17" Method Standard 301 machined wheels, fitment & lug nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Jul 4, 2017.
  1. Jul 4, 2017 at 12:29 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    Before I begin with my wheel inquiry, Happy Independence Day to everyone especially our veterans & those currently serving!
    The tires I will use are 265/70R17 "C" Rated BFG KO2's. I will also buy a set of aluminum hub-centric rings (108mm OD x 106.1mm ID) to fill in the 2mm gap & to ensure they ride smooth.
    As for the Method Standard 301 Machined wheels there are 2 options in the 17" size
    1) MR30179060312N
    • Wheel Size: 17x9
    • Bolt Pattern: 6 on 5.5
    • Offset: -12
    • Back Space: 4.5
    • Hub Bore: 108
    • Wheel Weight: 28.2
    • Max Load: 2500
    • Finish: Machined with Clear Coat
    2) MR30178560300
    • Wheel Size: 17x8.5
    • Offset: 0
    • Back Space: 4.75
    • Hub Bore: 108
    • Wheel Weight: 27.7
    • Max Load: 2500
    I'm leaning more towards the 8.5" wide version since I will be using 265mm wide tires but I don't know if they will stick out passed the fender or sit flush. I am looking for them to stick out passed the fenders a bit. For those of you that are using these wheels (or any other wheel with these specs) could you please post some pics that are down the side of the truck so that I can see how far they stick out passed the fenders?
    Did your wheels/tires balance ok?
    Will I need extended thread lug nuts?
    Will I need longer wheel studs?
    Thank you all for your time.
    Petros
  2. Jul 4, 2017 at 3:29 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I just realized that I posted this in the wrong section. I moved it to the "Wheels & Tires" section.
