16" wheels on a 06 DC
Discussion in 'Wheels & Tires' started by hockeypoor, Sep 9, 2008.
  1. Sep 9, 2008 at 8:32 PM
    hockeypoor
    hockeypoor [OP] Well-Known Member
    Central Coast of California
    Speedway Blue All stock Prerunner
    Ok I need some help. I have heard that 16's will fit and I have heard that they wont.
    I am put a lift on soon and am just looking at wheel options. Will 16's work? I think I would like to run 285/75/16 on 16x 8 wheels with a 3in lift if that will work.
    Also I have heard that there was some type of brake or rotorchange aroung 06. can someone please explain.
  2. Sep 9, 2008 at 8:34 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Some 16" wheels won't fit, if I was you I would test fit one of the wheels your looking at.
    Cheap solution, buy some used TRD alloys (16") and a set of spacers and then you can run your 285s.
  3. Sep 9, 2008 at 8:35 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey man, there are plenty of 16 inch wheels that will work....just gotta make sure the bolt pattern and back spacing are correct.
    not sure about the brake change in the 06 though....as far as i know, its the same as the 05. there was a tsb for squeaky brakes at one point......and with that...dealers were changing the rotors and pads per the tsb.
    what type of wheel are you looking for??
  4. Sep 9, 2008 at 8:47 PM
    hockeypoor
    I want these eagle type 102 wheels in 16x8 or 17x9[​IMG]
  5. Sep 9, 2008 at 8:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    go with the 16x8.....i think there are alot more tire choices, but i can be wrong.
  6. Sep 10, 2008 at 10:56 PM
    sooner02r1
    sooner02r1 Well-Known Member
    A lot of 16" wheels will work, but some won't. If you have a TRD Tacoma it's even worse because they have bigger brake calipers on the front.
    Also it has nothing to do with the backspacing of the wheel. It has everything to do with the shape of the inside of the wheel, for example, Robby Gordon wheels, 17x8, 4" backspacing, will not fit. And they are 17" even with correct offset.....
    Just depends on the wheel man.
