17" Konig Six Shooter Wheels - Brand New
Discussion in 'Wheels & Tires Marketplace' started by JdMeF9SiR2, Sep 20, 2012.
  1. Oct 24, 2013 at 9:20 AM
    #241
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I believe the BFG t/a ko in 265 70 17 should only be run on a wheel with a maximum width of 8.5"(as per BFG specs). So you would need to get the 8" version of the wheel
  2. Oct 24, 2013 at 9:39 AM
    #242
    davefollower
    davefollower Active Member
    Forgot to mention I was going to run the 17x8 wheels.
  3. Oct 24, 2013 at 10:09 AM
    #243
    Hairy Taco
    North of Hell
    08 TRD
    ok. If that wheel has a 5" backspacing, then it should have a +12 offset I believe. That would give you .47" extra clearance on the brakes and push the wheel out .94" compared to a stock 17" Sport wheel.
    Will you rub? You may rub, you may not. If you do, I suspect it would be minor.
  4. Oct 24, 2013 at 6:27 PM
    #244
    davefollower
    Thanks for the info.
  5. Oct 25, 2013 at 10:58 AM
    #245
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    The 17x8 have 0 offset. 4.5" backspace. Stock sport wheels are 7.5" wide w/ +30= 5.5" backspace. So a 8" with 4.5 back sticks out 1.5" further per side than the stock sport wheels.
  6. Oct 25, 2013 at 11:02 AM
    #246
    Hairy Taco
    North of Hell
    08 TRD
    ^^^then this, my mistake. I didn't see different specs for the 17x8's in the OP. These specs are nicer, so for the better!:D
    -but the chances of rubbing just increased unfortunately:D
  7. Oct 25, 2013 at 2:22 PM
    #247
    JdMeF9SiR2
    JdMeF9SiR2 [OP] FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    You should be fine with the 17x8" / 0mm offset / 4.5" back spacing Six Shooters and a mild 265/70R17 all-terrain tire, but you might experience very minor rubbing on the mud flaps at full lock.
    Anytime you increase the overall diameter of the tire, increase the wheel width, and decrease the offset you do run the risk of rubbing a bit, but it's been my experience that you should be OK with this setup. If your OE shocks have some mileage on them and they're getting worn out you might also rub the mud flaps a little more often.
    Overall this is a fairly conservative setup, and you shouldn't have any serious issues.
  8. Oct 25, 2013 at 2:31 PM
    #248
    JdMeF9SiR2
    Corona, CA
    Thanks for helping out with davefollower's question. The exact difference is 1.43" vs. the stock 17x7.5" TRD Sport wheels.
    .5" additional width / 2 = .25" to inside and to the outside of the wheel (you divide by 2 because the width is spread out evenly across the plane of the wheel).
    30mm lower offset = 1.18" additional outward stance.
    1.18"
    +.25"
    1.43" additional outward stance vs. the OEM 17x7.5" et30mm offset wheels.
    You can compare the backspacing numbers that we provide to determine inside clearance, which will increase by 1.0".
    Thank you for your help as well, but just to clarify, the chances of rubbing actually decrease when going from a 9" width / 0mm offset to an 8" width / 0mm offset.
    The calculations are actually incorrect, but it's a common error. Please remember that back spacing takes into account both of the .5" outer flanges of the wheel, which means that an 8" wide wheel actually measures 9" from flange to flange, a 9" wide wheel measures 10" from flange to flange, etc.
    A 9" width with 0mm offset will sit outward 1.93" additionally when comparing to a wheel with a 7.5" width and +30mm offset (OEM 17" TRD Sport wheel).
    A 9" width with 0mm offset will have .43" additional inside (suspension) clearance when comparing to a wheel with a 7.5" width and +30mm offset.
    Also, please note, as many people often get confused, that the 9" / 0mm offset wheel will NOT stick out of the fender by 1.93". It just will sit outward 1.93" more than the OEM 7.5" width / +30mm offset wheels, which are quite sunken in from the edge of the fender.
    One more point of clarification - lower backspacing and offset do not always directly correlate to increases in brake clearance. In the cases of the Konig Six Shooter and the other wheels that we sell - brake clearance is always better than OE wheels. However, in some other instances from other manufacturers brake clearance may actually decrease even though the offset is lower, and this can be due to spoke design or lip design.
    Fast1 likes this.
  9. Oct 25, 2013 at 5:34 PM
    #249
    Hairy Taco
    North of Hell
    08 TRD
    It was my error to base calculations off an incorrect positive offset. That said, it has most certainly been my experience that a 265 70 17 BFG AT tire on a wheel protruding 1.5" further than the oem will rub on stock suspension More so than a wheel that only protrudes a half inch.
  10. Oct 29, 2013 at 1:43 PM
    #250
    JdMeF9SiR2
    Corona, CA
    No problem at all. I know you were just trying to help. :)
    Any wheel that sticks out more than another and that is also combined with a taller than what was originally equipped has the propensity to possibly rub more, but my experience with years of installations is that a 17x8" / 0mm offset wheel (such as the Konig Six Shooter) with 265/70R17 BFG All-Terrain T/A KO tires will just rub very slightly on the mud flaps and fender liner on a 2nd Generation Tacoma w/ stock suspension. The rubbing can easily be remedied, and most of the time it only rubs when the steering wheel is turned to full lock. And, if the truck should have even a mild 1.0" (+/-) lift, there is no rubbing.
  11. Oct 30, 2013 at 10:36 AM
    #251
    JdMeF9SiR2
    Corona, CA
    17x8" Konig Six Shooters in matte bronze are expected to be back in stock any day!
    All pre-orders will ship immediately, and all waiting list customers will be contacted as soon as the wheels arrive. Additional sets are still available.
    Diameter: 17"
    Width: 8"
    Offset: 0mm
    Backspacing: 4.5"
    Bolt pattern: 6x139.7mm
    Color: Matte Bronze
    Light and strong! Only 20.6lbs per wheel!
  12. Nov 3, 2013 at 2:23 AM
    #252
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    So any of these colors on this site available?
  13. Nov 3, 2013 at 2:37 AM
    #253
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
  14. Nov 4, 2013 at 11:28 PM
    #254
    JdMeF9SiR2
    Corona, CA
    Yes, definitely. Some of the custom finishes might be listed as "Not UV Stable," so those are colors that we would not recommend. Otherwise our powder coater can finish a set of the wheels in any color you see listed on that website. Just let me know which ones you are interested in, and I will get you a quote. :thumbsup:
    Cool, thanks! :)
  15. Nov 18, 2013 at 5:23 PM
    #255
    JdMeF9SiR2
    Corona, CA
    PMs sent to everyone who inquired.
    17x8" Six Shooters are in stock in matte black and matte bronze! :)
  16. Dec 17, 2013 at 1:18 PM
    #256
    JdMeF9SiR2
    Corona, CA
    Update 12/17/2013:
    -Graphite Gunmetal - back in stock by early next week. The shipment is about 80% pre-sold out, but there are still a few sets available from this shipment.
    -Matte Black - back in stock by early next week. There will be a few sets available as well.
    -Matte Bronze - in stock now, but quantities are limited. Please contact me right away if you'd like a set.
    Thanks everyone! :)
  17. Jan 28, 2014 at 1:12 PM
    #257
    JdMeF9SiR2
    Corona, CA
  18. Jan 28, 2014 at 8:02 PM
    #258
    monstajp
    monstajp Well-Known Member
    joshua
    las vegas
    2011 trd sport debadged
    Debadged, Blacked Out Taillights and 3rd Brakelight , Blacked Out Grille, Blacked Out Lower Valence, Hot Wheels Badges, Yellow Fog Lights, Rims and Tires. Undercover Swing Case, Pop-A-Lock on my Tailgate, N-FAB Step Bars, Extang Trifecta Bed cover, Aero Cat- Back Exhaust, PIAA Extreme white 4000k Bulbs, Readylift 2.25 Leveling Kit.
    I think it is so hard to pick a color
  19. Jan 29, 2014 at 5:55 PM
    #259
    4x4rich89
    4x4rich89 Well-Known Member
    Richard
    Michigan
    2013 Tacoma TRD sport
    TRD supercharger
    Bump
    Love these rims, hope to have a set soon
  20. Jan 31, 2014 at 4:42 AM
    #260
    jimbo33l
    jimbo33l Tacodile.... Supreme
    Jimmy
    Baytown, TX
    12 DC Off Rd 4x4
    Can u pm me with a quote for 17x8 matte black shipped to 77523. Thanks
