16x8 -5 with 265/75/16 on stock suspension?
Discussion in 'Wheels & Tires' started by slodc4, May 1, 2011.
  1. May 1, 2011 at 10:16 PM
    slodc4
    slodc4 [OP] Conceal Carry
    Steven
    Pink Hill, NC
    07 TRD SR5 offroad
    LIFTED
    hey guys!
    i really like the look of the countersteer type x's, but i cant seem to find them anywhere. So im thinking about getting the rota grid offroad type x's. (please, no comments about the quality of rotas)
    wheel specs:
    Wheel Style - Rota Grid Type-X
    Wheel Diameter (Inches) - 16"
    Wheel Width (Inches) - 8"
    PCD Bolt Pattern - 6x139.7
    Offset - -5mm
    Hub Bore - 110mm
    tire specs:
    265/75/16 duratracs
    this will be going onto my stock supension 07 offroad edition double cab.
    will they fit together? I have searched EVERYWHERE for info and im no good at reading wheel specs.
    thanks for any and all info!!!!!!!!!!!!!!!!!
    jeffmansion likes this.
  2. May 1, 2011 at 10:20 PM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    You will be fine as far as I know. I have the same size tire on a stock suspension.
  3. May 1, 2011 at 10:21 PM
    slodc4
    Steven
    Pink Hill, NC
    07 TRD SR5 offroad
    LIFTED
    ^yeah, i know the tire size itself will work, but will the rims offset make the tires rub?
    thanks though for your input
  4. May 2, 2011 at 6:09 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    That's 4.25" backspacing. You should be fine. Hub bore is large enough as well.
  5. May 2, 2011 at 4:27 PM
    slodc4
    Steven
    Pink Hill, NC
    07 TRD SR5 offroad
    LIFTED
    ^thank you
