16x8 Konig CounterSteer Offroads
Discussion in 'Wheels & Tires Marketplace' started by JdMeF9SiR2, Apr 21, 2010.
  1. Aug 28, 2013 at 4:30 PM
    #1321
    JdMeF9SiR2
    JdMeF9SiR2 [OP] FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    No problem Chris! I'll still be here whenever you're ready, and we have regular shipments from Konig too. :) Take your time! :):):):)
  2. Sep 3, 2013 at 9:53 PM
    #1322
    JdMeF9SiR2
    Corona, CA
    I hope everyone had a great Labor Day! I've responded to all PMs. :)
  3. Sep 4, 2013 at 5:29 AM
    #1323
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I've realized getting that 5th wheel from you was both good and bad. I'm happy to finally have a full size spare again but now I have to wait even longer for these tires to wear out before I can get the ones I want. Haha
  4. Sep 4, 2013 at 6:04 PM
    #1324
    JdMeF9SiR2
    Corona, CA
    Uh oh! :eek:
    Is it time to ride the current tires really hard so you can justify buying new ones? :D
  5. Sep 8, 2013 at 5:36 PM
    #1325
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  6. Sep 9, 2013 at 1:24 PM
    #1326
    jameskhana
    jameskhana Maibatsu Monstrosity
    James
    Dallas, TX
    2007 DCSB Base 4x4 6spd
    Very nice ^ Seeing your truck I kinda wish I had stuck with 265's instead of moving up to 285's...
  7. Sep 9, 2013 at 5:10 PM
    #1327
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    255-265 > 285+ on 33" of tire or less :)
    35"+ is obviously a different ball game.
  8. Sep 9, 2013 at 5:11 PM
    #1328
    BuzzardsGottaEat
    Some Toyotas
    Round tires
  9. Sep 10, 2013 at 3:31 AM
    #1329
    T1no33
    T1no33 Well-Known Member
    Spring Hill, Fl
    2012 PreRunner V6 SR5
    - Partial Badge Removal & Dipped - Removed Mud Flaps - Blacked out Emblem - Blacked out Chrome Surrounding Grill - Salex Center Console Organizer - AntennaX 13" - Tinted Front Windshield - Derped Tacoma Emblems - Bridgestone 265/70/16 tires - Tuff AT Wheels - 3 and 1 spacer block lift (mistake big time) - Black Rear Bumper - Aries Bull Bar w/light rig
    I have 265s now and really want to jump to 285s. Why do you wish you hadnt had the jump. Please share so maybe I wont spend money on tires and get these wheels instead!
  10. Sep 10, 2013 at 1:31 PM
    #1330
    JdMeF9SiR2
    Corona, CA
    Such a clean truck and beautiful scenery! Thank you! I could look at photos like this all day and never get tired of them.
    I can't speak for Jaime, but speaking from personal experience:
    265/75R16 works better with 1.75" or less of lift. With a 1.75" lift you really don't have to modify any plastics or mud flaps at all.
    285/75R16 works better with 2.25" - 3.0" of lift.
    Furthermore, 285/75R16s are going to be a little heaver due to the extra material/mass of the tire, and the overall diameter is going to make your gears a little longer, so it's a little harder to get the truck going from a stop / slow speed, and you'll also reduce your gas mileage.
    Depending on how heavy duty your offroading activities are, and depending on your exact suspension setup, you may benefit from one tire size over the other as well.
  11. Sep 11, 2013 at 6:26 AM
    #1331
    T1no33
    Spring Hill, Fl
    Depending on how heavy duty your offroading activities are, and depending on your exact suspension setup, you may benefit from one tire size over the other as well.[/QUOTE]
    Man, thank you so much for that reply. I only do small light off road stuff. I do like the look of the bigger tire so maybe I'm better off with the smaller tire as gas is so darn expensive. Thanks again.
  12. Sep 11, 2013 at 6:52 AM
    #1332
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    With 16x8 konigs, the 285/75/16 tires, and a full 3" lift, is it likely that I'd have to trim the mudflaps or anything else for clearance?
  13. Sep 11, 2013 at 7:53 AM
    #1333
    bullaculla
    Da big big island!
    You might also need to do a cab mount chop too.
  14. Sep 11, 2013 at 8:00 AM
    #1334
    bullaculla
    Da big big island!
    Thanks! Using that one as my desktop right now. If you want a higher res file, let me know :)
    Still so in love with my wheels! :D thanks Dustin!
  15. Sep 11, 2013 at 8:01 AM
    #1335
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    ya, mudflaps will have to come off and you'll need to add a bit of caster. To stay safe offroad with suspension cycle you'll need to hammer your pinch weld and possible body mount chop.
  16. Sep 11, 2013 at 3:29 PM
    #1336
    jameskhana
    James
    Dallas, TX
    Yep that's about it. I've traded quite a bit of get up and go, and definitely mpg, for essentially 1/2" of extra ground clearance. Granted I picked the heaviest 285 tire possible (Toyo M/T's = 68 lbs :eek:), but I wanted maximum offroad grip and the toughest sidewalls for the terrain down here in AZ.
    Yaozer I also had to trim quite a bit of the fender flares and inner fender plastic, in addition to the pinch weld and everything else SconnieHailer and bullaculla mentioned.
    285's do look badass though :D
  17. Sep 11, 2013 at 5:53 PM
    #1337
    JdMeF9SiR2
    Corona, CA
    Thank you bullaculla , SconnieHailer and Jaime for your responses and input. The more first hand info we have the better. :)
    No problem! That's what we're here for. :) If you have a 1.75" - 2.0" lift the 265/75R16 tires will fill up your wheel well very well and look great.
    If you go 2.25" - 3.0" and you really want a larger tire, but don't want to sacrifice as much gas mileage and acceleration (and you don't do heavy duty crawling and hard core offroading) you can always go with a 285/75R16 A/T (all-terrain rather than an aggressive M/T tire like Jaime). It will be lighter, have less rolling resistance and the overall diameter will be a little bit shorter than an M/T tire in the same size.
    If the tire is an all-terrain (A/T) I've installed enough to say with almost 100% certainty for all brands that you won't have to do the cab mount (aka body mount) chop. You'll just need to trim and/or remove mud flaps, trim the fender liner, and possibly trim a small portion of the inside of the plastic over fender (all easy to trim plastic parts that won't be noticeable once trimmed).
    Alternately, as bullaculla, SconnieHailer and Jaime mentioned, I have installed enough 285/75R16 M/T (max terrain aka mud terrain) tires to know that you will likely have to do the body/cab mount modification.
    Even though the sizes are the "same," M/T tires just about always run wider and taller than their A/T counterparts.
    Let me know what tire you are planning to get, and I'll go over the dimensions and potential modifications with you.
  18. Sep 11, 2013 at 10:04 PM
    #1338
    bullaculla
    Da big big island!
    Hmm... I'd rather run a 265 MT than a 285 AT :D
  19. Sep 12, 2013 at 9:04 AM
    #1339
    T1no33
    Spring Hill, Fl
    I know this isn't the correct thread so this will be the LAST question I ask here about tires. Does anyone have any experience with P235/85r16s? I'm finding that they are 1/2" shorter than 285s and they don't affect the speed/gears as much. Thoughts?
  20. Sep 16, 2013 at 12:09 PM
    #1340
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I'd sent off and email in regards to shipping to Canada. Any idea on rates?
    Thanks! :)
