17 inch TRD wheels Matte Black.
Discussion in 'Wheels & Tires' started by Unchained 5150, Jan 31, 2015.
  1. May 5, 2016 at 9:32 AM
    #1241
    mrSM1TTY
    mrSM1TTY Well-Known Member
    Charlotte, NC
    2015 TRD Off-Road
    That makes sense. I have Spidertrax 1.25" spacers. I'll give that a try when I have a chance to remove them.
  2. May 5, 2016 at 6:13 PM
    #1242
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Those look great. Is that matte gray or black?
  3. May 5, 2016 at 7:55 PM
    #1243
    boomah
    boomah New Member
    Anybody running these on a stock 1st gen pre runner?
  4. May 6, 2016 at 6:56 AM
    #1244
    mrSM1TTY
    Charlotte, NC
    2015 TRD Off-Road
    Thanks! Went with the black.
  5. May 6, 2016 at 7:33 AM
    #1245
    TacoNole7
    TacoNole7 Well-Known Member
    Sebastian, FL
    2011 Super White Tacoma Pre-Runner
    I ordered mine today. About 2 hours ago. Excited but a little worried about rubbing and what not when I get the tires as well.
  6. May 6, 2016 at 11:25 AM
    #1246
    Daxdagr8t
    Daxdagr8t Well-Known Member
    Socal
    07 prerunner
    None
    Think 1st gens are 5 lugs. These are 6 lugs
  7. May 6, 2016 at 8:59 PM
    #1247
    fishnhunt2
    fishnhunt2 Member
    Yoman, where did you get the black lug nuts?
  8. May 7, 2016 at 8:24 AM
    #1248
    yoman321
    yoman321 Member
    chuck
    blaine wa
    86 4runner, 88 2wd pickup, 13 trd off road
    Found them on ebay. Even found some gorilla lock nuts. 262259179109 is the item id for the lug nuts. They were under 30$. The lock nuts 400450710956, about 20$. I just did a search for toyota lugs. They need to be mag lug with, 12x1.5. I didn't even think about the tpms sensor tho, they're gray :-(.
    Siblue likes this.
  9. May 7, 2016 at 1:21 PM
    #1249
    fishnhunt2
    fishnhunt2 Member
    Thanks youman! Wasn't to thrilled about re-using the oem chrome. Are you running 265s or 275s?
  10. May 8, 2016 at 7:27 AM
    #1250
    yoman321
    yoman321 Member
    chuck
    blaine wa
    265/70. I wanted to stay with a stock tire size, but my stock rim was 16. I'm not sure how it's changed because the new rim is 17. I did remove the front mud flap because it rubbed. I have a 3" lift
  11. May 8, 2016 at 10:38 AM
    #1251
    TacoNole7
    Sebastian, FL
    Siblue likes this.
  12. May 9, 2016 at 6:25 AM
    #1252
    fishnhunt2
    fishnhunt2 Member
    I think the only difference between a 16' 265 and a 17' 265 is sidewall height, the 16 having a larger sidewall.
    I also remember reading in one of the million post that I have read, these wheels have a different back spacing compared to the stock sport wheels. The back spacing may have caused the slight rub you experienced.
    Thanks again for the info!
    yoman321[QUOTED] likes this.
  13. May 9, 2016 at 6:27 AM
    #1253
    fishnhunt2
    fishnhunt2 Member
  14. May 9, 2016 at 10:54 AM
    #1254
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    TacoNole7[QUOTED] likes this.
  15. May 9, 2016 at 11:46 AM
    #1255
    TacoNole7
    Sebastian, FL
    Siblue[QUOTED] likes this.
  16. May 9, 2016 at 12:23 PM
    #1256
    TacoNole7
    Sebastian, FL
    mrSM1TTY likes this.
  17. May 11, 2016 at 9:39 PM
    #1257
    Maint1
    Maint1 Well-Known Member
    NC
    2019 DCLB Quicksand
    17" matte black 4Runner rims
    Without going back through all posts, what SIZES tires will these rim accept. Right now I have the stock 265/65r17. Could I order the rims and use my old tires then say go to a wider tire, such as a 270 or 275. As long as I keep the 17" I should be able to vary a little on width, right???
  18. May 12, 2016 at 5:49 AM
    #1258
    TacoNole7
    Sebastian, FL
    As far as I know yes. That setup is used a lot. I opted to go as large as I could stock which is 265/70/17. 270 or 275, you'd need a lift for or risk serious rubbing. I haven't had my truck for a super long time so I am sort of new. Maybe others can weigh in but this is what I know so far.
  19. May 12, 2016 at 5:30 PM
    #1259
    Maint1
    NC
    2019 DCLB Quicksand
    Thanks
  20. May 13, 2016 at 5:14 AM
    #1260
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I'm seriously considering upgrading from my OEM 16" TRD alloy wheels to these simply so I can run the Load Range C BFG KO2's in 265/70/17.
    Current tires = Toyo Open Country AT2 Load Range C - 265/75/16 no lift or spacers....all stock. I'll keep 2 for spares.
    After reading this thread and comparing the sizes on the tire size compare tool, it appears that this switch should result in virtually the same size tire/wheel setup and should fit just fine.
    Is the backspacing different on these 17" wheels? If so, could that cause unforeseen rubbing?
    Next question - I've seen many links here for sources of these - Is the original deal still valid?
