16x9 wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1stgen7, Aug 2, 2010.
  1. Aug 2, 2010 at 11:41 AM
    1stgen7
    1stgen7 [OP] Member
    Salt Lake City
    03 TRD SR5 4x4 XtraCab
    I was planning on getting some ATX Artillery wheels, but they are 16x9. Will these fit an 03 4x4 TRD with stock suspension without any problems. Stock size tires as well. Backspacing is 4.5" offset is 12mm. Thanks.
  2. Aug 2, 2010 at 5:01 PM
    1stgen7
    1stgen7 [OP] Member
    Salt Lake City
    Bump. No one knows?
  3. Aug 2, 2010 at 5:03 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    They'll fit fine...
    Make sure they are 6 lug on 5.5
  4. Aug 2, 2010 at 7:42 PM
    1stgen7
    1stgen7 [OP] Member
    Salt Lake City
    Thanks. They are the correct bolt pattern. I assume they just stick out 2 inches further since the backspacing is the same. Would this likely cause any rubbing?
