16x8 Konig CounterSteer Offroads
Discussion in 'Wheels & Tires Marketplace' started by JdMeF9SiR2, Apr 21, 2010.
  1. Nov 26, 2012 at 3:15 PM
    #1021
    JdMeF9SiR2
    JdMeF9SiR2 [OP] FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    11/26/2012:
    Matte black is officially sold out in sets of four.
    I have one wheel in stock right now. Konig's next shipment is expected mid-December (about 2-3 weeks from now).
    I do have a couple sets of graphite gunmetal available right now.
  2. Dec 10, 2012 at 12:04 PM
    #1022
    JdMeF9SiR2
    Corona, CA
    Graphite gunmetal is still in stock!
    More matte black and matte bronze will be arriving very soon!
  3. Dec 12, 2012 at 10:34 PM
    #1023
    motorsport36
    motorsport36 Black Lights Matter
    Furnace, AZ
    98 SR5 AC 4x4
    I love these wheels so much that this will be my third set that I order. Do you have a wheel for the guys running a 6 inch lift? Lemme know. Thanks
  4. Dec 14, 2012 at 8:40 AM
    #1024
    ElTacoCaliente
    ElTacoCaliente Well-Known Member
    Charlotte, NC
    2012 Ram Power Wagon ST
    Couple quick questions for you about these wheels-
    Since they are not hub centric, do I need to run a hub centering adapter to use them?
    Would they fit 265/75R16 on a 2013 SR5 stock? (I'm thinking the wheels' width would be a problem?) (I wanna do a lift and 285's but, looking like the wife won't go for that plan)
    Would it be possible to get a set of 5 in the gunmetal?
    Thanks!!!!
  5. Dec 14, 2012 at 8:52 AM
    #1025
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    When I put them on with 265/75r16 my tires rubbed on the front little mudflap, I took it off and they didn't rub. That was back when I had the 5100 at .85 with stock coils, so i was pretty close to stock height. The 0 offset is the culprit for the rub. You should be fine if you take the little front flap off.
  6. Dec 14, 2012 at 9:00 AM
    #1026
    GRAFH
    GRAFH Active Member
    Vernon Hills, IL
    1993 pickup aka hilux
    I thought they were hub centric? If they are not then yes you do need to install a ring.
  7. Dec 14, 2012 at 3:20 PM
    #1027
    JdMeF9SiR2
    Corona, CA
    Awesome! Thank you! If you have a 6" lift, I think you might like FN Wheels' new wheel (the owners of FN designed the Countersteer Offroad with Konig a few years back):
    This new wheel will be a 16x8" with a -25mm offset, so it will have a much more aggressive stance do go with your 6" lift. I'll PM you as well.
    ElTacoCaliente - Good questions! Thank you.
    -The wheels include both hub centric rings and push-thru center caps. The caps have an internal diameter of 106mm, so the caps will center the wheels on the hubs, or if you prefer not to use the caps you can use the rings we provide.
    -As SconnieHailer mentioned, the wheels will fit your stock 2013 Tacoma SR5 Pre-Runner with 265/75R16 tires. You'll have a slight rub on the front mud flaps, and you can either trim the mud flaps to accommodate the taller tires and wider wheels, or you can just remove the mudflaps altogether (I'd remove them myself). Other than that they fit perfectly, and there have been quite a few Tacoma owners with this exact setup over the years who love it.
    -I can definitely put together a set of five (5) wheels in graphite gunmetal for you, no problem. :)
  8. Dec 19, 2012 at 9:12 PM
    #1028
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Does anyone have a picture with the bronze rims on a silver Tacoma?
  9. Dec 20, 2012 at 8:18 PM
    #1029
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
  10. Dec 20, 2012 at 8:39 PM
    #1030
    GRAFH
    GRAFH Active Member
    Vernon Hills, IL
    Any pics of trucks with the anodized bronze?
  11. Dec 21, 2012 at 8:33 PM
    #1031
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
  12. Dec 21, 2012 at 10:18 PM
    #1032
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
  13. Dec 22, 2012 at 3:43 PM
    #1033
    GRAFH
    GRAFH Active Member
    Vernon Hills, IL
    Looks good, are they just dirty? Because they look matte bronze.
  14. Dec 22, 2012 at 5:07 PM
    #1034
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    The pictures do little justice. They are clean.
  15. Dec 25, 2012 at 3:50 PM
    #1035
    GRAFH
    GRAFH Active Member
    Vernon Hills, IL
    Taiwan made Volk knockoff's ftw!
  16. Dec 27, 2012 at 3:07 PM
    #1036
    JdMeF9SiR2
    Corona, CA
    motorsport36 and mr.trd - Thank you for posting your photos!
    PMs sent to everyone else inquiring.
  17. Dec 27, 2012 at 3:08 PM
    #1037
    JdMeF9SiR2
    Corona, CA
    Darn right. I've had a set of 16x8" Countersteer Offroads on my Tundra and a set on my Tacoma for nearly 5 years. I've towed 3,500lbs trailors, taken them offroad, and never had a problem. Prior to that I did have Volk TE37s, and I never had a problem with those either.
    Taiwan makes excellent products. Much, much better than China.
  18. Dec 27, 2012 at 3:10 PM
    #1038
    JdMeF9SiR2
    Corona, CA
    Back in stock as of today:
    -16x8" Konig Countersteer Offroad - matte black - 6x139.7 et 0mm (4.5" back spacing)
    -16x8" Konig Countersteer Offroad - anodized bronze - 6x139.7 et 0mm (4.5" back spacing)
    Also in-stock
    -16x8" Konig Countersteer Offroad - graphite gunmetal - 6x139.7 et 0mm (4.5" back spacing) - low stock - 10 wheels (2.5 sets) available
  19. Dec 27, 2012 at 9:51 PM
    #1039
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Here at Tacoma World there is a growing following for the "tall and skinny" tires best described as the BF Goodrich KM2 in the size 255/85R16 (and a couple other tires in this size). We are having difficulty finding suitable wheels for this size tire as most aftermarket wheels are 8" wide or more and this is just too wide for this tire.
    One reader suggested that Konig might do a special run of wheels in 16x7 if there was enough gauranteed sales. Can you verify this? And if so how many wheels would be required to have Konig build them? 10 sets (40 wheels) or 25 sets (100 wheels?). Just putting out a feeler because the market is very slim for 16x7 wheels outside of a couple steel items.
  20. Dec 27, 2012 at 9:52 PM
    #1040
    GRAFH
    GRAFH Active Member
    Vernon Hills, IL
    8" is not too wide for that tire.
