17" Konig Six Shooter Wheels - Brand New
Discussion in 'Wheels & Tires Marketplace' started by JdMeF9SiR2, Sep 20, 2012.
  1. Sep 2, 2019 at 8:29 PM
    #521
    Abumarf
    Abumarf Meep meep
    Hamza
    Tampa, FL
    2018 BR Wolfpack Edition
    I'm looking into a local set of six shooters and am wondering if anyone has used them with the Maxtrac Spindle lift, which I plan to do on my 3rd gen. I want to make sure they'll clear everything nicely with 32s or 33s maybe
  2. Sep 2, 2019 at 11:28 PM
    #522
    TacomaOC714
    TacomaOC714 Well-Known Member
    2015 Tacoma TRD OR 4x4 silver sky metallic
    @Abumarf The Six shooters come in both 16" and 17".
    Abumarf likes this.
  3. Sep 3, 2019 at 1:35 AM
    #523
    Abumarf
    Abumarf Meep meep
    Hamza
    Tampa, FL
    Oops. The ones I found are 17x8 with the 0 offset and 4.5 inch backspace. I'm wondering if anybody ran into any trouble due to the offset when installing the spindle lift
  4. Sep 3, 2019 at 6:11 AM
    #524
    Regcab05
    Regcab05 Well-Known Member
    David
    Atlanta
    05 regular cab 4x4
    Those should be fine. 17x8 4.5 bs are good for 33’s, 35’s will work too but expect to rub on the frame rails at full lock and maybe the uca’s too. 1/4 inch clearance on the uca depending on the tires.
  5. Sep 5, 2019 at 4:36 PM
    #525
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    Just to clarify, flow-formed wheels are still cast. The casting is placed on a spin-former and the barrel of the wheel is stretched out into it's final shape, while the face of the wheel remains the same as cast. This allows the grain structure of the barrel part of the wheel to be optimized for strength and/or reduced material (lightness).
    The pictures do not look like a barrel failure, the spokes themselves appear to have cracked (though I am just guessing). I do not know what kinds of non-destructive evaluation that FN Wheels uses to ensure quality, nor the use case in which it failed (we are taking @Gingerbeard Man at his word) but it's very possible that there was a casting flaw in this one particular wheel. If I were Konig, I would try to get ahold of this wheel to see if a failure mode could be determined. Though any catastrophic failure is undesirable, the sheer number of wheels sold compared to the infinitesimal examples of failure show that Konig has excellent safety margins and defective product control.
    I own and use a set of six shooters on my own truck. I am happy with them and will not be switching wheels.
  6. Sep 5, 2019 at 7:24 PM
    #526
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    I’m fairly certain I covered it earlier, but I’m sending the damaged wheel to Konig, the label has been printed and shipping out today. They asked and I had no reason not to send it to them. Again, the truck has never been wheeled or abused.
  7. Sep 5, 2019 at 9:37 PM
    #527
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Nor will I. But it was a frightening thing to read about nonetheless
    su.b.rat likes this.
  8. Sep 10, 2019 at 11:33 AM
    #528
    JdMeF9SiR2
    JdMeF9SiR2 [OP] FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    The 17x8" +0mm offset Six Shooters will definitely clear your Maxtrack spindle lift with 33" (285/70R17) tires. We've tested and installed this exact application many times of over the years.
    The Six Shooters come in 17", and a similar, but not identical, wheel called the Countersteer Offroad comes in 16".
    Absolutely correct. 35" tires are a challenging fit on a Tacoma with just about any wheel/tire/suspension combination, but 33" will work well with the aforementioned spindle lift.
    Also absolutely correct. The centers (spokes) of flow formed wheels are the same as cast wheels. The barrel of the wheel is formed over a mandrel with heat and pressure, which creates a more uniform grain structure providing better strength across the barrel when compared to a non-flow formed barrel. The barrel of a properly flow formed wheel is comparable to that of a forged wheel, but the spokes remain the same as the base casting method used to form them.
    With the wheel in question : the wheel is being returned to Konig for analysis. More than 200 units were produced and sold from the same batch code / manufacturing date as the one wheel in question (and many thousands of Six Shooter wheels in total over the life of the wheel before we released the new flow formed Six Shooters), and this is the first report of any failure. The customer in question owned and used the wheels for 4 years. We take any claim very seriously, but unfortunately we nor Konig can provide an unlimited, no questions asked, lifetime and all expenses paid warranty.
    We hope that our customers and potential customers draw the same conclusion as you when you stated:
    "Though any catastrophic failure is undesirable, the sheer number of wheels sold compared to the infinitesimal examples of failure show that Konig has excellent safety margins and defective product control.
    I own and use a set of six shooters on my own truck. I am happy with them and will not be switching wheels."
    Thank you very, very much for being a customer and for reading between the lines.
    Thank you as well for being our customer. I also know that you've owned, enjoyed, and in your own words thoroughly abused your wheels without issue for quite some time now. Anyone can post anything on the internet (including posting pictures intended to startle or frighten you) with or without full context and without you being privy to the motives.
    We have sold and continue sell tens of thousands of our wheels and our Konig exclusive wheels every year for 15+ years, and Konig wheels has sold and sells hundreds of thousands of wheels every year for 35+ years. We don't expect nor would we ask everyone of those thousands of customers to post a daily journal update letting us all know that they're enjoying and getting use out of their wheels without any problems. You might see a post here and there when someone gets a new set of wheels, or when they go on a cool trip, or an update after they've had their wheels for many years and the wheels still look like new. However, when one motivated customer has an issue, and especially if the resolution to that problem doesn't immediately go the way they demanded (i.e. an immediate, no questions asked, full and total refund for all four wheels after 4 years and unlimited mileage/use), then with a particular motivation you might see a post that startles you. We have a well established reputation for erring in favor of the customer whenever it is even remotely possible or reasonable to do so, but we can't give away no questions asked, full and immediate refunds over the phone after 4 years of use of the product without properly assessing the claim.
    AR15xAR10[QUOTED] and su.b.rat like this.
  9. Sep 10, 2019 at 11:48 AM
    #529
    JdMeF9SiR2
    Corona, CA
    AR15xAR10 likes this.
  10. Sep 10, 2019 at 12:56 PM
    #530
    AR15xAR10
    No complaints from me brother. I’d do it all over again :thumbsup:
    JdMeF9SiR2[OP] likes this.
  11. Sep 10, 2019 at 3:57 PM
    #531
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    How much do the 17" Six Shooters in 5x150 weigh?
  12. Sep 10, 2019 at 4:03 PM
    #532
    TrailRayted
    TrailRayted Well-Known Member
    Ray
    2008 Rugged Trail Tacoma
    These will
    Nice looking rims for sure. Tacoma owners should think about the large amount of open space in these. As you know we have drums in the rear of our trucks.These may not do justice to the look of rusty drums.
  13. Sep 10, 2019 at 9:19 PM
    #533
    Abumarf
    Abumarf Meep meep
    Hamza
    Tampa, FL
    Awesome. Would you happen to have any pics of that particular setup on a 3rd gen?
    Also, is there a way to order just one rim to have a full size spare?
  14. Sep 11, 2019 at 6:05 AM
    #534
    AR15xAR10
    I keep my drums painted:
    And look at how good they look in the front!!
    TrailRayted[QUOTED] likes this.
  15. Sep 11, 2019 at 6:12 AM
    #535
    TrailRayted
    Ray
    Looks good if you keep up on it! Most calipers are rusty as well as a rust ring that starts right where the pads stop touching the rotors. Would definitly look good with slotted and drilled rotors and some Wilwood's or Brembo's all the way around.
    Below are my rims of choice for trucks. If they made a 6 lug for Tacomas I'd have them already. They keep the ugly in and the dirt and nasty's out.
  16. Sep 19, 2019 at 7:52 AM
    #536
    supersano
    supersano Well-Known Member
    06 PreRunner(SOLD) 97 FZJ80(SOLD) 98 Landcuiser 04 GX470
    17x8 Gunmetal 285/70R17
    CowboyTaco and AR15xAR10 like this.
  17. Oct 2, 2019 at 5:44 PM
    #537
    JdMeF9SiR2
    Corona, CA
    I have photos of the spindle lift with the Six Shooters on a 2nd Gen Tacoma, but not a 3rd Gen. I haven't received any photos from customers who have a spindle lift + Six Shooters, and unfortunately we do not own a 3rd Gen with a spindle lift to photograph.
    You can definitely purchase a single (or any quantity) from us.
    Looks clean! I keep my drums painted too.
    Thanks for posting photos of your matte gunmetal Six Shooters! To anyone wondering, we offer graphite gunmetal (high gloss) and matte gunmetal. Matte gunmetal is a little lighter than graphite (but not a light color overall) and it has a satin matte clear coat.
  18. Oct 4, 2019 at 7:59 AM
    #538
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    @JdMeF9SiR2 on the 17x8 six shooters, how har is the poke out past the fenders on a second gen Tacoma? Also, does the TRD center cap on them without modifying the cap??
    Edit......do you have a pic of this wheel in the machines aluminum?
  19. Oct 4, 2019 at 8:15 AM
    #539
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    @JdMeF9SiR2 also, on instagram I saw the Verge model. What will be the specs and color availability on those? As well as the TRD center cap fitment?
    Sorry for all the questions.....
  20. Oct 9, 2019 at 9:25 PM
    #540
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Was the 9” wide a bit more concave than the 8”?
