16x8 0 offset rim, CMC???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by taco_boy, Sep 15, 2018.
  1. Sep 16, 2018 at 5:40 AM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    What are your wheel specs?
  2. Sep 16, 2018 at 6:10 AM
    marinemonkey
    marinemonkey Instagram - @tacomaturner @torxfabrication
    Cory
    Canton
    2016 Blue Toyota Tacoma TRD Off Road 4x4
    All-Pro Apex sliders Mobtown full skids SCS Ray 10s brushed copper Chevy 63 swap
    I have SCS Ray 10s 17x8.5 with -10 offset wrapped in 285/70/17 k02s E rated
    You can see how it looks on my truck on my Instagram @tacomaturnerfab
  3. Sep 16, 2018 at 6:14 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    It's covering a cut for rust prevention but also to protect your tires because without the plate you just have a really sharp piece of metal exposed there.
    That said, I ran post-cut, pre-plate for a couple weeks until I got around to it with 35s and no issues. Just wouldn't recommend it.
    marinemonkey likes this.
  4. Sep 16, 2018 at 6:14 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Also see thread in my signature for 255/85 info. It's my thread and it's massive lol
  5. Sep 23, 2018 at 2:27 PM
    Edgeman815
    Edgeman815 New Member
    Eric
    Florida
    2015 Red Tacoma TRD OFF-ROAD
    On my 2015 I fit a 285/75 on method 305s which is 16x8 with 0 offset, also with a 3-inch lift and I have no rubbing after I removed the mudflaps.
    taco_boy[OP] likes this.
  6. Sep 23, 2018 at 2:58 PM
    LostHusker
    LostHusker Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    Ok it reading the entire thread but but going by op original question. I have scs 16x8 rims stealth 6’s and running 285/75/16’s, with Toyo at tires. I had to do Cmc esp when backing up, in which I need to trim some more but it’s the plastic that is the main issue and not cab mount.
    FC_Taco and taco_boy[OP] like this.
  7. Mar 8, 2021 at 3:38 PM
    FC_Taco
    FC_Taco Member
    Christopher
    2017 TRD OR
  8. Mar 8, 2021 at 3:42 PM
    FC_Taco
    FC_Taco Member
    Christopher
    2017 TRD OR
    I have 265/75/16 Duratracs on my stock OR wheels and am transferring over to 16×8/0 offset in 2 days. Lifting next month with the works. CMC, UCA's and front bumper replacement. Would you say I could get away with no rubbing til then? I'm about to find out anyway, just lookin for feedback. Lol
  9. May 8, 2024 at 11:46 AM
    Jlevitt95
    Jlevitt95 Active Member
    Arizona
    '21 Cement Tacoma TRD OR
    Hey, did you have any rubbing with the 265/75/16 and 16x8 0 offset wheels before lifting? I'm about to pull the trigger on 16x8 0 offset Method 701's and LT265/75R16 (Load E) Falken Wildpeak's and I have stock TRD OR suspension.
  10. May 8, 2024 at 1:00 PM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    +1
    this is the way I rolled with 285/75R16 KO2 because I wanted to make sure no rubbing on and off road and good alignment. 2" lift and CMC and because I didn't want to futz around with a little slice here and push the fender liner there I bit the bullet on a viper cut. The CMC and viper cut are chaep compared to the suspension. As well went with SPC UCA to ensure proper alignment (You can probably get away the the OEM UCA though). The good thing is I am set up to go bigger (34 or 35) if I ever get to that point which so far I kind of doubt because I have plenty of clearance for what I do off road (not a rock crawler just moderate trails and sometimes some technical challenges but nothing too severe - maybe if I gain more skill I'll re-access).
