$1650 for a new complete engine wire harness?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pierofus, Apr 3, 2017.
  1. Apr 4, 2017 at 7:18 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    That sounds irrational
    cruxofthebisquit likes this.
  2. Apr 4, 2017 at 7:20 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Please don't tell me you are throwing parts at it until you get it working.
  3. Apr 4, 2017 at 7:23 AM
    RIDERED67
    Does it crank?
  4. Apr 4, 2017 at 7:23 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Could just be the starter or the battery fuse.
  5. Apr 4, 2017 at 7:27 AM
    pierofus
    pierofus [OP] Active Member
    Piero
    2016 TRD off road Silver Tacoma
    not the battery fuse, we are going to try with a new starter now.
  6. Apr 4, 2017 at 7:32 AM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Check inertia switch
    Joe D likes this.
  7. Apr 4, 2017 at 7:32 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    This. I'd be looking pretty hard at finding the specific cause before just spending $1650 to do a whole lot of work that might not even fix the problem.
    The price is probably about the norm though.
  8. Apr 4, 2017 at 7:33 AM
    Woodrow F Call
    Colorful Colorado
    Why not just test the one you have? Should be able to pull it off, put 12vdc on it and see if it works. Then you know if the issue is upstream of the starter.
  9. Apr 4, 2017 at 8:07 AM
    Herniator
    Edmonton
    Did you check all the Relays and fuses in the box next to the battery? Are all the ground connections good?
    What happens when you try and start the Motor?
  10. Apr 4, 2017 at 8:09 AM
    RIDERED67
    This thread is fishy
  11. Apr 4, 2017 at 8:18 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Wayyyy to much overkill going on here. None of this makes any sense. First the complete wiring harness and now the starter??? C'mon, who you kidding???
  12. Apr 4, 2017 at 8:47 AM
    RIDERED67
    OP have you tried putting 12volts straight to the starter?
    You know What, I'm out :ballchain:
    nv529 and cruxofthebisquit like this.
  13. Apr 4, 2017 at 8:49 AM
    pierofus
    Piero
    what are you trying to say, this is a joke? come on, if i ddin't had any problem i wouldn't waste my time explaining my situation.
  14. Apr 4, 2017 at 8:49 AM
    Herniator
    Edmonton
    The guy is going to spend 1000's of dollars just to find out that it is probably something simple to fix.
  15. Apr 4, 2017 at 8:50 AM
    #35
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Ya, ok. Try changing the ignition. If that doesn't work, then the driver's side reading light.
    zh137dz likes this.
  16. Apr 4, 2017 at 8:53 AM
    #36
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I think what everyone is trying to explain to you is that you need a mechanic with better diagnostic skills because he is jumping to really big conclusions that do not seem plausible and he is going to cause you to waste a lot of money. Are you in TJ ? Can you tow the truck up to San Diego to get it better diagnosed ?
  17. Apr 4, 2017 at 8:58 AM
    #37
    Herniator
    Edmonton
    It sounds like he has a backyard mechanic or a friend helping him out. You can test a starter before trying to install a new one. Anyone can fix a vehicle by replacing parts until it works. The trick is to find the problem without spending a bunch of money on unnecessary parts.
  18. Apr 4, 2017 at 8:59 AM
    #38
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    We used to start our Jeep with a hammer (wooden handled) across the POS and NEG connection on the starter.. should be pretty easy ... oh and there's a shit ton of cold cranking amps so be careful.
    OP did you check the fluid level in your tail lights? Sometimes that causes the issue you described originally.
    Pittrider likes this.
  19. Apr 4, 2017 at 9:04 AM
    #39
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    zh137dz and bobrown14[QUOTED] like this.
  20. Apr 4, 2017 at 9:04 AM
    #40
    JoeCOVA
    Joe
    Colorado Springs
    Yup, best way get a bad starter started, jump the selenoid, I used a screw driver :)
    bobrown14[QUOTED] likes this.
