1650 miles and I have a Leaking driveshaft bearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hepcat75, Aug 3, 2016.
  1. Aug 5, 2016 at 5:26 PM
    iceworks24
    iceworks24 Member
    16' MG Taco TRD OR
    No, the vibration is still there and feels like it has gotten worse. I feel the vibration at 10 to 30mph now when used to be 15-25mph. And the vibration isn't a subtle vibration either, anyone driving and any passenger can feel it, in the floor board, in the seat, and in the pedals.
  2. Aug 5, 2016 at 5:45 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I've been told a steering dampener could help. Supposedly this was a fix toyota tried for the 2nd gens that had issues with vibes. It doesnt fix the root cause but it can treat the symptoms. Some speculate it could be driveline angle and others have claimed perhaps exhaust resonance. Nobody seems to know for sure.
    Blueboy and Spare Parts like this.
  3. Aug 5, 2016 at 5:48 PM
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
    Squirting. Heh!
    12TRDTacoma likes this.
  4. Aug 5, 2016 at 5:56 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    My truck is lifted and the exhaust is dumped over the axle. No vibes for me
  5. Aug 5, 2016 at 6:01 PM
    BlazingTaco
    Exile
    I was told by Mike Sweers himself that the 2017 will have the exhaust routed into the area behind the front seats. He said it will reduce all kind of random noise from the front seats. OP, that is a special lube they use to dampen the pinion thrust angle seal.
  6. Aug 5, 2016 at 6:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Obviously the CB's on these trucks are not even close to improved and still the achilles heel of the otherwise solid made 2 piece DS system.
  7. Aug 5, 2016 at 6:31 PM
    smitty99
    Scottsdale
    I wished they'd have used the special lube for me when I signed the delivery paperwork for my 2016
  8. Aug 5, 2016 at 6:45 PM
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    Its too far back and its leaking from the rear side.
    Ive seen different leaks where the dealer drained and never cleaned off the area and got sprayed. This doesnt look like ot.
  9. Aug 16, 2016 at 3:15 PM
    hepcat75
    hepcat75 [OP] Member
    Raymond
    Very first brand new truck
    Update
    Took the truck to the dealer to check on the bearing that was leaking and they said they have to order a whole new driveshaft for it. So apparently the bearing is part of the drive shaft unit
    Raymond
    Kilokato likes this.
  10. Aug 16, 2016 at 3:27 PM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    My God already. Every day it seems there is one or two new threads on a new problem with the third gen.
    Sometimes I have to double check and see if I accidentally signed up for the Chebby Colorado forums and logged in.
    Blueboy, 12TRDTacoma, ZachMX and 2 others like this.
  11. Aug 16, 2016 at 4:00 PM
    Mark_R
    Mark_R Well-Known Member
    Mark
    2016 Toyota Tacoma TRD Off-Road
    Wait.... They said they need to order a whole new driveshaft as the bearing is part of the drive shaft?! That's the carrier bearing and it simply slips around the driveshaft and bolts onto the carrier bearing bracket that spans the frame......
  12. Aug 16, 2016 at 6:02 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    While it seems far fetched, maybe whatever's going on there actually damaged the driveshaft. A dealer will replace the whole unit versus tear down the driveshaft and replace the damaged part.
  13. Aug 16, 2016 at 6:06 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Its amazing isn't it ? No other truck on the planet has any problems but the Taco where one person comes in with a problem. POS.
    OMG don't forget the plastic plugs up front for the dreaded wind noise.
    The Ttttttrany TttttttSB, OMG !
    The hood glue problem on a few units !!!!!!!
    The NEW differential gear ratio for 2017 !!!!
    WOFT
    OP, did you grease your zerks in that area recently ???
  14. Aug 16, 2016 at 6:12 PM
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    It is a assembly they have to replace.
    It is sold as one part
    Kinda like the lower controll arms you can get oem replacement ball joints
  15. Aug 16, 2016 at 6:24 PM
    #35
    Weminuche
    Weminuche Well-Known Member
    16' Red Taco
    I would run that to failure.
  16. Aug 16, 2016 at 7:33 PM
    #36
    jdmfreak1992
    jdmfreak1992 Well-Known Member
    Taylor
    2017 Tacoma TRD Off-Road
    Stock for now
    A lot of the new vibration damping mounts have a fluid in the to help reduce vibration even more I had a motor mount in my car go bad did the same thing a leaked what looked like oil out of it.
  17. Aug 16, 2016 at 7:41 PM
    #37
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Is the carrier bearing coated in oil for shipment to the factory? Residual oil heating, thinning and gathering at the bottom?
  18. Aug 17, 2016 at 2:48 AM
    #38
    Five56
    Five56 Well-Known Member
    Rob
    Tune in for the latest episode of "Who's Truck Is Gonna Bite It Today".
  19. Sep 28, 2016 at 6:27 PM
    #39
    DedDucks
    DedDucks Well-Known Member
    Lindale
    2015 Silver Sky TRD OR DC 4x4
    What's the latest on this with your truck? I just had mine replaced today, as it was leaking just like yours. I noticed driving home from getting it replaced that above 60 there's a very low pitch drone noise that's not very loud. When I got home I felt the drive shaft and from the bearing forward on the shaft to about have way to transfer case it was too hot to keep your hand on longer than about half a second.
    My question is whether it's normal to get hot or not? I called dealer and took it back in for them to look at and they said, "It's not too hot unless it's orange." They also drove truck and could not hear drone noise.
    It just doesn't seem right to me for that bearing and u joint to get that hot. What do y'all think? Do y'alls get hot?
  20. Sep 28, 2016 at 9:14 PM
    #40
    George1441
    George1441 Much happier
    George
    2016 Chevrolet Colorado Diesel
    :rofl::rofl::rofl::rofl:
