16x7" Wheels vs. 16x8"
Discussion in 'Wheels & Tires' started by Anthony250, Sep 2, 2012.
  1. Sep 2, 2012 at 11:34 AM
    Anthony250
    Anthony250 [OP] Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    I really wanted to know how big of a difference lets say a 16x7" wheel with 7mm offset vs a 16x8" wheel with -12mm offset is. Is it just the offset or the one inch and the offset? Or is it not really an one inch that makes it stick out farther but one inch over all?
    :eek:
    Thanks
  2. Sep 4, 2012 at 9:22 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    it's both. negative offset will always make it stick out more than positive offset. if both wheels have the same backspacing, the additional 1" width will stick out 1" more. take into consideration the tire size you plan to run as well. for instance, if you plan to use 285s, you'll probably need an 8" or wider wheel.
    corrected myself: meant BS in my reference, not offset:D
  3. Sep 4, 2012 at 11:29 PM
    Anthony250
    Anthony
    Rialto CA
    Thanks, i got some 8" wheels. In plan for some 285s in future.
  4. Sep 5, 2012 at 2:55 AM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Actually, wouldn't the additional 1" width balance on both sides if the offsets are the same?
    1/2" sticking out and 1/2" towards the suspension?
  5. Sep 5, 2012 at 10:09 AM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    Island Cruiser is absolutely correct. If two wheels have the same offset but different widths, you must divide the difference in widths by 2 to determine the clearance and stance differences.
    I.e. :
    16x7" 0mm offset
    vs.
    16x8" 0mm offset
    The difference is 1". Divide 1" by 2, since the 1" is spread evenly across the barrel of the wheel. The offsets are exactly the same, so the only thing affecting clearance is the added width. You'll have the 8" wide wheel .5" further to the outside of the fender well, and .5" closer to the suspension on the inside.
    If you wanted the new, 1" wider wheel to stick out a full 1" more compared to the 7" wide wheel, the new wheel would need to be 16x8" -13mm offset (-12.7mm to be exact, but offsets are not typically made in increments smaller than 1mm).
    xCaldazar likes this.
  6. Sep 5, 2012 at 10:15 AM
    JdMeF9SiR2
    Corona, CA
    I.e. :
    16x7" 0mm offset
    vs.
    16x8" 0mm offset
    The difference is 1". Divide 1" by 2, since the 1" is spread evenly across the barrel of the wheel. You'll have the wheel .5" further to the outside of the fender well, and .5" closer to the suspension on the inside. I used the example of 0mm offset because it's very easy to understand.
    0mm offset means the mounting pad of the wheel is exactly in the center of the wheel. So if you have two wheels that are both 0mm offset, and one is 7" wide and the other is 8" wide, you know that .5 of those inches will be to the outside of the center, and .5 of those inches will be to the inside of center.
    Now, to compare exactly with the measurements you provided:
    16x7" +7mm offset
    vs.
    16x8" -12mm offset
    The 16x8" -12mm offset wheels will sit outward (towards the edge of the fender or beyond) 1.25" additionally compared to the 16x7" +7mm offset wheels.
    The 16x8" -12mm offset wheels will have .25" more suspension clearance as well (they wheel will be .25" further away from the suspension).
  7. Sep 5, 2012 at 10:24 AM
    JdMeF9SiR2
    Corona, CA
    Here's something I just edited in Photoshop to help you visualize:
    vs.
  8. Sep 5, 2012 at 10:41 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    You're both confusing offset with backspace. Offset is related to the distance from the center of the wheel, not the lip of the inside rim.
  9. Sep 5, 2012 at 10:45 AM
    MadToy
    Nick
    Huntersville, NC
    I agree. Much easier to measure backspace also.
  10. Sep 5, 2012 at 10:47 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    you're absolutely correct. i wrote offset, but i think my mind was thinking backspacing, lol. good catch:D.
  11. Sep 5, 2012 at 10:53 AM
    Anthony250
    Anthony
    Rialto CA
    So how much it be sticking out further ?
    16x7" wheel 4.25" BS +7mm Offset
    vs,
    16x8" wheel 4.00" BS -11mm Offset.
  12. Sep 5, 2012 at 11:01 AM
    MadToy
    Nick
    Huntersville, NC
    1 1/4".
  13. Sep 5, 2012 at 2:55 PM
    JdMeF9SiR2
    Corona, CA
    As I mentioned above in the post with the pictures that I edited for reference:
  14. Sep 5, 2012 at 4:11 PM
    Island Cruiser
    Kauai
    Baja
    Nice illustration!!
    Np! I was afraid to correct you seeing you're a vendor/rep lol
  15. Sep 5, 2012 at 8:59 PM
    JdMeF9SiR2
    Corona, CA
    Thanks!
    And I don't think you should ever be afraid to correct someone if they're wrong, even if they are a vendor. That's how we all learn.
  16. Sep 5, 2012 at 10:04 PM
    Island Cruiser
    Kauai
    Baja
    That is true. It was a simple typo, he did know lol
  17. Sep 5, 2012 at 10:19 PM
    JdMeF9SiR2
    Corona, CA
    I agree. It's tricky sometimes posting on a forum. Our fingers can get going faster than our minds.
  18. Feb 11, 2020 at 12:49 PM
    jjgandarillas
    jjgandarillas Well-Known Member
    joseph
    Anc, AK
    SPORT DCSB MT
    ICON 2.5 VSRR, icon 2.0 ext travel, UCA’s, Ray 10 17x8.5 -12, 285/70r17 BFG Ko2
    8 years later and I’m on this thread
    vsyntax likes this.
  19. Sep 3, 2021 at 4:46 AM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    Old thread but still valid. As soon as I bought my 2021 OR, I upgraded rims to OEM Pros and unknowingly went from stock 16x8 to 16x7's. The tire shop that did my swap never brought up any issues or potential problems and they look great. I wanted to save some $$ and stick with the stock 265/70r/16 Wranglers for now. Is there any downside with smaller width such as handling? I owned a 2019 OR and now a 2021 and they both get a bit unruly in heavy winds on the interstate. Suspension is quite soft on this truck but very much appreciated on WI's rough roads.
    Condog4x4 likes this.
