16x8 Konig CounterSteer Offroads
Discussion in 'Wheels & Tires Marketplace' started by JdMeF9SiR2, Apr 21, 2010.
  1. Jan 8, 2017 at 3:23 PM
    #1881
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I'm looking for pics of mine right now when i had stock springs. Its blue and yellow paint marks?
    Edit: NVM see rainbowyaks post
  2. Jan 8, 2017 at 3:23 PM
    #1882
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    They should've removed some material to save weight then. Previous design was strong enough. More than a few people have jumped them in LT trucks and they've held up fine.
    I like the edgier "new" design though, looks closer to the Volks which these are supposed to emulate. I suspect it was the motivation for the design tweak.
    If you zoom in to full-size picture, "16X8" is visibly cast into the rim.
    AR15xAR10[QUOTED] likes this.
  3. Jan 8, 2017 at 3:27 PM
    #1883
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Thanks!
  4. Jan 8, 2017 at 3:29 PM
    #1884
    SconnieHailer
    Marc
    Mine have been beat to death over the last 4 years. See sig pic haha. I've got over 50k miles on mine now
    AR15xAR10 and KenLyns[QUOTED] like this.
  5. Jan 8, 2017 at 3:37 PM
    #1885
    01 dhrracer
    Still Shopping
    Yes they do have the brown plastic sleeve over the top coil. Checked the colors- drivers side has 2 white dots and 2 pink donts/passenger has 2 white and 2 orange dots. Not sure if the shop that installed the 5100's payed attention which spring came off each side. I find that I have close too 1/2 lean.
  6. Jan 8, 2017 at 3:48 PM
    #1886
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Love seeing that pic by the way!:thumbsup:
    AR15xAR10 likes this.
  7. Jan 8, 2017 at 3:51 PM
    #1887
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    The ones with those outer markings like that, are typically the flow formed ones
  8. Jan 8, 2017 at 3:52 PM
    #1888
    AR15xAR10
    Have them swap the coils. That should fix it.
    OR, you can get aftermarket coils and a small driver's side spacer like i did
  9. Jan 8, 2017 at 3:52 PM
    #1889
    AR15xAR10
    Absolutely!
    Same goes for the rear suspenion too.
  10. Jan 8, 2017 at 3:56 PM
    #1890
    01 dhrracer
    Still Shopping
    I will find a real level spot and tak more accurate measurements. I found a post of yours from 2014 and you found white/pink drivers side and white/orange passenger. Mine are this way. Your truck from Cali-mine too and someone else had different colors but was from Texas. My work was done a while ago and hopefully in the near future I will be changing aal of it anyhow. I want more lift and will be adding more weight to the rear.
  11. Jan 8, 2017 at 4:53 PM
    #1891
    AR15xAR10
    My truck is an 08, built in cali. It didn't have any of those paint markings that i remember, pribably because the suspension had 50000 hard miles. I bought some new truck take off suspension from a 2013 and they were white for passenger, yellow for driver's marked. Plus i've had to ask others before too
  12. Jan 8, 2017 at 6:29 PM
    #1892
    01 dhrracer
    Still Shopping
    Thanks for the info. Not something I am going to worry too much about. I do have a 1/4" spacer that I most likley will install on drivers side than realign. Also trying to find another shop that trully understands alignments on Tacoma's or are just a bit more anal about the details. Last alignment the numbers are not what I was looking for escpecially caster. However it does not pull drives pretty good but I want more caster and less +camber on passenger side.
  13. Jan 9, 2017 at 4:25 PM
    #1893
    ERMB
    2002 Land Cruiser
  14. Jan 9, 2017 at 4:31 PM
    #1894
    AR15xAR10
    Needs more wheel ;)
  15. Jan 9, 2017 at 4:48 PM
    #1895
    ERMB
    2002 Land Cruiser
    Zoom in :p
  16. Jan 9, 2017 at 6:50 PM
    #1896
    AR15xAR10
    I'm saying you need 17s ;)
  17. Jan 9, 2017 at 8:17 PM
    #1897
    ERMB
    2002 Land Cruiser
    Lol, you buying? :D
  18. Jan 9, 2017 at 8:57 PM
    #1898
    AR15xAR10
    Not hardly
  19. Jan 24, 2017 at 5:53 PM
    #1899
    ERMB
    2002 Land Cruiser
  20. Feb 15, 2017 at 6:55 AM
    #1900
    KenLyns
    Belly of the Beast
    I just bought a 5th wheel from Cochrane Toyota for mounting the spare. Spoke design is slightly different from my original set in 2012. Don't mind the color difference as the photos are taken five years apart under different lighting colors.
    Old:
    y_7BuOBY8-TsjmHV1520GonCOj-tz-7MHv3nMrhp_8b7a0558bd7bd89cfae9faafda95f65e8b3aca92.jpg
    New:
    i2Np2ZK38Sc-0BodjzEuQjQMs5D5HnDjfDGLl3_4_632c7a9a3bd4c266d035ac8a1738e9beda09049e.jpg
    The hub pad is now hogged out between lug holes, so weight has not increased (16 lb measured on my bathroom scale - lighter than advertised in page 1). I'm happy. :)
    JoT97lHffYXTYsRylfKSUa5KSg3ZM97NPMzlH0oF_3d81ba74cb51a2a7ec56832f51f47aaefb638f4c.jpg
