 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    good to know. i thought it was brake judder from warped rotors.
