17" Konig Six Shooter Wheels - Brand New
Discussion in 'Wheels & Tires Marketplace' started by JdMeF9SiR2, Sep 20, 2012.
  1. Dec 5, 2012 at 12:29 PM
    #101
    JdMeF9SiR2
    JdMeF9SiR2 [OP] FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    The stock TRD Sport 17" wheels are 7.5" wide, and the offset is 30mm positive (30mm positive offset on a 7.5" wide wheel = 5.5" back spacing).
    There is absolutely nothing wrong with the LT265/70R17 tires that you have right now on 7.5" wide wheels.
    LT265/70R17 maximum recommended wheel width is 8.5". P265/70R17 allow for up to a 9" wide wheel because of the different sidewall construction.
    The 17x9" Konig Six Shooters are not recommended to be used with LT265/70R17 tires, but they are fine to use with P265/70R17, P265/65R17, LT265/65R17 or larger tires (such as the popular size 285/70R17 in either LT or P-Metric).
    Comparing the stance of factory TRD sport 17x7.5" +30mm offset wheels vs. 17x9" 0mm offset Konig Six Shooter wheels:
    The Six Shooters will have 11mm more inside clearance (about .43") from the strut / control arm. The Six Shooters will have a stance that is wider by by 49mm (1.9") to the outside of the truck.
    We have worked with Konig to come out with a 17x8" version of the Six Shooter as well for our customers that want to install narrower tires or specific tires that are recommended to be used narrower wheels. The 17x8" 0mm offset Six Shooter will be released in early Spring.
    For those that want a wider wheel the 17x9" Six Shooter will still be available. For anyone wondering - I also currently have a set of 17x9" Konig Six Shooters on my truck with P285/70R17 Nitto Terra Grappler tires. :)
    rydr1 likes this.
  2. Dec 5, 2012 at 12:39 PM
    #102
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    THANX
  3. Dec 6, 2012 at 12:23 AM
    #103
    808surfrat
    808surfrat Member
    Hawaii
    4X4 Taco
    Want to purchase a set, PM'd you JdMeF9SiR2...
  4. Dec 10, 2012 at 12:02 PM
    #104
    JdMeF9SiR2
    Corona, CA
    No problem! :)
    Thank you for your order! I can't wait to see your custom color once the wheels get back from the powder coater! :)
  5. Dec 11, 2012 at 3:59 PM
    #105
    jmast
    jmast Is it June yet
    O.I.C.
    2011 DCLB TRD SPORT
    Taz mudflaps
    Soooo no need for aftermarket UCA's or spacers on 3" lift?
    2011 sport
  6. Dec 11, 2012 at 4:06 PM
    #106
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    wheel backspacing isn't going to dictate whether you need an aftermarket UCA. They are recommended if lifting your truck 2.5" or more, many run without and claim to have perfectly good alignment, most can't tell you their alignment numbers from what I've seen though.
  7. Dec 11, 2012 at 9:22 PM
    #107
    JdMeF9SiR2
    Corona, CA
    Hi jmast,
    Good question!
    The Konig Six Shooter wheels will definitely clear stock upper control arms on your 2011 Tacoma with or without a 3" lift. You won't need to add wheel spacers or aftermarket control arms for wheel clearance.
    However, as BuzzardsGottaEat mentioned, you might want to invest in some aftermarket control arms to correct any alignment issues that you might encounter when installing a 3" lift. This is not related in any way to our wheels or any other wheels for that matter (including stock wheels). This is due to the change in suspension geometry caused by installing a lift kit.
    After I installed a 3" coilover lift on my truck, I wasn't able to get my truck's alignment settings to spec until I installed aftermarket upper control arms (UCAs).
    We have installed the Six Shooters on stock Tacomas and lift Tacomas, and there have not been any UCA clearance issues. :)
  8. Dec 31, 2012 at 12:27 PM
    #108
    JdMeF9SiR2
    Corona, CA
    I have one set of matte black left in stock!
  9. Jan 1, 2013 at 11:06 AM
    #109
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    can inget a shipping quote to 96720 (hilo, hi).
  10. Jan 2, 2013 at 7:10 PM
    #110
    JdMeF9SiR2
    Corona, CA
    PM sent to you. :)
  11. Jan 7, 2013 at 5:53 PM
    #111
    SeminoleTRD
    SeminoleTRD Well-Known Member
    James
    Fleming Island
    2008 TRD Sport DCLB
    3" ProComp Add-a-leaf, 1.5" SpiderTrax, Center Bearing shim, Nitto TerraGrappler 285/70R17, Volant Air Box, BakFlip Tonneau HD, DIY 3.5mm AUX Jack install, D-Ring bed mounts, Plasti-Dipped badges, Dumped 50 Series Flowmaster with DeltaFlow Tech, Lumen LED Fog Lights, Lumen Marker Lights, Spyder Smoke Headlights, Satoshi Grill, Anytime Fogs
    JdMeF9SiR2, do you have a pic of your truck with the Nittos on?
  12. Jan 10, 2013 at 11:51 AM
    #112
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    Any pics of the graphite gunmetal on a MGM tacoma?
  13. Jan 10, 2013 at 4:45 PM
    #113
    Alview
    Alview New Member
    I second the pics for MGM/Gunmetal pics :thumbsup::thumbsup:
  14. Jan 11, 2013 at 6:51 PM
    #114
    JdMeF9SiR2
    Corona, CA
    I don't have any photos yet. I will try to get some for you guys this weekend. I've been trying to find some time to install new suspension, and I was going to take photos of everything when it's complete. I'll just try to take some photos "as it sits" this weekend.
    Let me see what I can find for you guys. I have had some MGM customers order graphite, so I'll ask them if they can send me some photos. :)
  15. Jan 12, 2013 at 4:43 AM
    #115
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    Can't wait to see that!
  16. Jan 15, 2013 at 9:49 AM
    #116
    JdMeF9SiR2
    Corona, CA
    Matte black is currently sold out!
    I have two sets of each of these colors in stock:
    -Graphite gunmetal
    -Matte bronze
  17. Jan 15, 2013 at 4:38 PM
    #117
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    Ahhhhh I need $$$!!! These wheels are sick!
  18. Jan 16, 2013 at 11:37 AM
    #118
    JdMeF9SiR2
    Corona, CA
    01/16/2012 Update:
    Only one set of graphite gunmetal left in stock as of today.
    :) Thanks!
  19. Jan 25, 2013 at 11:49 AM
    #119
    JdMeF9SiR2
    Corona, CA
    PMs sent to everyone who inquired. Thank you all!
  20. Feb 2, 2013 at 11:11 AM
    #120
    JdMeF9SiR2
    Corona, CA
    UPDATE 02/02/2013:
    Due to popular demand, 17x8" Six Shooters (new size) will be arriving on approximately February 20, 2013 (2 - 2.5 weeks from today). I will have graphite gunmetal and matte bronze available in 17x8" at that time, and in mid-late March we will have 17x8" matte black available.
    I will continue to carry 17x9" Six Shooters as well. :)
