'16 TRD Sport - Oil and Filter?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ttu19, Aug 23, 2018.
  1. Aug 23, 2018 at 9:43 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Go to Mobil1 website, it's hard to pass up using it with that rebate.
    Velequez and tonered like this.
  2. Aug 23, 2018 at 9:49 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is a hard deal to pass up, but I'm done with oil changes for the next 18mo or so. Just ToyotaCare for now.
    shakerhood[QUOTED] likes this.
  3. Aug 23, 2018 at 9:57 AM
    ttu19
    ttu19 [OP] Well-Known Member
    Wes
    San Antonio, Tx
    '20 TRD Sport Premium
    I'll have to check that out because I need to order about 3 of those 5qt. 2 for the Tundra and I guess just 1 for the Tacoma. The little I have left over from mine can go in the Tacoma.
    tonered likes this.
  4. Aug 23, 2018 at 10:01 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Well shit I’ll have to check that, I’ve been using 5.5 Qts, only changed it once so far.
    [/QUOTE]
  5. Aug 23, 2018 at 10:08 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    [/QUOTE]
    As long as you're between the marks on the dipstick, then you're good to go.
  6. Aug 23, 2018 at 10:26 AM
    shakerhood
    Southern Ohio
    [/QUOTE]
    5.5 Quarts was on the 2nd Gen 4.0 so it's possible you may have caught a chart from that.
  7. Aug 23, 2018 at 10:32 AM
    Grossomotto
    2017 4WDV6LB6MT
    Ok thanks looks like I have to add another 1/2 qt or so, I've only driven a few hundred miles since changing
    [/QUOTE]5.5 Quarts was on the 2nd Gen 4.0 so it's possible you may have caught a chart from that.[/QUOTE]
    shakerhood likes this.
  8. Sep 2, 2018 at 1:42 PM
    ttu19
    Wes
    San Antonio, Tx
    So I can't get the oil filter to budge at all. I even broke a filer wrench using a breaker bar and I can't budge the damn thing. And yes I am turning it the correct way. Are they backwards in Japan?
    Anyone got any ideas because they must have used F'n glue on it or something. Even my impact will not make it budge.
  9. Sep 2, 2018 at 2:01 PM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Sounds like the typical dealership Toyota Care gorilla grip. Take it to them and have them fix what they've done.
  10. Sep 2, 2018 at 2:11 PM
    ttu19
    Wes
    San Antonio, Tx
    Oh I am. I used everything and can't move it, even broke off one of the tabs. So I'll be sure they replace that as well and a free oil change since I'm going have to fill it just to dump it in a couple days.
    KellyJoe[QUOTED] likes this.
  11. Sep 2, 2018 at 2:11 PM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
  12. Sep 2, 2018 at 2:26 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No. I pay my dealer $80 for:
    Oil change and filter
    Tire rotation
    Grease
    All visual checks like belts, brakes, etc.
  13. Sep 2, 2018 at 3:11 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Two on front shaft. 2017 4WD.
  14. Sep 2, 2018 at 7:15 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I am lucky to have a good dealer for the past 20 years.
  15. Sep 2, 2018 at 11:18 PM
    #35
    Bamareb
    Bamareb Member
    Andrew
    All great info here. Thanks
  16. Sep 3, 2018 at 5:31 AM
    #36
    GTS Bruce
    GTS Bruce Well-Known Member
    W
    I take in every vehicle 5000 miles. Local family garage. Oil change,check all fluids,rotate tires,check brakes and they estimate when I should think about getting brakes,and other stuff taken care besides using the factory maint schedule as in quality of coolant,tranny/diff fluids
  17. Sep 3, 2018 at 7:43 AM
    #37
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    It can be a bitch to take off but just a little courtesy information for you before you go in and start flaming on some poor people for thinking they over torqued your canister. I did mine yesterday for the 2nd time after doing the previous oil change on my own. I hand tightened and applied tons of oil on the threads and newly replaced gasket/o ring. Guess what? It was still EXTREMELY hard to get my canister off. I used so much torque that the filter wrench was wedged on and I needed to use a pry bar and hammer and wood just to get the filter wrench to release off the canister. Chances are they didn't over torque and it's the natural process of the plastics and o rings expanding and contracting due to the heat cycling. If you broke it im sorry to say that's completely on you.
    Vbpiper likes this.
  18. Sep 3, 2018 at 10:02 AM
    #38
    shakerhood
    Southern Ohio
    Are you talking about Break Away Torque or just Running Torque? The Canister only gets tightened to 18 Ft Lbs, if it is requiring so much force to break it loose and wedging up the wrench it sounds as if it was installed too tightly. These do have a bit of Running Torque but I believe it is by design since it is on the bottom and they do not want it to accidently come loose.
    tonered likes this.
  19. Sep 3, 2018 at 10:55 AM
    #39
    ttu19
    Wes
    San Antonio, Tx
    When I first did my Tundra, I had to use my breaker bar and it took a little muscle, but it came loose no problem and has been fine since. This one though, I can't move for the life of me. They are closed today so I'll call them tomorrow and see what can be done. I just need them to take the damn thing off so I can put a new filter and get a new canister cartridge since this one now has a broken tab. Hell they can replace it under warranty if they want, it's only a $30 part.
  20. Sep 3, 2018 at 11:24 AM
    #40
    Freegolf
    Denver
    Break away torque caused my metal wrench to wedge on the plastic canister. This happened even while I was the last one to install it by hand (last oil change). So it was not over torqued. My post was relaying info that the canister can be really tight even under torqued since last change.
