17" Konig Six Shooter Wheels - Brand New
Discussion in 'Wheels & Tires Marketplace' started by JdMeF9SiR2, Sep 20, 2012.
  1. Oct 2, 2012 at 5:25 PM
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    Thanks Dustin.
    My current set up:
    Black Rhino Ocotillos
    17x9, 4.5 backspacing, -12 offset
    265/70/17 tires
    I'd like to keep approx. the same width/stance and go 1" narrower at the rim.
    Compared to my current set up, how will the Shooters width/stance be with it's offset and backspacing?
    And how about with the Countersteers?
  2. Oct 2, 2012 at 9:04 PM
    JdMeF9SiR2
    JdMeF9SiR2 [OP] FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    No problem. :)
    Comparatively speaking with your 17x9" -12mm offset wheels:
    -The 17x9" 0mm offset Konig Six Shooter wheels will sit inward .47" more, or you can say they will stick out .47" less. The wheels are also 9" wide, just like your current wheels.
    -The 17x8" -10mm offset Konig Countersteer Offroad wheels will sit inward .58" more / stick out .58" less. These wheels are 1" narrower than your current wheels.
  3. Oct 2, 2012 at 9:10 PM
    Junya808
    Junya808 Well-Known Member
    Maui, Hawaii
    2012 Tacoma OR 4X4
    Suspension Fronts: Icon Coil Overs Total Chaos UCA Rear: Icon shocks with resivior Icon aal. Interior: Wet okole seat covers Led map and dome lights Lighting: Slimcubby hid 6000k Slimcubby hid fogs 3000k Led parking lights Led license plate lights Led Switchbacks Misc. Mods Rear diff. Breather Mod
  4. Oct 2, 2012 at 10:13 PM
    JdMeF9SiR2
    Corona, CA
    :thumbsup:
  5. Oct 2, 2012 at 10:47 PM
    tacomtn
    Bummah. I didn't want to lose the stance. I guess there's spacers but I'd rather not go that route - problematic from what I've read. Or just live with the 1/2" difference.
  6. Oct 3, 2012 at 6:34 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    If my calculations are correct, they are still nearly 2" wider than stock stance on the sport wheel. They actually have a very nice/aggressive stance imo...but I don't believe it is recommended to run 265 70 17's on a 9" rim...
  7. Oct 3, 2012 at 6:42 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Another beautiful wheel. Great lightweight (and good looking) choices from FN and great customer service bump! :D
  8. Oct 3, 2012 at 6:53 AM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    Subd for wish list
  9. Oct 3, 2012 at 10:23 AM
    JdMeF9SiR2
    Corona, CA
    I understand. As mentioned by Hairy Taco, the added stance vs. stock wheels is still 2" +/-, which is very significant. If you have long-travel suspension you might still need that extra 12mm of stance, but if not I think these will still look great and aggressive without spacers.
    Also, going hand in hand with Hairy Taco mentioned, LT265/70R17 is generally not recommended to be used with 9" wheel widths. P265/70R17 (P-Metric) will work perfectly fine with 9" wide wheels.
    Furthermore, if you want to recoup the .5" outward stance vs. your -12mm offset wheels, you can always install 285/70R17, which will really look aggressive.
    FYI to others who might be reading this: 265/65R17 (the stock Tacoma 17" size) fits perfectly on 9" wide wheels. P265/70R17 tires also fit just fine on 9" wide wheels. It's the LT265/70R17 tires that usually recommend 8.5" or less wheel width due to the different sidewall. You'll know if you have P-Metric or LT-rated tire as denoted on the sidewall. You can also check the manufacturer specs prior to ordering your tires. Most manufacturers offer a P-Metric and an LT-rated tire in the same size. Just PM me if you need any help! :)
    Thank you sir! :thumbsup:
  10. Oct 3, 2012 at 10:31 AM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    awesome looking wheel, also some 265/70-17 tires will fit on a 9" wheel, i know nitto reccomends a 7-9" wheel with their 265's
  11. Oct 3, 2012 at 10:45 AM
    JdMeF9SiR2
    Corona, CA
    Thank you! And you're absolutely right. I don't know why I didn't mention that.
    P-Metric (non-LT) tires in 265/70R17 are generally approved to work with 17x9" wheels. I checked with BFG, Bridgestone, Continental, Falken, Hankook, Toyo, etc. and all of their P-Metric 265/70R17 tires are just fine with 9" wide wheels. It's just the LT (C/D/E-rated) versions that recommend 7-8.5" because of the different sidewall.
  12. Oct 5, 2012 at 1:10 AM
    tacomtn
    I'm running 265/70/17 on my 9" wheels and it's fine.
    Thanks for the 285 idea JD but that is wider than I need and want to go. Plus more $$ to fork out just for a 1/2". Not worth it. If I get these wheels I'll just live with the 1/2" less. But my tires only have about 15k miles on them. So I'm just looking into wheel options for now. The tires I hope to have a very long 50k or more miles.
  13. Oct 5, 2012 at 4:43 PM
    JdMeF9SiR2
    Corona, CA
    I don't blame you for not wanting to swap tires. I personally think the difference in stance between 9" wide / -12mm offset and 9" wide / 0mm offset won't be too noticeable on the Tacoma, since either set of wheels is already significantly wider and lower offset vs. stock. The stance will still be quite aggressive.
  14. Oct 9, 2012 at 3:40 PM
    creedler
    creedler Well-Known Member
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    265/70/17 General Grabber AT2, no lift, minor trimming.
  15. Oct 9, 2012 at 4:05 PM
    #35
    Hairy Taco
    North of Hell
    08 TRD
    saweeet!
  16. Oct 10, 2012 at 7:44 PM
    #36
    creedler
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    That was one on the reasons I went with the General AT2 tires, one of the few tires in a 265 that will accommodate up to a 9" wheel. It does make for an aggressive stance though.
  17. Oct 11, 2012 at 2:07 AM
    #37
    08navytrd
    08navytrd Well-Known Member
    Kenneth
    Italy
    08 Prerunner TRD Sport
    K&N CAI Flowmaster super 40 dual exhaust, Upgraded 6 disc from factory single disc, mag light attached to driver door, bilstein 5100 set at highest up front and 5100s in the rear, 1.5'' add a leaf in rear, aftermarket black headlights, 35w hids 6000k low beams, 4 85w HID off road lights 6000k color,
    Just ordered my matte bronze tuesday and cant wait for them to arrive, getting wrapped in some 285/75R17 Nitto terra grapplers. will post pics when they arrive.
  18. Oct 11, 2012 at 1:37 PM
    #38
    JdMeF9SiR2
    Corona, CA
    Thank you for posting your specs / experience! It will definitely help out all of us with our tire size choices. Your truck looks great too! :thumbsup:
    Thank you sir! Your wheels are on their way, in transit as of yesterday. :)
  19. Oct 11, 2012 at 9:16 PM
    #39
    08navytrd
    Kenneth
    Italy
    Thank you sir! Your wheels are on their way, in transit as of yesterday. :)[/QUOTE]
    Cannot wait hopefully they will be here when i get back from rome but i also have to wait on rubber bummer its taking that a little longer.
  20. Oct 12, 2012 at 3:22 PM
    #40
    JdMeF9SiR2
    Corona, CA
    I can't wait to see some photos of your truck with Konig Six Shooter wheels and a cool Italian volcano in the background!
