17 inch TRD wheels Matte Black.
Discussion in 'Wheels & Tires' started by Unchained 5150, Jan 31, 2015.
  1. Mar 25, 2017 at 11:16 AM
    #1601
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    Yes, another dealer told me August (for Canada). So i'm aiming to keep my stock Sport wheels and upgrade the tires to a spec that fit these TRD wheels, then when are available pick up a set and keep then around till the following Spring to mount.
  2. Mar 25, 2017 at 5:54 PM
    #1602
    Jason_X71
    Jason_X71 Well-Known Member
    2016 Tacoma TRD Sport 2wd Long Bed Auto
    I'm almost tempted to say FFFF it and buy other wheels cause there's no guarantee they'll still be available.....
  3. Mar 30, 2017 at 5:50 AM
    #1603
    scw156
    scw156 Well-Known Member
    PA
    2016 DCLB Off-road MGM
    I placed an order with Bev Smith as it was available on their website.... they cancelled the order a day later.
  4. Apr 5, 2017 at 10:47 AM
    #1604
    tracker366
    tracker366 Well-Known Member
    Bourbonnais,Illinois
    2017 Access cab TRD Off Road
    I just picked up a set of this wheels for my 2007 TRD off road and was thinking these tires will fit but not quite sure.
    Will I be able to fit the BF Goodrich LT265/70R17 All-Terrain T/A KO2 on my truck without a lift?
  5. Apr 5, 2017 at 11:18 AM
    #1605
    mrSM1TTY
    mrSM1TTY Well-Known Member
    Charlotte, NC
    2015 TRD Off-Road
    They'll fit, but you'll rub A LOT most likely.
    I have those same tires on my 2015 OR and I had to do a bit of trimming to the plastic on the wheel well and then lift about 2 inches to avoid rubbing.
  6. Apr 5, 2017 at 11:24 AM
    #1606
    tracker366
    Ok thanks.. I was hoping to avoid a lift but I guess I could go with a smaller tire but what fun is that. Thanks again.
  7. Apr 5, 2017 at 11:26 AM
    #1607
    mrSM1TTY
    Charlotte, NC
    2015 TRD Off-Road
    If you want something fairly simple and cheap, you can do what I (and many others) have done. Bilstein adjustable 5100's up front will get you enough clearance to prevent rubbing. You don't have to do anything to the rear unless you want to. There's only rubbing in the front.
  8. Apr 5, 2017 at 11:30 AM
    #1608
    tracker366
    That's a good idea.. My shocks are ten years old so might as well put new ones on. Can I still use the same front springs?
  9. Apr 5, 2017 at 11:32 AM
    #1609
    mrSM1TTY
    Charlotte, NC
    2015 TRD Off-Road
    I used my stock OR springs, so probably, but I'm not 100% sure what you have.
  10. Apr 5, 2017 at 11:36 AM
    #1610
    tracker366
    2007 TRD off road Tacoma 4x4 with the original Bilstein shocks
  11. Apr 5, 2017 at 11:38 AM
    #1611
    mrSM1TTY
    Charlotte, NC
    2015 TRD Off-Road
    I would assume you'd be good to use the stock springs then.
  12. Apr 5, 2017 at 11:41 AM
    #1612
    tracker366
    Thanks for all the help mrSM1TTY
    I opted to change the look of the truck instead of buying a new truck.$$$$
  13. Apr 5, 2017 at 11:46 AM
    #1613
    mrSM1TTY
    Charlotte, NC
    2015 TRD Off-Road
    New wheels/tires plus a little lift will do that (and for a lot cheaper). For the rear, consider a 3-leaf AAL pack. You can pick one of those up for about $200 and install it yourself if you have a friend (and tools) to do it with.
  14. Apr 5, 2017 at 11:53 AM
    #1614
    tracker366
    Toyota just put the new springs on my truck last year per the recall. Maybe I can go with a add a leaf
  15. Apr 5, 2017 at 11:57 AM
    #1615
    mrSM1TTY
    Charlotte, NC
    2015 TRD Off-Road
    Yeah, you can go with a single or the 3-leaf AAL. Plenty of opinions and how-to's on this site for both options.
  16. Apr 5, 2017 at 12:03 PM
    #1616
    tracker366
  17. Apr 5, 2017 at 1:21 PM
    #1617
    mrSM1TTY
    Charlotte, NC
    2015 TRD Off-Road
  18. Apr 5, 2017 at 1:27 PM
    #1618
    tracker366
    I didn't know know that. Thanks at first I was thinking of putting just spacers up front but what I have read it's better to go with the 5100s
    Thunder Fist likes this.
  19. Apr 6, 2017 at 8:04 AM
    #1619
    mrSM1TTY
    Charlotte, NC
    2015 TRD Off-Road
    Yeah, I'd recommend the 5100's over a spacer lift. Should give you a better ride and put less wear and tear on the vehicle.
  20. Apr 6, 2017 at 11:17 AM
    #1620
    tracker366
    Just got back from the truck accessories shop and asked about
    2" lift rear add a leaf.
    2 Bilstein front adjustable 5100
    2 Bilstein 5100 rear 2.5" lift.
    Thinking on just buying the whole set from toyotec cause it comes with front coils
    mrSM1TTY likes this.
