16 Tacoma not fueling and now check engine/trac off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BattleBornCerakote, Jan 3, 2019.
  1. Jan 3, 2019 at 6:34 AM
    BattleBornCerakote
    BattleBornCerakote [OP] Active Member
    Brant
    16 Tacoma SR5 Crew Long Bed
    On my recently purchased '16, pre owned, it would not take fuel. I noticed a good amount of pressure in the gas tank when pulling the gas cap. Hadn't had a chance to look to into it yet. Then this morning, I start my truck and get the "Trac off" and Check engine lights. I stop, pull the gas cap...No excess pressure now. Replace the cap and I still got my lights. I haven't pulled the negative cable yet (Sitting at work) to try and reset it. Any chance i got too much tank pressure and blew a hose or seal somewhere?
  2. Jan 3, 2019 at 6:35 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    With issues like that, I'd take it directly to the dealer for them to figure out.
    outlawtacoma likes this.
  3. Jan 3, 2019 at 6:36 AM
    TacoRated
    TacoRated Do the chickens have large talons?
    Colorado
    2016 DCSB TRD OR
    High speed, special purpose duct-tape noise cancellation LCAs. Redline Tuning hood struts Hefty Fabworks Rock Sliders Trifold Bed Cover TRD Pro Grille
    That sucks man. I’d start by pulling the codes using a scanner. Some auto parts stores have a scanner and will do it for free.
    fdbyrne likes this.
  4. Jan 3, 2019 at 7:12 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    . . . "it would not take fuel"
    You mean you couldn't put fuel in the tank?? Like something blocking the fueling tube?
    I'd do some more research on the "pre-owned" thing.
    Dealer.
    G.
  5. Jan 3, 2019 at 7:13 AM
    BattleBornCerakote
    Brant
    As is, it would click off constantly due to tank pressure.
  6. Jan 3, 2019 at 7:15 AM
    Garyji
    Gary
    Yeah, take it in. Probably no warranty so get ready to bend over!
    G.
  7. Jan 3, 2019 at 3:25 PM
    BattleBornCerakote
    Brant
    So i got code P0031 and P0051. Both 02 sensors. Doing some research, sounds like that could be a relay being that having them both go at once isn't common. Ill swap the relay tonight and see what i find with it. So maybe this and the gas tank not venting are not related.
    I just bought this truck on Monday so its pretty frustrating. I called the dealership and they are helping over the phone the best they can at this point. Problem is, I'm 500 miles away. The closest dealer at all is 200 miles the opposite direction.
  8. Jan 3, 2019 at 3:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Those lights set (trac off/CEL) when the gas cap is not properly installed, or the cap has failed. One of those is the reason you didn't have a pressure release when you opened the cap.
    It would be unlikely for the cap to be bad on a new truck. Unless someone swapped you an old one from another truck? I mean it's not like they are gen specfic.
    *Sometimes* not taking fuel due to pressure is related to the pump itself (nozzle rate too high). Sometimes it's related to the vehicle emissions systems.
    I'd ignore the O2 codes for now, make sure the cap is properly installed, then reset the ECU or clear the codes with a tool and see what happens.
    Then try a fillup from a different gas pump and see what happens.
  9. Jan 3, 2019 at 3:42 PM
    BattleBornCerakote
    Brant
    Before I got the codes, I used 2 different gas stations with the same result. That was Monday. After getting the codes this morning, I messed with the gas cap. I didnt have excess pressure but I also only have about 1/4 tank. Not sure if that is why. Tried to add fuel from another station and same issue. I had a NAPA reset the codes for me and they came right back.
  10. Jan 3, 2019 at 3:49 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Was the previous owner a drug dealer by chance? Is your gas tank full of cocaine?
    Hank Heel, TeecoTaco and whatstcp like this.
  11. Jan 3, 2019 at 3:56 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    :fingerscrossed:
    Hank Heel likes this.
  12. Jan 3, 2019 at 4:17 PM
    Garyji
    Gary
    Where are you?? No dealer within 200 miles? In America??
    G.
    2016Tacoman likes this.
  13. Jan 3, 2019 at 4:36 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Longshot...
    You don't happen refuel with the ignition on?
  14. Jan 3, 2019 at 6:00 PM
    BattleBornCerakote
    Brant
    I'm in Central Nevada. 185 miles to the nearest one.
    I've tried fueling with the ignition on and off.
    I checked swapped the relay for the O2 sensors, reset the truck, and no joy.
  15. Jan 3, 2019 at 6:07 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Had a work Chevy do this once, brand new truck. Filler tube was compressed, and melted together. Most i could add was 1-1.5 gallons before it would shut off. Check your filler tube. Dont know why that would throw codes though.
  16. Jan 3, 2019 at 6:13 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Excessive pressure and fuel spitting back during refueling is a typical sign of a blocked or plugged vent line in the tank !!
    Hank Heel, TacoRated and Steves104x4 like this.
  17. Jan 3, 2019 at 6:23 PM
    BattleBornCerakote
    Brant
    I'll be pulling the vent line off this weekend and see what's up with it.
    TacoRated and US Marine like this.
  18. Jan 3, 2019 at 6:26 PM
    Garyji
    Gary
    Hope you get it figured out. That really sucks in the middle of no where.
    G.
  19. Jan 3, 2019 at 6:29 PM
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    Stuck vent sucked the fill tube flat and collapsed it.
  20. Jan 5, 2019 at 12:36 PM
    BattleBornCerakote
    Brant
    Update:
    Got the codes cleared. It was a fuse, not the relay. Now to figure out the "hopefully" plugged vent hose so the truck will take fuel.
