1650 miles and I have a Leaking driveshaft bearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hepcat75, Aug 3, 2016.
  1. Sep 28, 2016 at 9:33 PM
    #41
    2k4Taco
    2k4Taco IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    It might be grease, if it got too hot, it might have reached its breakdown state and ran down...
  2. Sep 29, 2016 at 10:22 AM
    #42
    DedDucks
    DedDucks Well-Known Member
    Lindale
    2015 Silver Sky TRD OR DC 4x4
    They deemed the first one was bad and leaking. Replaced it and now the drive shaft and bearing get real hot. Plus the low pitch drone after 60+ mph. That's the issues. Thinking drive shaft out of balance now. Can see small chunks of metal missing on u joint where they banged around on it.
  3. Sep 30, 2016 at 12:19 AM
    #43
    2k4Taco
    Swanny
    Fleming Island, Fl
    Crazy question, are the bearing internally lubricated and sealed? What are they using for it to be "leaking"?
  4. Sep 30, 2016 at 1:37 AM
    #44
    sethhawaii
    sethhawaii Well-Known Member
    2016 TRD offroad 4x4
  5. Sep 30, 2016 at 2:02 AM
    #45
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I don't understand why a driveshaft would get hot. Transmissions and differentials get hot, could they heat up the drive shaft? I will test mine with the infrared thermometer 'cause I'm curious now.
  6. Sep 30, 2016 at 4:17 AM
    #46
    DedDucks
    Lindale
    Yes, they are sealed.
  7. Sep 30, 2016 at 4:22 AM
    #47
    DedDucks
    Lindale
    My drive shaft is not warm at front by transfer case. Just from that bearing toward the front of truck about half way down shaft so it's apparent the bearing is getting hot. The vibration/ low pitch noise is what bugs me now more than the shaft getting hot. But they are definitely related in my opinion as it didn't do it before bearing replaced. Perhaps drive shaft barely out of balance. Can see where they hit the U joint and knocked chips off right by that bearing. I suspect it doesn't take much to get the shaft off balance.
  8. Sep 30, 2016 at 4:28 AM
    #48
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Does anyone know: are these couplers greased, or is there oil; encapsulated around a bearing?
  9. Sep 30, 2016 at 4:35 AM
    #49
    bradwhitenikki
    Brad
    Orange... Huh... Imaging what it would be like if they gave you good advice.
  10. Sep 30, 2016 at 4:37 AM
    #50
    bradwhitenikki
    Brad
    Usually heat would come from bearing gall/out of round or too much friction in seals.
  11. Sep 30, 2016 at 11:07 AM
    #51
    cosmicfires
    David
    Everett, WA
    If it's too hot to touch by the bearing and not away from the bearing the bearing is going bad.
  12. Sep 30, 2016 at 11:16 AM
    #52
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I had the same problem. I removed the driveshaft and now just use 4wd. My gas mileage has increased 27% partially due to the fact that I removed the third member and the cooler wheel bearings that are now air cooled.
    12TRDTacoma likes this.
  13. Sep 30, 2016 at 12:14 PM
    #53
    DedDucks
    Lindale
    In today's edition of what's wrong with my carrier bearing/drive shaft? My new bearing is leaking and vibrations getting more noticeable. Thinking drive shaft is out of balance. Appointment Monday, we'llswe what happens.
  14. Sep 30, 2016 at 12:30 PM
    #54
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Another example of kaizen from Toyota.
  15. Sep 30, 2016 at 1:34 PM
    #55
    Kaerntner
    Kaerntner Well-Known Member
    2016 doublecab limited 4×4
    Aftermarket exhaust installed?
  16. Sep 30, 2016 at 1:41 PM
    #56
    DedDucks
    Lindale
    No, but maybe I should put one on to cancel the vibration/noise
  17. Oct 16, 2016 at 7:36 PM
    #57
    bucktowntaco
    bucktowntaco Well-Known Member
    New Orleans
    2017 MGM DCSB TRD Sport
    Noticed mine is leaking today while I was under there. I wiped the oil? off and I'll keep an eye on it and check it again in a few days.
  18. Oct 16, 2016 at 7:37 PM
    #58
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Fucking El oh el
  19. Oct 16, 2016 at 7:45 PM
    #59
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Could these bearings cause the howl that people are experiencing?
  20. Oct 16, 2016 at 7:46 PM
    #60
    DedDucks
    Lindale
    Now dealer says that's how they come. Packed with that oil and when it gets warm it may leak excess out. I ended up jacking rear tires off ground and checking drive shaft. It does not spin straight. Dealership finally listened to me and confirmed it was out of balance. Getting new driveshaft this week. We'll see if it fixes vibration/noise.
    Taco361 likes this.
