16x8 Boost Fuel wheel and different tires
Discussion in 'Wheels & Tires' started by haider320, Apr 7, 2013.
  1. Apr 7, 2013 at 11:47 AM
    haider320
    haider320 [OP] Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    I know I am good with the Nitto Terra Grapplers on my stock suspension. 265/70r 16.
    I'm wanting to get the Boost 16x8 wheel from Fuel. I have read some wheels won't clear the front brakes. Anybody have these wheels and will it clear the brakes? Will I run into any problems with this wheel and tire combo?
    I also see Nitto has these tires in 75R size, but has E & D ratings. Some of them also have 123Q and 119Q. What does all of this mean?
  2. Apr 8, 2013 at 5:30 AM
    haider320
    Roswell, NM
    Nobody?
  3. Apr 8, 2013 at 5:59 AM
    kevinsc
    kevinsc 2012 dbl cab 4x4
    kevin
    columbia, south carolina
    12 4x4 dbl cab
    chrome on front painted to match, satoshi grill done by myself, BHLM, billys all the way around with ome springs upfront and LR ucas with wheelers 3 leaf progressive pack in the rear, mb gunner wheels powdercoated black on 285/75r16 nitto trail grapplers, tinted all the way around and on windshield, pioneer dbl din touch screen with two 10's behing the seat and new speakers all the way around and certain interior parts painted to match, also have a road wire leather kit black with red stitching sitting here waiting for me to find time to install it!
    I just recantly put 16x8 rims on my 2012 4x4 double cab and they fit just fine.. i could be wrong but i believe the trd models might have bigger brake calipers... but mine fit and cleared fine although not the same rims aas your going with.. mine are 4.5 backspaceing and -.06 backspaceing.. here is mine i know the tires look small but i am collecting parts for my lift and putting back money back for tires as money doesnt come easy
  4. Apr 8, 2013 at 6:06 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
  5. Apr 8, 2013 at 6:12 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    E and D mean load ratings, typically E is overkill for our trucks, D would be a better choice, the higher the load rating the heavier the tire. Just make sure you get the proper backspacing/offset and you wont have to worry about clearing the calipers. Depending on the offset you can probably run 265/75/16 with maybe minor trimming and removing the front mudflaps
