16" wheels to 17" wheels ?
Discussion in 'Wheels & Tires' started by lynyrd3, Aug 30, 2011.
  1. Aug 30, 2011 at 3:51 PM
    lynyrd3
    lynyrd3 [OP] STRENGTH DETERMINATION MERCILESS FOREVER
    Bill
    East Central Upstate NY
    Looking to go with a taller tire . I have just about a 3 " lift with 265/70/16s now. If I get a 17 " rim what would be the biggest tire I could use ? And does that 17 " rim add to the height or just make for a bigger hole in the tire?? :confused: :confused: :confused::eek:
  2. Aug 30, 2011 at 3:53 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    17 doesnt add to the height anything. the only thing that makes a height difference is the 1st and 2nd numbers on the tires size
    can i ask why you want to go to 17's? the only reason i could see is for a 6" DP lift or spending more money on tires, neither of which would be a selling point for me personally
  3. Aug 30, 2011 at 3:55 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    16's are cheaper
  4. Aug 30, 2011 at 4:03 PM
    lynyrd3
    Bill
    I think my tire size is maxed out for a 16" rim. Just want to know if 17" will let me go with taller tire ? :eek: Thanks
  5. Aug 30, 2011 at 4:06 PM
    08pretaco
    az
    your thing says 265/70/16, getting a 265/75/16 will give you a taller tire.
    from the online tire size calculator
  6. Aug 30, 2011 at 4:08 PM
    08pretaco
    az
    if you want a really tall tire, that offers great gas mileage look into getting 255/85/16. a little narrower than your 265 but has a diameter of 33.1" over your 31.6"
  7. Aug 30, 2011 at 4:13 PM
    TacosNTits
    TacosNTits Well-Known Member
    Rick
    Here's my 2 cents... if you have 265/70/16s and went to 265/70/17s you would gain nothing in tire wall height but you would gain 1" in rim diameter obviously. Sounds like you want to fill up the wheel well and going to 17's would help I guess.
    From what I am hearing here and on the net 16's are best.
  8. Aug 30, 2011 at 4:16 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    What size tire do you have that maxed out the 16's?
    I think you can put like 35's on a 15 inch wheel...
  9. Aug 30, 2011 at 4:33 PM
    lynyrd3
    Bill
    265/70 16s
  10. Aug 30, 2011 at 4:36 PM
    lynyrd3
    Bill
    I guess I could go with the 265/75s. Looking to get rims and tires for the summer and keep what I have for the winter. That is why all the questions about 17 " rim . Sounds like I should stick with 16s and go with 265/75s to gain 1.04 inches .
  11. Aug 30, 2011 at 4:42 PM
    lynyrd3
    Bill
    That might be pushing it with a 3" lift ,right ?:confused:
  12. Aug 30, 2011 at 4:45 PM
    98tacoma27
    Ben
    Not Beech Creek
    The calculator is 100% accurate. For instance, my 265/75-16 Duractracs are actually 31.25" tall.
    Nope. You can fit them on a 3" lift.
  13. Aug 30, 2011 at 4:45 PM
    08pretaco
    az
    You can get a 37 on a 15. The only thing that's the limiting factor is the width to thw wheel width.
  14. Aug 30, 2011 at 4:46 PM
    98tacoma27
    Ben
    Not Beech Creek
  15. Aug 30, 2011 at 4:53 PM
    lynyrd3
    Bill
    Thanks for all the info guys . Now I just need to pick out a nice new set of rims for the summer. I have all winter to to figure it out !
