16' Tacoma front license plate mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma2GR, Nov 13, 2015.
  1. Nov 13, 2015 at 5:25 PM
    Tacoma2GR
    Tacoma2GR [OP] Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    Has anyone taken it off? looks like mine is drilled into the bumper :annoyed:
  2. Nov 13, 2015 at 6:50 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    2 holes in my bumper.
    I may opt to not use the bulky oem plate mounting block and just screw the plate to the bumper with a thin license plate frame surround.
  3. Nov 13, 2015 at 6:59 PM
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I'm curious to how that will look, post pictures when you get around to it.
    I didn't think of that one, I wanted to do away with them but the two holes are really ugly since they used that roughed edged screw.
  4. Nov 13, 2015 at 7:20 PM
    andyr562
    andyr562 Well-Known Member
    Andy
    Long Beach Ca
    I took it off, it was really bulky. Then inserted some nylon plastic phillips retainer clips. Will post a pic later
    Tacoma2GR[OP] likes this.
  5. Nov 13, 2015 at 7:26 PM
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    Yeah I was hoping there were some clean holes under there and I could sneak around for awhile without my front plate.
    Next best thing might be removing the mount.
    andyr562[QUOTED] likes this.
  6. Nov 13, 2015 at 7:35 PM
    andyr562
    Andy
    Long Beach Ca
    Well the holes were not clean, I grabbed a blade and smoothed them out
  7. Nov 13, 2015 at 8:09 PM
    MannyS
    Republic of Texas
    Holes in the bumper for the mounting block will be covered by the plate, so no issue with the holes being visible after the plate is installed.
  8. Nov 13, 2015 at 8:21 PM
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I'm waiting on the pics :fingerscrossed:
    CusterFan likes this.
  9. Nov 13, 2015 at 8:26 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  10. Nov 13, 2015 at 8:32 PM
    CusterFan
    The holes don't line up is what you told me on the other thread. I guess a guy could drill some new holes. Hard to believe just a plain ole deck screws are used instead of bolts/nuts to fasten both plates to the truck.
  11. Nov 13, 2015 at 8:34 PM
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I might do the bumper plugs
  12. Nov 13, 2015 at 9:07 PM
    andyr562
    Andy
    Long Beach Ca
    Sorry for the crappy pics!
  13. Nov 14, 2015 at 6:55 AM
    MannyS
    Republic of Texas
    The bracket holes do not align up with the license plate holes, but once I made 2 new centered holes for mounting the plate directly to the bumper, the oem bracket mounting holes will be covered by the plate. Hope this helps.
  14. Nov 14, 2015 at 7:14 AM
    CusterFan
    Is it metal behind the black plastic on the bumper you drilled through? I stood there and watched a tech drill out the holes when I bought the truck. Guess I was talking with the dealer and not paying attention if metal shavings were falling to the floor or not. I would like to use something besides those black screws to fasten the plate to the bumper. Any ideas?
  15. Nov 14, 2015 at 10:54 AM
    MannyS
    Republic of Texas
    No metal
  16. Nov 14, 2015 at 11:07 AM
    Taco2k16
    Taco2k16 TRD_ShoreTrooper
    Danny
    Los Fresnos, Texas
    2017 TRD OffRoad 4x4 QuickSand DCSB
    Stock Tow Package Bed LEDs
    i was lucky enough to get my truck before it was processed to be sold in the lot(if that makes any sense) it was still wrapped in plastic, i notice it didnt have the license plate mount on the front. the hardware was in the truck i told them not to mount the front license plates frame because i didnt want my bumper to be drilled:D:drunk:
  17. Nov 14, 2015 at 11:21 AM
    CusterFan
    I had to twist there arm to get them to drill my bumper in Jasper, IN.
    Tried to get them to drain the blue windshield wiper fluid but they said they needed a labeled container to dispose of it in. I ordered a Jiggler Self Priming Siphon Hose to deal with it myself.
  18. Nov 14, 2015 at 1:46 PM
    MannyS
    Republic of Texas
    Installed the front plate with an AutoZone thin license plate frame. I will eventually color match the license frame.
    As you can see, the drill holes on the bumper for the OEM bracket are not visible. I still need to replace the black plastic screws on the bottom of the license frame with stainless steel bolts/nuts.
  19. Nov 14, 2015 at 1:54 PM
    CusterFan
    Looks like there is just enough room to drill the holes before the bumper slopes in.
    http://www.autozone.com/license-pla...ersal-front-license-plate-bracket/103015_0_0/
    I'm thinking about this bracket because I could use the holes already in the bumper and the plate would be more centered on the bumper.
  20. Nov 14, 2015 at 2:08 PM
    MannyS
    Republic of Texas
    Funny you mention the autozone bracket in your post. I actually tried that bracket first, but I just did not like the way that the slides holding the plate looked (not pretty!). I thought of painting the bracket silver in order to make the bracket blend in, but I opted to try the thin license plate frame. Also, the existing OEM holes do not exactly match the holes on the bracket that you mention.
    As for the bumper hole placement for the thin license plate bracket, the holes are right at the slope, but no issues with the metal screws grabbing the plastic. I just punched a hole in the plastic with an awl and then screwed in the metal screw.
