+165,000km Maintenance?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymac10, Oct 3, 2024.
  1. Oct 3, 2024 at 2:24 PM
    jaymac10
    jaymac10 [OP] Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    My 2013 now has about 165,000km. She's raised about 3' in the front and 2' in the rear. Overall, she's been pretty good to me so no real complaints! She goes up to the ski hill a lot in the winter so rusting parts has been a bit of a problem (cam bolts), but the frame is good shape.
    I did a bunch of maintenance on her at 100,000km. Replaced all fluids & iridium spark plugs.
    OEM Baja TRD 6112 Shocks have 155,000 km on them (broken springs replaced 4 years ago). They still seem fine! 5100's in the back are only 6 years old and have about 90k km.
    Just got JD Fab UCAs installed a couple weeks ago.
    On Monday, I'm getting the needle bearing replaced with the ECG Bushing, new inner and outer tie rods as they are too rusted to work anymore and my shop is trying to figure out which wheel bearing(s) are humming...
    Just wondering as gets older, what sort of major/common things will become an issue that will need attention/replacing/fixing? Is there anything I should fix/replace before it becomes an issue, or just fix things as they come?
    Thanks!
  2. Oct 3, 2024 at 8:27 PM
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    For me, it depends partly on rust. I tend to break a few bolts each time I work on my truck, so preventive maintenance could sometimes be a good idea. Might as well replace a few parts while in a certain area as well. I dropped $10K, mostly in parts over the last 2 years, starting at about 200K km. Not much before that. I must of done at least 50K km on gravel roads, usually high speed and loaded (not me, the truck) which is hard on lotsa parts. Here's a rough list on what was done with date, km's and parts. Presently, trucks purrs like a kitten, no vibes and hoping for a 30K until additional work which will probably be idler wheels, possibly alternator, and thinking of changing AC compressor as preventive maintenance.
    20121114 32 Tires, Duratrac 265/75-16
    20121114 32 OME 2.5'' HD Kit
    20121114 32 SPC UCA
    20121114 32 Firestone Airbags for rear leafs
    20140217 31115 Front rotor machining
    20150528 48000 SPC UCA bushing replacement # 1
    20160920 60843 Replaced front pads and rotors
    20170111 66500 Tire replacement # 1, Duratrac 265/75-16
    20180510 96000 Battery replacement # 1
    20180514 96000 SPC UCA balljoint replacement # 1
    20180612 96987 Belt replacement # 1
    20180612 96987 AC clutch replacement # 1
    20181005 98000 Unifilter mod
    20181005 108000 OME BP-51 rear shocks
    20181117 110000 Airbag for rear leafs replacement # 1
    20190212 114505 SPC UCA bushing replacement # 2
    20190212 114505 Differential air vent mod
    20190212 114505 Replaced front pads and rotors
    20190225 115265 Rear axel sceal
    20191212 135244 Antenna replacement # 1
    20200428 140028 Replace air pump under warranty
    20200826 144132 AC o-ring repair, front rotor machining, replaced 3 idler wheels and belt replacement # 2
    20200717 150000 Tire replacement # 2, Duratrac 265/75-16
    20210104 159403 Drum machining
    20210127 165000 Windshield replacement
    20210526 167569 Replaced high pressure AC hose
    20210630 170000 Replaced stabilizer bar bushing
    20210716 170000 AC clutch replacement # 2
    20210916 176426 Replaced front brake pads and rotors
    20221202 210768 Replaced lost pin from front brake pad
    20221223 212000 Tire replacement # 3, Duratrac 265/75-16
    20230417 218000 Antenna replacement # 2
    20230417 218000 Replaced front and back suspension, coils, leafs, shocks etc. (broken leaf spring) (back BP-51 replaced under warranty)
    20230417 218000 Replaced LCA
    20230730 227303 Replaced front brake pads and left caliper
    20230817 227303 Replaced a bunch of front end fasteners
    20230817 227303 Lots of welding left wheelwell/radiator support area
    20240603 242522 Replaced all 4 tires under warranty (# 4)
    20240605 243000 Replaced muffler
    20240611 243500 Replaced front wheel bearings, front and rear pads, rotors, drums, right caliper
    20240813 244000 Replaced CV Axels + seals, right side caliper, SPC balljoint (#3) and bushing, AC clutch # 3, battery replacement # 2, added ECGS bushing
    20240907 246000 Replaced catalytic converter gaskets
  3. Oct 3, 2024 at 8:30 PM
    Bishop84
    Bishop84 Well-Known Member
    You fix as you go, 100,000 miles/160,000 isnt much, but we start to see leaks, and suspension wear.
    You're already on top of it, so not much to worry about.
    TnShooter likes this.
  4. Oct 3, 2024 at 8:39 PM
    OSUTacoma
    OSUTacoma Well-Known Member
    OHIO
    2023 Lunar Rock TRDSport DCSB
    My 12' now has 230K . Around the beginning of Summer I took it to the dealer to have the serpentine belt changed , the last oil change the guy said it was looking a little worn. As I was leaving , I asked the service guy what else I should do due to the high mileage , he said keep an eye on the fluids and thats about it. Ive been very fortunate with this truck , brake pads and rotors , oil changes and shocks is all the money ive spent on maint.
  5. Oct 3, 2024 at 8:50 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    254,000 Miles
    I had my entire front suspension rebuilt when I lifted it at 220,000. OEM LCA, Ball joints, swaybar links, Element UCA Uniball, Tie Rods Outer. New CV Boots on original CV Axles.
    Other than brakes and Oil changes.
    Drain and fill at 140k, full Trans Flush at 150K, drain and fill at 240k with new Filter and clean pan.
    Carrier Bearing at 240k with new U-Joint.
    U-Joint near Rear Shaft where it meets the Pinion on the rear axle 240K
    Coolant flushes dont recall mileages
    Front and rear Diff, T-Case fluid at 130k and 240k
    Fuel pump at 130K
    Plugs at 150k
    Water Pump 120K
    These trucks are solid, maintain them.
    Just fix them as they come. Lube all of your U-Joints if you're 4x4, do some Transmission Drain and fills, Change your coolant and service your differentials this should get you up to speed, also 5K mile oil changes none of that 10K mile BS. You also might want to get regular fluid film on your frame if you drive a lot in the snow.
