16x8 motometal 951
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Susie Q, Mar 26, 2010.
  1. Mar 26, 2010 at 9:14 AM
    Susie Q
    Susie Q [OP] Well-Known Member
    Susie
    FL
    05 PreRunner SR5 2.7L 5spd Manual
    6" Pro Comp Suspension Lift, 35" BFG Mud Terrains, 18" Motometal 951, Tint, More to come..
    Bolt Pattern: 6 on 5.5
    Diameter: 16.00 "
    Width: 8.00 "
    Style: MO951
    Finish: Black
    Construction: Aluminum
    Backspace: 4.50 "
    Max Load: 2200 lbs
    Hubcentric: No
    I have an 05 regular cab prerunner with a 6 inch pro comp lift on the way. I plan on purchasing wheels and tires within the next week or so. I would really like to slap those motometals on with some 35 inch pro comp tires. Will it work? Is that enough backspacing? I'm open to any and all advice. Thanks.
  2. Mar 26, 2010 at 9:15 AM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    :redxfall:They should fit
  3. Mar 26, 2010 at 10:48 AM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    i'd say so too
  4. Mar 26, 2010 at 11:47 AM
    Susie Q
    Susie
    FL
    Is 4.50 back spacing enough? I was thinking since its a 6 inch lift that it might look tall and not wide.
  5. Mar 26, 2010 at 11:53 AM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    i thought you had to have 17 inch wheels with a six inch lift
  6. Mar 26, 2010 at 12:20 PM
    Susie Q
    Susie
    FL
    lol do i? That's why im posting. Theres only so much a girl can know. lol
  7. Mar 26, 2010 at 12:22 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    im pretty damn sure but someone will chime in that knows excatly what they're talking about
  8. Mar 26, 2010 at 12:27 PM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    Due to the new parts you're getting for the 6" lift a 16" wheel wont clear the space. You'll have to get 17" or higher and since 17" is a rare tire you might as well do an 18" wheel... Check out my pics and you'll see 305/75/R18 with a 6" lift..
  9. Mar 26, 2010 at 12:27 PM
    Susie Q
    Susie
    FL
    I ordered my lift last friday to pick up in the 4wheelparts store and they havent called me yet to pick it up. I think I'll ask them when I get there what my choices are for wheels and tires. I read on some threads that they will usually cut you a deal if you buy at the store.
  10. Mar 26, 2010 at 12:29 PM
    Susie Q
    Susie
    FL
    Kyle, your truck looks great but I think Im gonna go with as little rim size as I can because i love the look of big tires and little rims. I might just have to take your advice and go with the 17s
  11. Mar 26, 2010 at 12:37 PM
    SuthrnTaco07
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    The reason you have to do this is because (i can't remember the exact term) the joint used to connect your upper and lower A-Arms is a smaller than the one they have to replace it with so when they replace it with the new one it is bigger than a 16 inch wheel can fit. Also becareful with the backspacing.. You should be good but but if you don't have enough you will have to ditch your sway bar. I am pretty sure i have a 5.0" backspacing and that is the most you can have... The lower the number the better. ecause i have that i ddon't have a sway bar anymore.. Cons - A little more boating feeling on the highway driving. Pro- better offroad capability!
  12. Mar 26, 2010 at 1:37 PM
    Susie Q
    Susie
    FL
    Okay, great. Thanks. I was looking for some with little backspacing because i want them to stick out a little bit. I think I'll save a little longer and go with the 17s. You think 4.53 backspace and offset of -12mm okay? Im not sure what the offset is
