16x8 0mm stock height
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bear_okababa, Sep 11, 2017.
  1. Sep 11, 2017 at 8:17 PM
    bear_okababa
    bear_okababa [OP] Well-Known Member
    Honolulu, HI
    2017 Tacoma TRD OR DCSB MT
    Thinking of running 265/75/16 tires with 16x8, 0mm offset wheels at stock height on a 2017 TRD Sport Double Cab. Has anyone ran this setup without cutting/chopping and experiencing no rubbing issues?? Thanks.
    Also, if a wheel is 16x8 with 0mm offset it should fit regardless of brand is that correct? One manufacturer says that it will not clear the brakes, while another says should fit okay just may need to remove flaps. Both same dimension rims. Confused here why one could fit and not the other.
  2. Sep 11, 2017 at 8:39 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    You won't have any rubbing and you don't need cutting.
  3. Sep 12, 2017 at 2:11 AM
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Yup all day long. That's the ticket
  4. Sep 12, 2017 at 2:18 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Those will poke out 2" over stock, so there's a very good chance you'll at least rub the mud flaps.
  5. Sep 12, 2017 at 3:52 AM
    schmack b
    schmack b Well-Known Member
    Clarksdale, Mississippi
    2016 DCSB TRD OR M/T
    I have this set up and it will rub the back of the fender under hard compression and turning. Nothing a little trimming won't fix. I also tried to modify the stock mudflaps to fit without rubbing, but could not make them work.
  6. Sep 12, 2017 at 4:52 PM
    bear_okababa
    Honolulu, HI
    Thanks. What are you running on your wheels and tires?
  7. Sep 12, 2017 at 4:52 PM
    bear_okababa
    Honolulu, HI
    Thanks, what are you running?
  8. Sep 12, 2017 at 5:18 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    265/70/17s with a 17x8 0 offset wheel
  9. Sep 12, 2017 at 5:42 PM
    bear_okababa
    Honolulu, HI
    okay, curious what brand wheels and tires please?
  10. Sep 12, 2017 at 6:03 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Nitto Terra Grapplers
    Level 8 Mk 6
  11. Sep 12, 2017 at 6:09 PM
    schmack b
    Never mind this post. My wheels are not 0mm they are -12mm. So please disregard.
  12. Sep 12, 2017 at 8:04 PM
    bear_okababa
    Honolulu, HI
    good to know, appreciate the correction!
  13. Sep 12, 2017 at 8:50 PM
    Rowdymoon
    Rowdymoon Well-Known Member
    Courtice Ontario
    2017 Inferno OR SB Canada
    6112's and 5160's
    Only problem being is not a lot of wheel choices for 16"
