17 inch TRD wheels Matte Black.
Discussion in 'Wheels & Tires' started by Unchained 5150, Jan 31, 2015.
  1. Jun 5, 2020 at 9:11 AM
    #2021
    onesixonetwo
    onesixonetwo Well-Known Member
    What headlights do you have?
  2. Jun 5, 2020 at 12:58 PM
    #2022
    Dampahee
    Dampahee Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
    Morimoto XB
    onesixonetwo[QUOTED] likes this.
  3. Jun 8, 2020 at 1:01 AM
    #2023
    nai_hiro
    nai_hiro Instagram: _whitetac0
    2019 Super White Toyota Tacoma Off-Road
    did you have to cmc or do any trimming?
    I have the stage 4 6112/5160 from runnin4tacos with SPC upcs.
    https://www.runnin4tacos.com/produc...spension-kit-2005-2020-toyota-tacoma-lift-kit
    still have the stock trd off road wheels as of now though. been quite curious if 285s would fit no problem. I’m a big fan of the nitto ridge grapplers too that’s why. was told by my father to stick with a 265/75/16 to be safe but was curious to see if 285s could potentially fit.
  4. Jun 8, 2020 at 4:52 AM
    #2024
    MW20Taco
    MW20Taco Well-Known Member
    Mykle
    2020 TRD OR Premium
    prob answered but yes... TMPS is specific to the vehicle. As long as you use the same TMPS on that Vic you can swap wheels... even then some can be interchangeable and reset (typically within the same manufacturer). Valve holes are pretty much the same in every wheel. Unless it’s a commercial/ high performance Vic.
  5. Jun 8, 2020 at 4:58 AM
    #2025
    MW20Taco
    Mykle
    2020 TRD OR Premium
    Nitto RG!!! 285/70? What load range?
    Edit:
    Found the answer! What load range? I have them on my truck but they put Pmetrics on and I hate the looks. Rounded shoulder or something. Ordered new ones, I can’t get over it.
    Also just ordered 6112/5160s.
    So essentially you are running a 2-3 lift? Thought the 5160 was only rated for 1.5? Is the AAL option squeekey?
    I think I am just doing a 1” block.
  6. Jun 8, 2020 at 7:12 AM
    #2026
    Dampahee
    So Cal
    2019 TRD Off Road
    0 rubbing for daily driving. I did go out for some hard wheeling this last weekend and I do rub a bit on fender wall and driver side rear fender and it is very minimal. I probably won't trim anything and no need for CMC. I do have Camburg uniballs and caster is 4+. But take this with a grain of salt, all trucks have slight variations.
  7. Jun 8, 2020 at 7:14 AM
    #2027
    Dampahee
    So Cal
    2019 TRD Off Road
    I'm under 2 in bro and no squeaks from my leaf packs. I did pull them apart and grease each individual leaf during install. And my tires are C load.
  8. Jun 9, 2020 at 2:19 AM
    #2028
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    Looks really nice , think I’ll do that
  9. Jun 22, 2020 at 10:01 AM
    #2029
    StealYourFace
    StealYourFace Well-Known Member
    Reno/Sparks
    2020 ORDC MBM
    I am planning to get these wheels for my ORDC, and am wondering if anyone can confirm that 255/75/17 should fit on the stock suspension?
    Seems like they should but I am worried that they will rub.
  10. Jun 22, 2020 at 11:07 AM
    #2030
    -Rorschach-
    -Rorschach- The Black Helicopters are coming…I gotta go!
    2019 Silver Sky Metallic Tacoma DCLB TRD OR 4x4
    You may want to check out the Skinny Tires thread if you have not already...
    https://www.tacomaworld.com/threads/the-skinny-on-skinny-tires.529656/
    StealYourFace[QUOTED] likes this.
  11. Jun 22, 2020 at 12:03 PM
    #2031
    StealYourFace
    Reno/Sparks
    2020 ORDC MBM
    -Rorschach-[QUOTED] likes this.
  12. Jun 22, 2020 at 1:47 PM
    #2032
    JAStaco
    JAStaco Well-Known Member
    MT
    2013 Tacoma DCLB
    Elka 2.5 RR w/ adjusters front and rear, JBA UCA's, Icon RXT, SEMA 4R pro wheels, Meso Customs interior lights, Wheeler's Superbumps front and rear
    You should easily clear the 255/75, especially on a 3rd gen. Absolute worst case you may have to heat up and form a small spot/area of the mud flap a little, but with a 255 I doubt you'll even have to do that.
  13. Jun 23, 2020 at 8:13 AM
    #2033
    StealYourFace
    Reno/Sparks
    2020 ORDC MBM
    Thanks for the confirmation, I assumed so based on tire size calculators etc. I appreciate your feedback.
  14. Jun 26, 2020 at 4:47 AM
    #2034
    Castle 4
    Castle 4 Well-Known Member
    Dan
    Richmond, VA
    2018 TRD Sport DCSB
    Bilstein 6112 / 5160, Icon RXT Stage 3, JBA UCAs, SmartCap Evo Sport, Falken Wildpeaks 275/70R17s; TRD Pro wheels
    With the lettering fading after only 1 year, I added some new life and color back to my rims. Thanks @rrentrop! As always, great quality products!
    onesixonetwo and markram like this.
  15. Jun 29, 2020 at 7:30 PM
    #2035
    Rampage224
    Rampage224 New Member
    Scott
    2020 Toyota Tacoma TRD Sport
    Bought a 2020 Black TRD Sport a month ago and received my black TRD rims from Bam Wholesale. I had the truck and rims ceramic coated.
    I went to Costco for tires and installation and said they didn't fit. The tech put tested the rim fit with out the tire and could get the rim but the rim would not go all the way. I witnessed him with another rim with the same result. Anybody have any thoughts? Unfortunately I did not take any pictures.
  16. Jun 30, 2020 at 5:15 PM
    #2036
    rigoberd
    rigoberd Well-Known Member
    Rigo
    2019 Off Road DCLB
    What size are your tires? And does the spare fit under the truck?
  17. Jun 30, 2020 at 5:37 PM
    #2037
    Dampahee
    So Cal
    2019 TRD Off Road
    285-70-17 and I don't have mine under the truck. I gonoff roading every weekend and need it more accessible if something were to happen. But there are a lot of posts where folks have fitted that size under the truck.
    rigoberd[QUOTED] likes this.
  18. Jun 30, 2020 at 5:45 PM
    #2038
    rigoberd
    Rigo
    2019 Off Road DCLB
    Thanks man. Im look for bigger wheel and tire since I feel like it'll look better with my long bed. Ideally I would want skinny 33s on with these rims but I'm a bit confused on whether they would fit or not on the sema wheels
  19. Jun 30, 2020 at 10:42 PM
    #2039
    Dampahee
    So Cal
    2019 TRD Off Road
    I was confused too after a lot of reading. Wanted 285 but didn't want a cmc either. Then I looked a pizza cutters cause I heard they don't rub, but then heard they rub with these wheels. Went back and forth for a while and finally decided if I'm going to rub i'll get what I want and went with 285-70-17. I did also get uca's and have caster at 4 plus degrees and I do not rub at all daily driving. I also wheel pretty hard and have minimal rubbing on driver side only. And not the can mount, on a piece of plastic. I haven't even bother trimming since it's so minimal. My suggestion is get what you really want and good luck!
  20. Jul 3, 2020 at 2:54 PM
    #2040
    AZ_Taco16
    AZ_Taco16 Member
    Couple questions for the group on these wheels and tire setups.
    Seems to be everyone is running the OEM TRD Pro Wheels from the 4Runner. Are these the 17x7 -4 MM offset?
    Also i see a lot of people are running the 265/70/17 Wildpeaks or K02s with no rub on stock suspension. Has anyone tried a Nitto Ridge Grappler in the same size and what was their experience with them?
