16" vs 17" wheels: pros and cons?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Soccer Mom, Nov 11, 2016.
  1. Nov 11, 2016 at 1:31 PM
    Soccer Mom
    Soccer Mom [OP] Well Endowed Member
    2017 MGM SR5 DCSB
    METHOD | SOS | C4 | RIGID | PRINSU | OME | TC
    if the tire going on the wheel will be the same diameter, is there any difference in performance between a 16" and 17" wheel of the same make and model? I am narrowing down wheel and tire choices and am interested in a 16" but my truck came with 17" and that seems to be the most popular size. Would i see any differences in MPG or speedo between 16 and 17 with the same diameter tire? Any difference in ride quality? Any practical reason to go with one over the other? Thanks!
  2. Nov 11, 2016 at 1:33 PM
    para38s
    para38s Well-Known Member
    2011 Tacoma DCSB 2wd / 2012 Toyota Tundra 4x4
    It's all preference. Bigger sidewall is better for off-road. I went with 16s by the way.
    mmrocek and Ritchie like this.
  3. Nov 11, 2016 at 1:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    The Tire calculator will answer your size/speedo/odo/gearing effect questions.
    I prefer more side wall than wheel on a truck. Little better ride less risk of banging up a wheel.
    Total wheel/tire weight matters too. Lighter is better for pavement use. Handling, braking, acceleration, and ride quality are all affected.
    mmrocek and MadDaddy like this.
  4. Nov 11, 2016 at 1:40 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    16s fo life, unless sports car
    71tattooguy and digitaLbraVo like this.
  5. Nov 11, 2016 at 1:48 PM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    More side wall means more flex, on passenger vehicles it also numbs the handling. But because of the give the ride is more smooth and tends to even out small bumps. You'll feel less of the road.
  6. Nov 11, 2016 at 1:51 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    16" = Taller Sidewall = More squish over rough roads = smoother ride. (*Assuming same overall tire size, psi, etc)
    17" = Shorter Sidewall = Less squish over rough roads = less smooth ride. (*Assuming same overall tire size, psi, etc)
    18"+ = OMG LOOK AT ME!! YAY! Mall Crawler!
    The only pro with 17", in my mind's eye, is that you have more room for larger brake calipers if you ever wanted bigger brake rotors/calipers.
  7. Nov 11, 2016 at 1:52 PM
    Soccer Mom
    2017 MGM SR5 DCSB
    If I save a few lbs per wheel choosing 16's over 17's won't the more tire make the weight savings negligible?
    MadDaddy likes this.
  8. Nov 11, 2016 at 1:59 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Not sure there is a real difference in actual "squish" feel between the two. The theory is, of course, correct.
    G.
  9. Nov 11, 2016 at 2:00 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Another factor to consider is tire price. The last particular tire I was looking at was about $20 cheaper a tire for 16 vs the 17. It's probably due to more truck owners with 16s, therefore a larger demand and lower prices.
    DrFunker, 0210 and Ritchie like this.
  10. Nov 11, 2016 at 2:35 PM
    oldman52
    oldman52 It's a Truck!
    Raytown, MO
    2016 Tacoma TRD Off Road DCSB 4x4 MGM
    5100's front and rear on stock OR coils set at .85 with 1/2 spacer LF, 1/4 spacer RF. LED interior lights. OPT7 LED low/high lights. Morimoto LED fog lights. Philips LED front turn and side marker lights. Philips LED rear tail/brake/turn all in one mod with license plate lights. ATX Series 202 matte black 16"x 8" alloy wheels. Goodyear Authority MT 265/65/16C tires. Matte Black painted OR grille with MGM painted front emblem. SR5 OEM fog light covers. Gloss black bedside decals-tailgate inlay. Subdued US flag decal each side and vehicle badging, Triple black custom Clazzio seat covers with custom embroidery TRD on head rests. TRD cold air intake. TRD cat back exhaust. TRD skid plate painted MGM, w/black vinyl TRD inlay by Rrentrop. Shift Sense Pro V2. Salex center console divider tray. Center console TRD coin holder with lid by Mesojdm. Total Chaos bed stiffeners. Engine cover decals by Rrentrop. TRD oil and radiator caps. Cheap Speaker Mod; Subaru tweeters - Kicker DS Speakers 6"x 9" front, 6.75" rear. RedLine Quicklift Plus hood damper struts. Noice 50mil sound deadening on front and rear doors. GassHole gas cap holder by Mesojdm. Ultimate LED turn signals by Mesojdm. Custom radio knobs by Tacowiede.
    I could be wrong but it seems like there are more wheel and tire options with a 17" wheel then 16".
  11. Nov 11, 2016 at 3:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    Maybe. Maybe not. The same size tire can have different weights in different brands.
    Which is why the last para in post 3 reads as it does.
  12. Nov 11, 2016 at 3:01 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Maybe. All I know is when I was searching for new tires in a 285, the 16" variant was consistently cheaper than the 17"
  13. Nov 11, 2016 at 3:03 PM
    Long Time Toy Fan
    Long Time Toy Fan Well-Known Member
    17 DCOR
    Cookie cutter Tacoma, 888/Dakars/LR/ECGS/Sliders
    What size tire are thinking of putting on that wheel? As OldMan52 said there are way more options in the 17 even if they do cost a little more. Also you need to look at the load rating on the tire size you are looking at. Just because you can match the height with a 70 or 75 profile doesn't mean the load ratings will be the same.
  14. Nov 11, 2016 at 3:11 PM
    PROseur
    Pussy
    If 18 is bro
    What are all the 20" that turd gen owners keep installing ?
    Wallbright and arnette64 like this.
  15. Nov 11, 2016 at 3:26 PM
    oldman52
    Raytown, MO
    I agree with that 100%, I was looking at aftermarket wheels last night on several sites and noticed less choices with the 16" then 17" made me start thinking about switching.
  16. Nov 11, 2016 at 3:31 PM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    The best way to figure this out is to go to some site, like tirerack.com and compare the same tire in the 2 different sizes. You'll be able to find the actual weight of each tire and go from there.
  17. Nov 11, 2016 at 3:35 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    You'll note I said 18"+ (so 18 and everything larger).
    Once you get that big it's all about looks and not functionality. Not much sidewall left in that 20+ size!
    antlab67 and PROseur[QUOTED] like this.
  18. Nov 11, 2016 at 3:37 PM
    PROseur
    Pussy
    I see
    I have puny 16
  19. Nov 11, 2016 at 3:38 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Me too! :) Stayed 16" purely for off-road purposes.
    PROseur[QUOTED] likes this.
  20. Nov 11, 2016 at 3:41 PM
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    The only 17" rim I'd consider is the TRD Pro rims. Apparently the guys at expedition overland have no problems running them on with 285s with AT3 general grabbers.
    Xtra_yota, dziner and PROseur like this.
